Old 11-28-2008, 04:51 PM   #1
Eyedoc Orlando
Member#: 146216
2007 Impreza 2.5i SE
Newport Blue Metallic
Default Seafoam a 2.5i... where?
Hi guys,
I'm very familiar with seafoam and it's uses in intake cleaning. That said, what hose are you guys using to pour the seafoam down? The brake booster on my car has a line running to only one cylinder on the driver's side so it didn't look like it would clean all 4. Is there a line that will clean all of the cyls?
Just curious. For now I dumped it in the gas If you know which line to use please chime in! Thanks.
Eyedoc Orlando is offline   Reply With Quote
Old 11-28-2008, 05:38 PM   #2
italsupra10
Member#: 15791
1999 Impreza RS BLUE
2003 Black FOZZ
I put it in the PCV hose on my 1999 impreza, worked like a charm!
italsupra10 is offline   Reply With Quote
Old 12-01-2008, 08:38 PM   #3
ShadowVlican
Member#: 156965
sorry for noob question.. but do you have a picture of what the PCV hose looks like?
i've been dripping seafoam into my brake booster hose... but like Eyedoc Orlando said, it doesn't seem to get to all cylinders
ShadowVlican is offline   Reply With Quote
Old 12-01-2008, 09:40 PM   #4
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
there are 3 vacuum hose attached to the air box, 2 on the left, one on the right.
on the left, the one that is close to the throttle body.
qualityracer is offline   Reply With Quote
Old 12-01-2008, 11:34 PM   #5
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
definatly the pcv line! wow bad idea with the brake booster line. your changing the way 2 cylinders are workings vs the other 2 .
look at your intake manifold. you will see silver lines
in the rear of it , a hose is connected to those lines . thats the pcv hose.
sea foam is awesome. ive never tried it in the oil but think i might next time im about to change it.
watchunglava is offline   Reply With Quote
Old 12-01-2008, 11:38 PM   #6
watchunglava
Member#: 168862
Old 12-01-2008, 11:41 PM   #7
qstarin
Member#: 186129
2001 2.5RS
STM
^^ that. nice picture.
This too (same thing): http://www.northursalia.com/modifica...n/pcv/pcv.html
qstarin is offline   Reply With Quote
Old 12-02-2008, 12:15 AM   #8
lolawd
Member#: 176670
2006 30r STi on E85
Ahh, I remember back in the day of Seafoaming my VQ30DE motor in my 01' Maxima. It totally fogged my neighborhood and pissed off all neighbors. Works like a charm though.
lolawd is offline   Reply With Quote
Old 12-02-2008, 10:17 AM   #9
Pohenegamook
Member#: 134262
cyka blyat
Just curious - do you think this is really needed for your 07?
I just didn't think that much gunk could build up in ~2+yrs...and since I've got an 06 I'm wondering about mine.
Pohenegamook is offline   Reply With Quote
Old 12-02-2008, 12:07 PM   #10
Eyedoc Orlando
Member#: 146216
I typically decarbon an engine with at least some throttle body cleaner every 30k, it's just part of my 30K tuneup
Thanks guys for the info!! I wasn't sure what the hell that box was on the throttle body
Old 12-02-2008, 04:11 PM   #11
watchunglava
Member#: 168862
i had 25k when i did mine . omg carbon build up is insane . the engine definatly felt more peppy afterwords.
Old 12-02-2008, 04:33 PM   #12
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
I just did it for the first time with 195k on the engine.
Wow.
XanRules is offline   Reply With Quote
Old 12-02-2008, 11:11 PM   #13
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Wow.
Haha get a nice big cloud of smoke for a few minutes? Mine was going like crazy when i did mine at 15k
Mike
GrimmSpeed is offline   Reply With Quote
Old 01-13-2009, 04:59 PM   #14
matsumoto.collin
Member#: 111563
2006 WRX Wagon
post deleted
matsumoto.collin is offline   Reply With Quote
Old 01-13-2009, 05:08 PM   #15
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Originally Posted by matsumoto.collin View Post
I'm a noob with a 2006 WRX. Can someone post a pic of where I would locate the pcv hose on my car? My engine has 69K so I'm expecting a lot of smoke out of the exhaust but are there or has anyone heard of any adverse effects of using Sea Foam or an engine cleaner? I've heard that you shouldn't use engine treatments with turbocharged engines. Any truth or input here? Thanks guys.
Collin
What's a turbo? I think you're in the wrong universe?
formula91 is offline   Reply With Quote
Old 01-13-2009, 05:20 PM   #16
n/a boxer
Member#: 160645
2013 Brz
LOLOLOL
n/a boxer is offline   Reply With Quote
Old 01-14-2009, 05:07 PM   #17
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Collin
You'd probably be better served in the Factory 2.5L turbo forum.
Counterfit is offline   Reply With Quote
Old 01-31-2009, 11:36 AM   #18
BlkTS02
Member#: 50142
2002 2.5TS
MBP
I just used seafoam on my engine which has 96k on it. Nowhere near as much smoke as I was expecting. I also just used chevron techron concentrate injector cleaner, which leads me to believe that it did a pretty good job.
BlkTS02 is offline   Reply With Quote
Old 02-01-2009, 03:08 AM   #19
Spudchucker
Member#: 201147
2006 Impreza 2.5ISC
M90 SUPERCHARGED
What is this seafoam treating you guys are doing? just how many horses would it revive on my 26k mile engine? (yes noob question)
Spudchucker is offline   Reply With Quote
Old 02-01-2009, 10:00 AM   #20
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Pick up a can of seafoam (it's a red and white metal can that's a little bigger than a soda can) at your local auto store. Follow the directions on the back and enjoy.
As for how many horses it would revive, I'm not sure. It's definitely not going to hurt anything
Old 02-01-2009, 12:51 PM   #21
Spudchucker
Member#: 201147
2006 Impreza 2.5ISC
M90 SUPERCHARGED
Nice, next time it's not insanely cold Ima have to go do that
Old 02-01-2009, 02:44 PM   #22
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
its fun...it is actually quite a bit of fun...just watch the temp guage as it can make the car run a bit warm
Mr_Snips is offline   Reply With Quote
Old 02-01-2009, 05:40 PM   #23
chad2.5i
Member#: 187720
2008 2.5i
i dont have to do it yet on my 08 but my last vehicle was a 02 silverado 1500!
at about 90k i decided i would do it!! you have never seen a bigger cloud for a longer amt of time.
i did my part that day to contribute to global warming!
chad2.5i is offline   Reply With Quote
Old 04-21-2009, 10:36 PM   #24
jaypt802
Member#: 149730
2002 Impreza WRX
sorry to bring this thread up....but what is the difference lots of smoke = lots of gunk.........to less smoke = cleaner enigne?? my car didnt have a lot of smoke?? i'm confused on this.......................and i did this today in the oil and vacumm line, gonna pour the rest into the gas tank tomorrow morning before i fill up, i felt a significant amount of difference after doing it
jaypt802 is offline   Reply With Quote
Old 04-22-2009, 12:30 AM   #25
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Don't bother using the PCV hose. It only connects to two cylinders, so you're only cleaning half your engine.
On the left (from car's perspective) side of the plenum, in between the plenum and the bits of the throttle body, towards the bottom of the plenum, is a vacuum line. Pop off the vacuum line and feed it in there. That's the only place I've found that feeds all 4 cylinders. Not to mention the plenum itself. Take your TB off, the plenum is disgusting!
Oh, for that matter, look into Chemtool B-12. It's the same sort of thing as Sea Foam, but with a lot more balls.
Subie Virgin: '07 2.5i... Where do I start? Kountersteer Normally Aspirated Powertrain 18 01-01-2009 10:50 PM
'07 2.5i... Where do I start? Kountersteer Newbies & FAQs 5 12-28-2008 09:54 AM
where to get 06 2.5i spoiler? kunel17 North West Impreza Club Forum -- NWIC 5 09-13-2006 12:32 PM
Where is all the current info for n/a 2.5i 's Team Scream Normally Aspirated Powertrain 3 09-08-2006 12:16 AM
OT: Anyone know where to get uppipe for legacy 2.5i? EJ20(GDB) Vancouver Impreza Club Forum -- VIC 9 10-29-2005 05:02 PM
