Old 11-28-2008, 09:33 PM   #1
1000AWHP
Member#: 195881
Default "Easiest" way to make 500whp...
Hello everyone! I have a 2004 STi...I was thinkin bout going with an FP Red turbo. What do u guys think? My goal is 450-500! I called Forced Performance and they said it can be done with just basic mods...Does that sound right??
FP Red Turbo
Turbo XS TMIC
1000 injectors
Walbro pump
Turbo-back exhaust
Headers/ up-pipe
Those were the basic mods they mentioned...What kinda #s have yall seen from experience? If not with this turbo, is it possible to make 500whp on pump gas w/o having to spend millions? Thanks for any help/info you might have!!
1000AWHP is offline   Reply With Quote
Old 11-28-2008, 09:41 PM   #2
mpsti05
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
*cough* search *cough* i throw something quick at you, fp red,inlet pipe,tgv deletes,big maf,tbe,el header,injectors,pump,clutch cobb or opensource for em and a good tune maybe meth, and This forum is full of information so use the search button
mpsti05 is offline   Reply With Quote
Old 11-28-2008, 09:51 PM   #3
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
The 04's are known for having the weakest pistons of the sti's which means when you push that stock block to make close to 450-500 whp on pump you WILL crack a ringland it is inevitable,maybe not immediately,but you will.There is no such thing as making 500whp on straight pump cheaply--PEROID!!!
john 1badSTI is offline   Reply With Quote
Old 11-28-2008, 10:24 PM   #4
1000AWHP
Member#: 195881
K, thanks for the help...I was told bout the piston thing before. Should I add rods while I have the motor out? If I did that, what kinda power could my motor reliably handle then?
Old 11-28-2008, 10:52 PM   #5
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
The easiest way is a big shot of nitrous
Mr_Snips is offline   Reply With Quote
Old 11-28-2008, 11:06 PM   #6
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
pick up phone, call local tuner, discuss "500hp", hang up and smile
cough cough: forget the red and go GT35R or bigger
pauli18c is offline   Reply With Quote
Old 11-29-2008, 02:44 AM   #7
CVR STi
Member#: 127428
moter will go boom.
CVR STi is offline   Reply With Quote
Old 11-29-2008, 07:23 AM   #8
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
wrxsti.l is offline   Reply With Quote
Old 11-29-2008, 07:48 AM   #9
Kaldar142
Member#: 151090
S197 boosted V8 FTW
upgraded shortblock and the biggest 35R you can get on meth...
Kaldar142 is offline   Reply With Quote
Old 11-29-2008, 08:29 AM   #10
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
TurboXS TMIC? I am going TXS FMIC for just ~330whp. If you're really going for 500whp, then think about the heatsoak your TMIC will suffer from. More power = more heat, and therefore more retarding on timing in certain driving conditions. Other than your internals I would imaging adding meth, both as a power adder and as a way to help guard against detontation. Depending on how you're going to be driving this beast you may get away with the stock transmission components but I would certainly be looking at a new clutch.
scramjett is offline   Reply With Quote
Old 11-29-2008, 08:34 AM   #11
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Originally Posted by wrxsti.l View Post
You know I've seen more than one driver of these Vipers lose to less powerfull cars because they can't control the wheelspin from its... what, 600ft-lbs in RWD layout. Still a hell of a car on the highway even in the passenger seat!!!
Old 11-29-2008, 10:05 AM   #12
Scoobs2002
Member#: 64615
2002 Impreza WRX
GT42R Power!
Reliable 500whp, or stock motor with big turbo kinda reliable 500whp?
Scoobs2002 is offline   Reply With Quote
Old 11-29-2008, 10:07 AM   #13
audioutopia
Member#: 77093
03 FPgreen'd WRX
05 Audi S4 stock
You can't do it on pump, you'd have to run pump/meth on the street. Race gas should get you there with the right turbo. I'd hate to say it but the cheapest way to 500whp would be to mod an evo...
audioutopia is offline   Reply With Quote
Old 11-29-2008, 10:08 AM   #14
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
and fp red or rotated 35r with supporting mods should do the trick.... problem is, the supporting mods are where a lot of the $$ cost comes in...
turbo inlet
TGV's
injectors
clutch
fuel pump
upipe w/ ext gate
tial 44
etc
All4bSpinnin is offline   Reply With Quote
Old 11-29-2008, 10:40 AM   #15
1000AWHP
Member#: 195881
LMFAO, I literally jus got posts back to back that were the EXACT opposite! Of couse I wanna believe the positive one, but who knows...Just cuz you havent seen 500whp, doesnt mean it cant be done. Maybe ur jus pissed cuz u have a 400whp wrx and ur getting raped by 200whp all motor civics...All tuners tell u it can be done, cuz they all want ur business...Does anyone actually know or any tuner that has done it?
Old 11-29-2008, 10:49 AM   #16
lev98
Member#: 140529
01 Ferrari 360 spy
There are plenty of cars that have 500whp+. They have a built block and a 35r. Do some research its been done many times over.
lev98 is offline   Reply With Quote
Old 11-29-2008, 10:50 AM   #17
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
If you are going for anything other than dyno numbers (ie any reliability) you will want too look at:
Forged internals, maybe sleeves
35R with all the trimmings
FMIC
Fuel Pump
INjectors
EM
damn good tune ($1000)
you may hit 500 without a built motor, but it will not last. If you're lucky, you'll break ringlands and be able to reuse motor parts. If not lucky, you'll break a piston and ruin the block, crank, rods, andmost expensvely - the heads.
Zornorph is offline   Reply With Quote
Old 11-29-2008, 11:14 AM   #18
520hpsti
Member#: 108965
2005 Subaru WRX STi
cheap. fast. reliable.
pick 2.
520hpsti is offline   Reply With Quote
Old 11-29-2008, 11:29 AM   #19
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
i'm running the fpred on my ej205 set up this is a great turbo and yes you can hit 500 whp with the red and right setup, however this will be on race fuel (c16, q16). with meth and pump you could be somewhere around 450.
there was a thread on here couple days ago guy hit 536whp and 500lbs with his red. do a search it may come up.
spoolinred is offline   Reply With Quote
Old 11-29-2008, 11:31 AM   #20
audioutopia
Member#: 77093
03 FPgreen'd WRX
05 Audi S4 stock
Dude a new 500whp subie is posted atleast once a week on this forum...
ps. even 350whp civics have a hard time keeping up with a 400whp subie on the street, its called traction....
Old 11-29-2008, 11:36 AM   #21
1000AWHP
Member#: 195881
Do u guys agree its easier to make power in an evo? Will it also be more reliable? Why get a Subie then...? Just curious...
Old 11-29-2008, 11:44 AM   #22
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
To more succinctly answer your question: I have tuned hundreds and hundreds of Subarus, many at 500+whp. The answer to your question really depends on a few more simple questions:
(1) Are you looking for a 500whp dyno sheet?
(2) Are you actually looking to run 500whp while driving around town?
(3) Are you planning on doing track racing (open track, not drag racing)
(4) Are you planning on drag racing the car?
(5) Do you have a good source for C16 or Q16 fuel.
(6) Do you realize that 500whp is > 500 crankhp?
The answer to those questions will significantly help guide you. While an FP Red can make 500+whp, it has to be pushed very hard to do it. Take a look at this thread from more than 3 years ago: http://forums.nasioc.com/forums/show...onaugle+fp+red
If the answer to question 1 is yes, but 2 is no, the Red will work fine. If you really want to drive around with 500whp, you will need something larger. While a 35R can do it, you would still be pushing that turbo very hard, especially on stock heads and cams.
Consider the questions I posed above, and you will be able to get more help then you expected.
Cheers,
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 11-29-2008, 11:52 AM   #23
520hpsti
Member#: 108965
2005 Subaru WRX STi
yah, its def easier and will probably be more reliable from the evo IX back. idk about the X's
subie love. brand loyalty. the rivalry. just like the car more.
most people dont buy their car knowing they are going to turn it into a 500whp+ beast.
Old 11-29-2008, 11:54 AM   #24
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Why 500awhp? Have you ever ridden in a 300awhp car? To get to 300awhp (which is still PLENTY fast for the street) all you need is a nice exhaust set up with some ported/polished manifold elbows, perhaps a short-ram intake, 255 fuel pump and a good tune. If you want 400awhp you will be looking at a 49-52lb/min turbo and highly recommended to swap out at least the pistons, massive injectors, FMIC and EWG. 500awhp is in no way easy if you want your motor to last. I'd recommend a GT35R .82A/R (minimal), fully built bottom end, some nice ported heads, cams and one hell of a valvtrain so you actually have a powerband you can rev to. In other words- $$$$$!
If you just purchased you're 04 STi, I'd recommend getting used to it stock then slowly add power. A strong "stage 2" setup is a very potent combination for the street and reliable. Do not forget suspension and brakes too!
Steve.804 is offline   Reply With Quote
Old 11-29-2008, 01:24 PM   #25
zmw
Member#: 13181
97 Supra
FAST
uhhh on 300WHP on an 04 STI can be had with a 3.5 APS catless turbo back, 93 stage 2 cobb map, and for some cars the k&n intake is needed for the extra push, that'll get you to roughly 295-310 awhp and about 330 wtq...
<1500$ if you search... 2500 if you retail it all.
zmw is offline   Reply With Quote
What does it take to make 500whp on a daily driven 07 STI?? sean18337 Other Engine Management 16 03-05-2012 02:02 PM
Quicker and less painful way to make 60 bucks than the other way excipient Rocky Mountains Impreza Club Forum -- RMIC 7 06-10-2008 05:18 PM
OT electricians - I need a way to make lights brighten and dim to music. RaceCarRiot Off-Topic 23 11-07-2006 03:10 PM
What is the best way to make a cast in order to make a fiberglass mould? BrysImpreza Interior & Exterior Modification 1 02-20-2006 10:21 AM
Is there a way to make Word export to HTML in a simple format? Jessie James Off-Topic 11 02-27-2004 04:06 PM
