Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 11-28-2008, 03:36 AM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default wat grade dino oil for built motor break in?
may i ask wat's a gd grade to run for a built engine considering e larger clearance?
jacky599r is offline   Reply With Quote
Old 11-28-2008, 03:39 AM   #2
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
contact your engine builder. I would do just 5w30 or 10w30 and use good oil and filter.
spoolinsti05 is offline   Reply With Quote
Old 11-28-2008, 08:01 AM   #3
jays05
Member#: 78165
05 STI 35r + e85
I ran Rotella 15w40 for the first ~2500 miles.
jays05 is offline   Reply With Quote
Old 11-28-2008, 08:08 AM   #4
jacky599r
Member#: 137631
2006 WRX
Red
hmmm, is 15w50 any gd? this is actually the 2nd rebuilt as the first one has gotsome oil ring prob. do i need to break in as long? all in all it has clocked 3000k km for the first rebuilt and then 2000k km for the 2nd. im goin for an oil change so thought if i should try something different. we dont have rontella
Old 11-28-2008, 10:46 AM   #5
acssa
Member#: 184023
Default oil
Cosworth wants 1000 mile on 20W50 mineral oil. Dont rev it passed 4500rpm in general.
acssa is offline   Reply With Quote
Old 11-28-2008, 08:59 PM   #6
jacky599r
Member#: 137631
2006 WRX
Red
20w50? woah. shoudnt break in oil be as thin as possible?
Old 11-28-2008, 09:25 PM   #7
DSM_Outback
Member#: 56345
93 Swapped L
Green
+1 If no cats
+2 If you get some heat in the oil before you drive.
DSM_Outback is offline   Reply With Quote
Old 11-28-2008, 09:29 PM   #8
Member#: 189490
I tried Brad Penn Break In Oil http://www.bradpennracing.com/Products/BIO30.html in my car with great success.
Break in oil will vary. Depends on bearing tolerances and if you will break it in the "old fashioned way" by driving in various speeds and loads or on a dyno.
In most cases, you want to find mineral oil with as much zinc as possible.
http://www.mototuneusa.com/break_in_secrets.htm
Artie
Artie@Agile Auto is offline   Reply With Quote
Old 11-28-2008, 09:41 PM   #9
jacky599r
Member#: 137631
2006 WRX
Red
is castrol gsx w40 a gd candidate?
im on my last "burst" before transiting to sythethics. Have been on 15w50 all along for the 2nd rebuilt.
Old 11-28-2008, 09:48 PM   #10
jacky599r
Member#: 137631
2006 WRX
Red
sorry. GTX 15w40
Old 11-28-2008, 10:29 PM   #11
Rickyh
Member#: 40453
20w50 since day one. Only 2500 miles on the motor so far but all is well. I changed it at 100, 500, 1000 and 2000.
compression is even at 145 on all 4.
Rickyh is offline   Reply With Quote
Old 11-28-2008, 11:12 PM   #12
AdamBOMB_STi
Member#: 103419
04.7 STi
LA Sleeved 2.5,35R,Hydra
i make it simple. initial fire up, 30w non-detergent cheap oil. drain after 15 mins of idling. then "napa 10w40" changed out a few times until 1000 miles. after that 10w40 or thicker dino oil until 4000+ miles.
AdamBOMB_STi is offline   Reply With Quote
Old 11-28-2008, 11:29 PM   #13
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Yup, cheap oil! If you are replacing it every 200-400 miles and not abusing it, why spend gobs (especially now-a-days) on more exspensive oil that will not see boost?
Old 11-29-2008, 12:10 AM   #14
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
NO. Using a thin oil for break in is very bad to do. Thin oils dont aid you at all in bedding in the rings.
Use nothing less then 10w40 and never use a synthetic until your pass at least 2500 miles.
project_skyline is offline   Reply With Quote
Old 11-29-2008, 12:16 AM   #15
quikcobra
Member#: 175246
Here is how I break my motor's in.
quikcobra is offline   Reply With Quote
Old 11-29-2008, 12:34 AM   #16
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
What about the Royal Purple break in oil that recently came out?
Old 11-29-2008, 12:56 AM   #17
AdamBOMB_STi
Member#: 103419
04.7 STi
Even a little abuse is ok. Just as long as you have a proper break-in tune, AFR's and timing NEED TO BE CORRECT. Rpm's are ok, I just don't like to go overboard with the boost. I always use a very light spring in the wg for break in. maybe 3-4psi?? A LOT of engine braking, downshifting, and boosting the whopping 4psi!
Old 11-29-2008, 01:16 AM   #18
n2oiroc
Member#: 141952
15 legacy 16 wrx
quit being sallys. my built motor had less than 100 miles on it before 15 or so 23 psi 6th gear dyno runs. and it runs great!
n2oiroc is online now   Reply With Quote
Old 11-29-2008, 01:21 AM   #19
AdamBOMB_STi
Member#: 103419
04.7 STi
I don't discredit that method either, but if I could take my time breaking in a motor I will. Now if I had to make a deadline then yes I'd just fully tune it right away.
Old 11-29-2008, 02:56 AM   #20
jacky599r
Member#: 137631
2006 WRX
Red
erm, from where i come from, 35deg c everyday, breakin in with 15w40 is alright? How come is there 2 different school of thoughts, some say less viscos and some say throw in something thick. Ive boost the car initially to let it seat and now is alll shifting, loading and trying not to hit high boost, prolly 0.5bars?
In view of the new piston rings only, 3000km should suffice? I miss those days where i can scream down the streets....
o i just changed to 15w40 this morning. oil press seems a tad lower and less stable.
Old 11-29-2008, 07:49 PM   #21
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
I used the same method breaking in my new sti short block and it turned out to be a monster in the shadows.
Old 11-29-2008, 07:56 PM   #22
AwdBoostCreep
Member#: 182804
2006 Gsxr 1000
Turbo
I broke my engine in easy for 50 miles. Then gave her 10PSi here and there out of my PT67 turbo. Starting from 2,500 RPM, going to 5,500 RPM, Then deaccelerating in gear after each pull. Did a compression test at 350 mile's. I got dead even 155 on all 4 cylinder's.
AwdBoostCreep is offline   Reply With Quote
Old 11-29-2008, 10:45 PM   #23
DSM_Outback
Member#: 56345
93 Swapped L
Green
2500 is still too soon IMO
Old 11-30-2008, 04:19 AM   #24
jacky599r
Member#: 137631
2006 WRX
Red
gents, note this is not a fresh engine per sae. First built - new pistons, rods, bearings...
Then the shop screw it up and i have reinstalled the oil rings. Now im 2.2k km on the odometer. Is that too soon?????????????????????????????????
noobie in the oil department! motor break in.. anthonyfur Newbies & FAQs 10 08-10-2009 03:04 PM
Do i need to use dino oil for turbo swap??? why??? Mike7 Newbies & FAQs 5 05-07-2009 09:08 AM
new motor...safe to use old tune for motor break in???tuner advice needed!! JT's06sti AccessPort 2 02-21-2009 05:15 PM
What's a good dino oil for the tranny? joker11 Transmission (AT/MT) & Driveline 5 03-31-2008 10:14 AM
Best Dino oil for turbos? kaos200 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-01-2001 06:28 PM
