Old 09-09-2011, 11:25 PM   #4851
BIGSKYWRX
Member#: 7958
09 GH B+
^ youch
new motor and probably an extended warranty to boot imo (that's what the vast majority of us got)
look into your state's vehicle lemon laws- worse comes to worse you can get your $ back
Old 09-10-2011, 12:55 AM   #4852
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Interesting how several second owner's are having them blow almost immediately... wonder why.
Breezio is offline   Reply With Quote
Old 09-10-2011, 05:38 PM   #4853
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Originally Posted by Blue Bomber WRX View Post
My wife's 09 XT had exact same problem 2 weeks ago. Drove it right to the dealership...where it's been sitting since. I found all of these posts and presented both SOA and my local dealer with the facts and my VIN is associated with the known engine issues. They have so far refused warranty because I didn't keep all my oil change receipts. I'm not sure why I need to spend the weekend calling the quick-lube places around my house to get copies of oil change reciepts when the problem is obviously a Subaru engine issue. Any thoughts on getting SOA or the dealer to move more quickly?
Bomber-
I had this happen to me on my 05 (spun bearing). Never kept the receipts but treated the car better than the dealer would have. Eventually I went in with a bottle and asked for an oil sample so I could have it Independently Tested since they were accusing me of not maintaining the car. I had a fumoto valve on my pan so I knew it would be easy to do. That seemed to get things rolling, but they still screwed me by not giving me a loner for the 45+ days it took them to replace the shortblock. I ok'd them to drop the pan to inspect the engine for excessive wear due to lack of maintenance and the day after that I got SOA approval for the repair at 30K even thought I had an 80K warranty.
Oh, and I had NO luck getting receipts anywhere so I'll hold my breath for you. Demand to get an oil sample from your pan, and watch them do it. They will know you are serious if you stay in their face.
WRXSD is offline   Reply With Quote
Old 09-11-2011, 03:55 PM   #4854
-Witness-
Member#: 294108
Default Think you're in the clear? Think again.
let me just add to the sleepless nights of every WRX owner who thinks they cleared the 18k mile 'danger zone'
2009 WRX, 08/08 build date
54,xxx miles.
100% bone stock besides tires. 100% adult owned & dealer maintained. Oil change less than 100 miles ago, @ 3000 miles.
Never seen a race track, never drag raced, never overreved, never 'power shifted'
(though ive met the 144 mph limiter a few times on the highway....)
Spun rob bearing friday
Sleeping well thinking you're in the clear? Think again.
....did i just take the title for highest mileage to blow?
~Ryan
-Witness- is offline   Reply With Quote
Old 09-11-2011, 11:26 PM   #4855
dScooby
Member#: 277465
2010 WRX
sl0w
Is there no problems for the 2010?..
dScooby is offline   Reply With Quote
Old 09-12-2011, 05:35 PM   #4856
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Read the thread title
Superorb is offline   Reply With Quote
Old 09-12-2011, 09:36 PM   #4857
snowskis
Member#: 222489
2009 WRX Hatch
Originally Posted by -Witness- View Post
...100% adult owned...
Are you driving on the autobahn? God save me if I'm on the same highway when you pull this off as my kids are in my back seat. Last I checked here, the speed limit is 70mph. Sounds like you need to take it to the track to get your speed fix.
snowskis is offline   Reply With Quote
Old 09-14-2011, 01:09 AM   #4858
Breezio
Member#: 234357
2009 WRX
Highest I've seen, maybe you shouldn't have babied it so much so it would have gone sooner
Old 09-16-2011, 03:00 AM   #4859
EternalX
Member#: 217047
2009 Subaru Impreza WRX Sedan
Miles = 50,400
Location = Indianapolis
VIN = JF1GE76669********
Mods = BONE stock, not a single mod or change on the car other than some winter tires on steelies.
Work done = never any major warranty work done, never had a problem with the car until now. Only issue I had at one time was it would NOT shift into reverse without serious work some times, I had to JAM it in there to get it into gear, and also sometimes could put it into 4th or 2nd gear (at bottom of shift stalk, will help get it into reverse) then it would go into reverse.
Adult owned (28yrs old), never raced, never dragged it, never rally raced it, never auto-cross raced, nothing. Just drive on the roads and freeway and thats it.
Warranty = still have 5yr/60k powertrain warranty, but also have Subaru Gold Plus extended warranty thats good for 4yr/60k miles, with $100 deductible I think. Hopefully they dont give me any problems, I may just not give back their loaner
I've had it dealer maintained for the majority of its life, but have done the previous oil change or two at home due to cost and wanting to do some of the work on the car myself. I know it needs an oil change currently and needs the air filter changed, it also needs front brakes. I have all these parts sitting at home in my garage ready to go, but I put the install on hold due to the problems with the car. Hopefully this wont be a problem.
Car started making noises getting into boost around 2,500 to 3,000 RPM, and overall didnt have all of its power. Metallic rubbing noise as RPM increased and lack of power, noise got worse and eventually was a clanking clanking noise as RPM's neared 2,000RPM. If I did my best to stay out of boost and shift at 2,000 RPM, the noise would be very quiet and not very loud. It eventually started making clanking clunking metallic rubbing noise that increased in pitch as RPM's increased shortly thereafter. Check engine light came on, Traction Control light is on, Cruise Control light is blinking (never seen this, usually its solid on if turned on, never any blinking) the BRAKE light is on constantly now (this is partly due to needin front pads on car, the light would come on then go off occasionally in the past few miles due to more brake fluid being used to push pads out farther due to pads being almost completly out and calipers needing to travel further), having trouble starting. When all the lights came on, it would have trouble staying running when first started. It would start, then die quickly. Only if I pushed the gas and revved it up a bit could I get it to start properly and stay idling just fine.
I'm not sure if its the engine having issues, or a turbo being blown. I am leading towards blown turbo. If you have any questions, please ask. I am here to help any way I can.
Thanks
EternalX is offline   Reply With Quote
Old 09-16-2011, 03:19 PM   #4860
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
A blown turbo wouldn't exhibit your symptoms. The car dieing, and all that metal on metal noises sounds like a popped engine. It's probably best to call your dealer and have them tow it in.
Do you have a lot of smoke out the exhaust? Does it make a noise off idle similar to other cars on youtube with spun bearings?
Old 09-16-2011, 03:25 PM   #4861
Quik265
Member#: 189662
2012 S4
Monsoon
^ I dont even understand the debate considering a) what year WRX you drive (2009) and b) the forum you're posting in - you spun a bearing and blew your engine like the hundreds of people before you that have posted in this thread. I am going to say your build date is 07/08 or 08/08.. drumroll please
Quik265 is offline   Reply With Quote
Old 09-18-2011, 12:57 AM   #4862
inf3cti0n
Member#: 280103
2012 STI Limited
Hello,
I have had my 09 hatch for a few months now and have been wanting to get a CBE. I have the Subaru Warranty and was wondering if any has ever been denied due to a CBE SPT or not. I had my eyes on a blitz / turbo xs / or greddy. Thank you in advance.
inf3cti0n is offline   Reply With Quote
Old 09-18-2011, 01:36 AM   #4863
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
^^ The important thing that they always will ask for is proof of oil changes at proper intervals. I doubt they could prove that an exhaust system affected the oiling system and caused a bearing failure. Of course, they can deny anything they want and then you'll have to take them to court if that ever happens.
Old 09-18-2011, 01:45 AM   #4864
inf3cti0n
Member#: 280103
2012 STI Limited
Hello,
I pulled a carfax today and ALL of the oil changes since the 1st owner bought it ( im the second) have been logged. If I was to go the "official route" they can't complaing about an SPT CBE installed at the dealership right? This would however increase the cost 2 times and less sexy boxer goodness.
Old 09-30-2011, 12:03 PM   #4865
chino_487
Member#: 209156
2009 WRX Sedan
SSM
Has there been a case (at least here on NASIOC) in which the mileage exceeded that of the power train warranty?
chino_487 is offline   Reply With Quote
Old 10-01-2011, 12:31 AM   #4866
snowskis
Member#: 222489
2009 WRX Hatch
Not that I'm aware of ...... yet. I think Witness above is one of the highest I've seen reported here.
Old 10-20-2011, 08:47 PM   #4867
lightgod86
Member#: 197343
2009 WRX Premium
WR Blue
Originally Posted by BIGSKYWRX View Post
^ youch
Bummed I never got an extended warranty. Mine just expired on Oct. 10th and now my Throwout bearing is starting to squeal again... Already on my 4th one! Clutch pedal is squeaking when depressed as well... I am soo going to miss my warranty
lightgod86 is offline   Reply With Quote
Old 10-21-2011, 12:27 AM   #4868
Breezio
Member#: 234357
2009 WRX
Prehaps there is a driving habit that's causing premature failure...
Old 10-21-2011, 04:00 AM   #4869
lightgod86
Member#: 197343
2009 WRX Premium
WR Blue
Well, I don't launch it, I don't track it, I don't burn it. I do sit in traffic occasionally and I drive it rather quickly when not. I pretty much always downshift, I suppose that could be something regular owners don't do??
Perhaps maybe I'm more sensitive to the noise, and others don't notice/care?
Perhaps, perhaps, perrrrhaps.
Old 10-21-2011, 10:18 AM   #4870
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
A *LOT* of 08+ WRX have noisy TOBs......I got to play with a noisy TOB out of an 08 and it felt smooth as can been despite the noise. I think they are just noisy. I think there are various sensitivity to car noises. Subarus tend to have lots of them .
Driving habits isn't going to mess with a TOB. Sitting in traffic for extended amounts of time with your clutch on the floor can, however.
Mine was noisy only when cold/humid in the morning and quickly fixes itself. I did 200+ 3-4k rpm clutch slip launches at autox during the time I owned it but other wise drove it like a grandma and my TOB was fine when I sold it.
09rexwagon is offline   Reply With Quote
Old 10-22-2011, 06:09 PM   #4871
Subirex09
Member#: 207880
2013 STi
Awesome SWP
Ha! Nice man, cake is my favorite band.
I just traded in my 09 for an 11 a couple months ago, and the tob is giving me the same trouble, to a slightly less degree as it used to in the 09. I have a long thread on here about it. I've learned to deal with it.
Subirex09 is offline   Reply With Quote
Old 10-23-2011, 10:59 PM   #4872
Breezio
Member#: 234357
2009 WRX
Well, none of those things you listed cause throw out bearings to get noisy and fail prematurely.
Leaving your foot on the clutch pedal will however. Or sitting at lights with the clutch pedal depressed and the tranny not in gear.
Just a thought. I've put several hundereds of thousands of miles on vehicles with manual trannies and never had a throwout go before the clutch needed to be replaced.
Maybe I'm just lucky... only have 30K on the 09' wrx...
Old 10-25-2011, 05:23 PM   #4873
Subirex09
Member#: 207880
2013 STi
Awesome SWP
I wonder if that's why I always hear my tob making noise on cold mornings and have the issues I do with the clutch pedal tob vibrations...I almost always leave the foot on the clutch at lights and not in gear.
Old 10-25-2011, 05:38 PM   #4874
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I wouldn't think resting your foot on the clutch pedal would do anything on a hydraulic clutch system. There's a little travel before the slave cylinder even begins to move.
Old 10-25-2011, 10:49 PM   #4875
Breezio
Member#: 234357
2009 WRX
Probably just depends on how much weight you put on it. I was under the impression it didn't take much to put pressure on the TOB.
After I made my last post I got to think. I think a couple times a heard a very quiet noise out of the TOB on my 09' on very cold mornings before things got fully warmed up.
2009 Impreza WRX Short Take Road Test: Faster to 60 than the STI CARandDRIVER NASIOC Official News, Articles and Polls 143 09-25-2010 05:14 AM
Official 2009 Impreza WRX - 265HP (Info & Pics) SOA Blog News & Rumors 3274 01-08-2009 08:20 PM
FS: 2009 Impreza WRX - wrecked/donor car - Perfect for swap - $8000 obo ProdriveRex Private Vehicle 'For Sale' Classifieds 51 01-05-2009 01:53 PM
2002 wrx motor issue??? AWD0425 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 11-13-2008 04:46 PM
2009 Impreza WRX PBB (Unofficial Pandog Bluebook/Buyer's Guide) Pandog24 News & Rumors 95 11-02-2008 04:48 PM
