Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 11-29-2008, 03:37 AM   #1
greenshoes3
Member#: 164049
MBP stg2 dom tuned
Default Need a track setup for my 2002 wrx
I need new wheels/tires and want the most cost effective setup as possible. I know very little about the tire and wheel side of suspension so please advise me for what would be best for my car for a reasonable amount of money. I do about 3-4 track days a year. 17" 18"? 225/45's? Please help!
Will rotas survive track usage? I hear they can fall apart, but this is usually from people that have 0 track experience so I don't know what to believe.
This is what I have so far for suspension setup.
KYB adjustable struts
Prodrive lowering springs
Perrin solid front and rear endlinks
Front and rear strut braces
I will have sway bars by the time track season starts up
greenshoes3 is offline   Reply With Quote
Old 11-29-2008, 11:01 AM   #2
BillJC
Member#: 31002
Go with Rotas. You will be fine. I've been using them for years. Plus, if one gets damage, it will be easier and much less expensive to replace.
Bill
BillJC is offline   Reply With Quote
Old 11-29-2008, 05:05 PM   #3
Uncle Scotty
Visiting NASIOC Timeout
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I would use a 17x8 or 17x8.5
a 245/40 should fit without rubbing(much)...those Prodrive springs are 'street' springs and are a bit soft for 'track'...with a bit of a roll and camber bolts a 255/40 should fit
consider stiffer springs...and dspec shocks in the future as an upgrade
Old 11-29-2008, 05:19 PM   #4
Daishi00
Member#: 78952
2005 WRX
CGM
The new Rota DPT wheels are 17x9 and come in at $850 a set, and they'll clear pretty much everything but a 355mm BBK, which is is nice if you decide to go to a larger brake kit later in life. Otherwise a nice 17x8" set can be had for $650. Plenty of guys track Rota's without issue.
As US said your springs are not the best for track, but to go to a stiffer spring you're really going to have to change out the struts as well. Not to expensive to do that though if you take your time researching.
With that said though any time on the track is worthwhile to improve your driving skills. Car is only part of the equation
Daishi00 is offline   Reply With Quote
Old 11-29-2008, 08:34 PM   #5
greenshoes3
Member#: 164049
MBP stg2 dom tuned
I actually have been running stock springs all year, so I don't even know what the prodrives will be like, I assume they will be an approvement. I got them for $50, so I hope the prodrive springs are worth at least $50 at the track compared to stock.
It sounds like I should be looking at a 17x8 with 225's? Is a wider tire always better? It seems like it might be less responsive. What should be my goal for tire width be in terms of not costing a fortune. I am lucky enough as it is to be able to hit the track while I'm in college.
Old 11-29-2008, 11:55 PM   #6
Daishi00
Member#: 78952
2005 WRX
CGM
A 235 or 245 on an 8" wheel is perfect. 225 is a little narrow on that width. The prodrives will be an improvement, but nothing huge.
Old 11-30-2008, 12:16 AM   #7
indolegend89
Member#: 139849
2011 STi
if you can you may be able to get a set of used 17x8 rpf1s for like 700 with tires. i use these on my 02 wrx and they were great at my last track day
indolegend89 is offline   Reply With Quote
Old 11-30-2008, 02:42 AM   #8
greenshoes3
Member#: 164049
MBP stg2 dom tuned
what size tires were you running?
Old 11-30-2008, 02:46 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
you could run 225/45 or 235/40 or 245/40 take you pick on od and availability not all tires will come in all sizes
Old 11-30-2008, 02:47 AM   #10
greenshoes3
Member#: 164049
MBP stg2 dom tuned
well what springs would be a better choice for 02-03 struts for track use? I couldn't even find another option. Please hurry and tell me before I put the prodrives on. I realize that coilovers or nicer struts would be better, but that isn't an option at this point.
Old 11-30-2008, 02:50 AM   #11
greenshoes3
Member#: 164049
MBP stg2 dom tuned
But there has to be a size that will perform best on an 8" wide wheel, that is what I am trying to understand. I thought that if you go too wide with a tire on a wheel that isn't wide enough, the sidewalls would wear out super fast and it would yield bad performance
Old 11-30-2008, 02:56 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
oh boy
Old 11-30-2008, 02:57 AM   #13
greenshoes3
Member#: 164049
MBP stg2 dom tuned
oh boy
i'm just trying to learn dammit, whats the oh boy for? lol
Old 11-30-2008, 09:11 AM   #14
Daishi00
Member#: 78952
2005 WRX
CGM
the oh boy is because we keep telling you that a 235 or 245 is FINE on an 8 inch wheel. A 255 is when you start getting wide. Have you read the stickies at all? Also look in the motorsports forum for the wide tire talk thread.
Old 12-01-2008, 08:35 PM   #15
HYPHYmoment
Member#: 178234
Fail POS 5x100
WFC #035
buy some coilovers noob.
HYPHYmoment is offline   Reply With Quote
Old 12-01-2008, 09:51 PM   #16
flukewrx
Member#: 75081
2003 WRX
Buying coilovers is a VERY Vague statement. You could spend $1K to get a set of springs & struts that could match or outperform coilovers in the same price range. It is ENTIRELY dependent on WHAT the goals of the car & driver actually are. There are quite a few people that think that they HAVE to get coilovers when in fact that is just not true. Remember that coilovers are a lot more involved & don't tend to last as long as a spring & strut setup. Yes you have the variability options available with the coilovers, but I would not be surprised if MOST street driven coilovers are simply thrown on the car and never really touched or properly adjusted. Also what works well for a setup for 1 car may not be a very good setup for another as different cars behave differently & different driving styles can DEFINITELY affect the way the car should be setup.
flukewrx is offline   Reply With Quote
Old 12-01-2008, 09:59 PM   #17
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
I have some 17x8.5 Rota Slipstreams with some 255/40/17 RT615 tires if you are interested. I was going to use it for next years season but I think I am going a different route!
And over all, you are going to be looking for a light wheel that will get over your brakes. The tire is what is more important!
gr8r rex is offline   Reply With Quote
Old 12-01-2008, 11:59 PM   #18
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
If you are looking for a cost effective setup I highly recommend Rota wheels. The new Rota DPT is very popular for track/autoX due to the nice size/fitment, low wheel weight, and affordable price. For aggressive street/track driving these wheels come in a 17x9 +42 fitment for Suby's. With this wheel you can easily run a 245/40/17 tire (only requires rear rolled fenders) and it will perform very well. I run this setup on my car right now with 245/40/17 Bridgestone RE-01R's and it's a blast to drive.
17x9 +42 5x100/114.3 (dual drill), only 18.9 lbs.
-Dan
suby_dude is offline   Reply With Quote
Old 12-02-2008, 01:31 AM   #19
HYPHYmoment
Member#: 178234
Fail POS 5x100
WFC #035
this guy.
Old 12-02-2008, 02:47 AM   #20
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
very true - though I disagree slightly: if you're blindly slapping on coilovers it's ok, just make sure to consult a knowledgeable track guy (this is where mechanics who also track their cars are golden), and have your mechanic/track guy tune it for your liking.
verc is offline   Reply With Quote
i need an glove box for my 2002 wrx bad.... jettashowoff NESIC Private Classifieds 2 05-29-2010 09:10 PM
NEED parts for my 2002 WRX wagon!!..anyone?...buhler? thomascrown Private 'Wanted' Classifieds 3 10-09-2009 04:25 PM
i need a ECU for my 2002 wrx M/T turbo wrxmatt02 Private 'Wanted' Classifieds 2 03-25-2009 06:59 PM
i need a ECU for my 2002 wrx M/T turbo wrxmatt02 Private 'Wanted' Classifieds 3 03-18-2009 02:11 AM
Looking for Prodrive WR Sport exhaust for MY 2002 WRX PARAMEDIC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-31-2002 12:24 PM
