Tire & Wheel Forum sponsored by The Tire Rack |
11-28-2008, 08:37 PM | #1 |
Member#: 97537
Vehicle:2005 Saab 92x Aero Black |
one new tire - bad?
I recently got into an accident and they had to replace one tire.
The other tires have about 60% tread left. Is this bad? Can this damage the diffs? I hear you can shave the tire down, but will they do it after I've driven on the tire? thanks
11-28-2008, 08:40 PM | #2 |
Member#: 88005
Vehicle:2002 WRX + NSX Silver + Green |
Yes. that is def a big enough of a difference that you may end up damaging your center diff. Not worth it in my opinion. I would get 4 new ones and the others, or if you're lucky, find 1 used one.
11-28-2008, 08:43 PM | #3 |
Member#: 97537
thanks.
how serious is it? should i try to avoid driving? |
11-29-2008, 10:41 AM | #4 |
Member#: 166820
Vehicle:my ignore list |
You might as well replace the other 3 if they're already at 60% tread. I can't give you any hard data on tolerances for tread wear but it never hurts to have fresh rubber all the way around.
Is it ok to put on one new tire? | 04Silverex | Tire & Wheel | 10 | 10-31-2007 02:53 PM |
Need new tires...bad timing | Iceman12321 | Tire & Wheel | 10 | 06-03-2006 10:40 PM |
1 new tire, bad for diff? | SilverKnuckles | Tire & Wheel | 12 | 09-11-2005 01:22 AM |
One new tire okay? | mycarsux | Tire & Wheel | 8 | 10-07-2004 09:13 AM |
Getting one new tire...question?!? | cracker196 | Tire & Wheel | 1 | 09-14-2004 05:08 PM |
