Notices
Closed Thread
Old 11-28-2008, 11:11 PM   #1
sorrowfulkiller
Member#: 170439
I <3 Lamp
Default Alternator or voltage regulator?
I'm having an issue with my 02 wrx, it's got the stock alternator on it still and what its doing is sometimes when I'm driving recently it'll show 14.5-14.7 Volts on my turbo timer at first then it'll spike up to 15.7 or so then back down, on and off. While this is going on it'll flash the battery light also.
Pretty sure it's the regulator which I'm guessing it's on the alternator. Does anyone got any idea if it is or not?
sorrowfulkiller is offline
Old 11-28-2008, 11:53 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
You are correct. The regulator is inside the alternator. It looks like you need to replace the alternator.
Cougar4 is offline
Old 11-29-2008, 02:19 AM   #3
rick-l
Member#: 33868
2003 wrx
srp
The battery terminals are clean and tight correct?
rick-l is offline
Old 11-30-2008, 03:57 AM   #4
sorrowfulkiller
Member#: 170439
I <3 Lamp
it was the regulator, swapped it with an 02 outback one, works fine. 10 more amps and a hundred fifty dollars less than the wrx one!
Old 11-30-2008, 08:15 AM   #5
subaru3169
Member#: 55252
* pullup bar *
the outback is 85amps??
subaru3169 is offline
Old 05-18-2013, 01:32 AM   #6
kracky
Member#: 353711
2002 WRX Wagon
What part number did you use? I am having the same issue and wouldn't mind upgrading to the higher amperage as well.
kracky is offline
Old 05-18-2013, 05:23 AM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This thread is from five years ago. Please don't bump old stuff.
Mulder is offline
Closed Thread
Relationship between alternator whine, voltage, and alternator health caterpill Electrical & Lighting 2 01-16-2005 06:15 AM
FL: Apexi Super ground system/Voltage regulator QwikRex Private 'For Sale' Classifieds 47 10-01-2004 01:03 PM
Voltage Regulator / Lights dimming issue Woody643 Car Audio, Video & Security 9 12-22-2003 11:39 PM
Voltage Regulator Revision Mid West Subaru Owners Club Forum -- MWSOC 4 06-27-2002 12:50 PM
Voltag Regulator? callawayv Service & Maintenance 1 01-12-2002 10:48 PM
