#1 |
Member#: 191380
Vehicle:2009 WRX 5 Door Dark Grey Metalic |
After seeing a few posts about other people having motor issues with their 2009 Subarus, I would like to see who all is having problems.
Today I myself detected internal engine failure. By detected I mean I heard a loud knocking sound at 2000-3000 RPMs. Car purchased 10/11/08 Aprox mile 3200 VIN: 9G800693
#2 |
Member#: 191827
Vehicle:2009 WRX WRB |
I haven't heard any noise from my engine. I have approx 2200 miles. When was yours built?
#3 |
Member#: 174022
TXIC
Vehicle:2008 WRX Lightning Red |
May sound stupid, but the motor's natural rumble comes out around 2-3k. Are you sure that is not what you are hearing? That could be very well what you are believing is internal failure. If all else take it to the dealer and have them look at it, it's a new car with a warrenty for a reason...
#4 |
Member#: 133418
Vehicle:2006 DOM3 XTR WRX TR SRR 407whp 365wtq ppg'd |
so far ive heard about of a handful of them throwing rod bearings. Hense why there is a stop sale. but with every new set of revamped cars subaru has there have been a few bugs so just bring it to the dealer and have it checked out and if there is a problem i'm sure that they will fix it under warrantee.
#5 | |
Member#: 103136
1. Hasn't figured out the cause of the rod bearing failure yet and it is impacting even the 09 WRX/STi models. 2. Knows the cause of rod bearing issue, but it is too costly to implement a fix or a method of detecting the issue on the line and because it impacts a small number of motors, they chose to ignore it. 3. The issue has been fixed, however a large number of short blocks that could potentially have the issue have already been manufactured and it would be too costly to scrap or disassemble these motors for such a low failure rate. The OP has a video of the rod knock, IIRC. If you watch it, it is obviously not normal. |
#6 |
Member#: 152176
Vehicle:2001 2xImpreza 2.5RS BRP/SRP |
![]() i want a new subie, only looks like they are poorly made. |
#7 | |
Member#: 191380
Unfortunately, my car had 3200 miles on it. You would think by then I know how my motor is supposed to sound. That plus I do have an ASE Certification and have worked in multiple auto shops. The stop sale is only on the 2008 models with certain VINs. The 2009 is a different VIN set so it would not match up. I had my car towed to the dealer on Saturday (original selling dealer is 25 miles away) so hopefully I should hear something back from them this up coming week. As Tea Cups pointed out, I did find a video that one of the other members had posted on YouTube. http://www.youtube.com/watch?v=SvxaR7HSmWc |
#8 | |
Member#: 174022
TXIC
Nobody was insulting your intelligence, I was just pointing out that this motor is naturally noisy between 3-4K. My car has 9300 miles on it and every once in a while I think it does not sound like it should, but my car is 100% fine. If your car sounds like the video posted that is def. engine failure and I hope it works out for you.. Last edited by 08EJ25; 12-01-2008 at 04:47 AM. |
#9 | |
Member#: 192526
Vehicle:2008 WRX FMIC/VF48 Red/Steel Grey |
#10 | |
Member#: 191380
![]() Stopped by the dealer today. He said there was definitely internal engine problems. I just wanted to go "O RLY?!" He said phone calls were being made (translation SoA was called) Other than that, don't know much of anything. |
#11 |
Member#: 177056
Vehicle:2009 STI 2009 Forester XT |
Sorry your new car is having trouble. I know how frustrating it can be. My '09 STI threw up ABS/VDC warning lights after only 2 weeks of ownership, and it took them over a week to fix it.
Hopefully they find a fast resolution to the problem. It would really suck if you were without your 2-week old car for the next two months. |
#12 |
Member#: 110330
Vehicle:2007 STI Limited 2012 MDX 2012 Golf TDI |
SoA gave me a new longblock under warranty a while back from a spun bearing, took about 30 days after they sent their rep out to look at it, engine was shipped, etc. Hopefully they'll take care of you but it can take a while to get righted.
#13 |
Member#: 154013
Vehicle:2012 S4 Monsoon Grey |
Damn I feel sorry for you guys with new cars having engine trouble. Make sure you break in your engines properly 1,000 MILES and keep it under 4,000 RPM! Anyways good luck with the problems. Hopefully I wont have the same problem I only have 410 miles on the 08 sti.
#14 |
Member#: 191380
So... update.. my car ECU has been imaged and sent to SoA. I feel like it is a BlackBox on a doomed airplane.
#15 |
Member#: 194884
South East
Vehicle:07 F150 Lariat |
oh wow. have you ever flashed it? i flashed mine, i have an 08 with 2600 miles. i dont know what i would do it if they tried to deny warranty for something like that. i would flash back before they ever got to look at it tho.
#16 | |
Member#: 191380
#17 |
Member#: 194884
South East
how do i find out if my vin is affected by bad short block, i have a TBE on the way and will deffinitely not install if my engine is on track to doom.
#18 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
register on mysubaru.com, if there are any open recalls you can find out there or call your dealer.
#19 |
Member#: 161499
Before I get a new WRX I need to know that this has been resolved.
Subscribed and wishing those of you with this open issue a fair and quick resolution. |
#20 |
Member#: 169316
RMIC
Vehicle:2009 WRX DMG |
Knock at 1251 miles
VIN: 800572 Build Date: July 2008 Video of my car making the noise: http://www.youtube.com/watch?v=SvxaR7HSmWc Diagnoses: Spun bearing Fix: New Engine Time out of service: 3 1/2 weeks (should be less if your dealer doesn't screw up your car) I just returned from a 1400 mile road trip. Seems the new engine fixed the problem. ~2600 miles on the new engine now. Last edited by Peppe316; 12-02-2008 at 02:01 PM. Reason: more info |
#21 |
Member#: 191380
Yea it was Peppe316's video I have been showing people to describe the noise.
Dealer has called. They cannot determine if it was my fault or just faulty engine so they are replacing it. |
#22 | |
Member#: 7887
What is the root cause for the spun bearings? Contamination in the journal? Incorrect rank bearings? Design? ~~Quentin |
#23 |
Member#: 191302
Oil starvation. Poor clearance tolerances. Torquing issues. Contamination. High RPM on cold engine (on/off ship at the docks). Poor hone. Piston problem. There are many variables, that is probably why they have not figured it out yet.
#24 |
Member#: 161499
Glad to hear this.. Wishing you the best with the replacement and workmanship of the dealership. It really S U C K S that its a new car and this has to be replaced. Wonder if this will show on carfax??
#25 |
Member#: 191302
It sure should.
| Thread Tools | |
| Display Modes | |
| 2009 Impreza WRX Short Take Road Test: Faster to 60 than the STI | CARandDRIVER | NASIOC Official News, Articles and Polls | 143 | 09-25-2010 05:14 AM |
| Official 2009 Impreza WRX - 265HP (Info & Pics) | SOA Blog | News & Rumors | 3274 | 01-08-2009 08:20 PM |
| FS: 2009 Impreza WRX - wrecked/donor car - Perfect for swap - $8000 obo | ProdriveRex | Private Vehicle 'For Sale' Classifieds | 51 | 01-05-2009 01:53 PM |
| 2002 wrx motor issue??? | AWD0425 | Factory 2.0L Turbo Powertrain | 39 | 11-13-2008 04:46 PM |
| 2009 Impreza WRX PBB (Unofficial Pandog Bluebook/Buyer's Guide) | Pandog24 | News & Rumors | 95 | 11-02-2008 04:48 PM |
