Old 11-27-2008, 07:50 AM   #1
msedillo
Member#: 193030
2007 wrx
red
Default Rallting noise with WOT HELP!?!?
Hey guys i just recently noticed a rattling noise coming under the car the car runs perfectly fine and has no performance issue but when i open it up it sounds it sounds like rattling loose change. i can hear it very faint inside the car. Could this be an exhaust leak? I have no clue what it is any help is appreciated thanks
msedillo is offline   Reply With Quote
Old 11-30-2008, 04:16 PM   #2
shiftlesswrx
Member#: 138890
04 impreza wrx
java black
hey there it sounds like i may have the same problem any one else? i can't figuier this one out any help?
shiftlesswrx is online now   Reply With Quote
Old 11-30-2008, 04:30 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
detonation
VERY bad juju
Old 11-30-2008, 05:49 PM   #4
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Yup, pinging and detonation. Very bad for...well, everything. Don't allow it. If you hear it, back off the throttle. Ensure you are up to date on all the usual maintenance if the car is all stock, and/or see a specialist if it needs a "tune" if it is modded out. Also, check for fuel quality (switch stations, always run Premium, etc.).
I was riding with my wife in her Saab Turbo, I kept yelling at her because it was pinging so badly...looks like a bad boost control solenoid in conjunction with poor quality gas...it also needed a fuel filter badly, and after changing the filter it improved, and was nearly eliminated with better gas. Cleaning the BCS cured the rest.
JamesWilson is offline   Reply With Quote
Old 12-01-2008, 03:09 PM   #5
2bluewagons
Member#: 58475
2004 WRX Wagon
WR Blue
Definitely follow the advice above, but since you say the sound is coming from under the car (as opposed to from the engine bay) and if the sound is only apparent at certain RPMS (regardless of which gear you're in) then it could be heatshield or other exhaust compnent rattle. You could recreate this in neutral and have a friend lie under the car to try to pinpoint the noise as you slowly increase throttle.
This would be more of a matallic ting than loose change, but onomatopoeia is a b***h.
2bluewagons is offline   Reply With Quote
strange noise at WOT, help? siksit Service & Maintenance 0 10-10-2009 08:04 PM
weird noise an WOT WRXout Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-05-2004 11:06 AM
"Electric zapping/buzzing"-like Noise at WOT, 1st&2nd Gear @ 5000+ RPM, A/T '04 WRX dcwrx2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 09-30-2004 01:13 AM
Screeching noise at WOT when shifting gears timo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-17-2004 02:03 PM
weird noise at WOT WRXout Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-14-2004 05:20 PM
