Old 11-27-2008, 05:44 PM   #1
exrage
Member#: 77366
2014 WRX Hatch
Default real time maps on AP1
So I got my base map to the stage 1 at 93 octane no problems. i check to see what map is being used and it states stage1 93. I try to go to a realtime map - like the econo or the high waste gate map and it says that it flashes it, but when i check to see what map is being used it still says stage1 93... I dont know if I am selecting a real time map incorrectly or what? Does the car need to be turned on? does it need to be completely off? Does it reset to the base map when i turn the car off and back on? the ap manual isnt very clear about any of this stuff...
exrage is offline   Reply With Quote
Old 11-27-2008, 05:49 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
The AP1 only shows your base map you flashed to the ECU, the rt maps you need to remember yourself as to what you flashed on top of the base map...
wrxdrvr is offline   Reply With Quote
Old 11-27-2008, 11:54 PM   #3
exrage
Member#: 77366
2014 WRX Hatch
thanks, so does that mean that if I go w/ the economy rt map, that i also need a stage 1 93 map in my rt maps so that i can go back to it or is there an easier way to go back to my base map.
Old 11-28-2008, 12:06 AM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yea, when you want to go back to the base map you just need to flash the same rt map as the base map and you are there.
Stage 1 Base MAP ON TOP of Real TIme MAP? jeraljay AccessPort 3 08-20-2007 08:27 PM
Help, sent real time map without car being on, stuck on 'sending.." imprzya AccessPort 3 07-09-2007 08:23 AM
Switching between real-time maps on Accessport bigwrxguy Engine Management & Tuning 18 04-09-2005 07:47 PM
AP: Changing to real time map on the fly txl146 Engine Management & Tuning 8 08-09-2004 05:41 AM
regarding anti thef maps and real time maps for the accessport bubba03wrx Engine Management & Tuning 2 05-24-2004 11:01 PM
