Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 11-29-2008, 12:29 AM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default How Do You Fix an Exhaust Leak
No, really
OK, so the two new pieces of my exhaust are supposed to meet at a flat mating surface (like the stock midpipe to axleback joint). However, because it's cheap Chinese crap, the flanges aren't flat. They're flat on the short axis, but on the long axis, they're higher in the middle than at the edges. So when you actually try to bolt up the pieces, they meet in the middle but have gaps at both bolt holes. I used a thick waffle-board style gasket to try to account for the mismatch. However, it's not enough and the exhaust is leaking.
So what do you do when a gasket is not enough to seal up a bad joint?
Old 11-29-2008, 06:47 AM   #2
mikeythejew
Member#: 141672
Just take it to buckeye brake and muffler on karl RD. They are good at these kinds of things.
mikeythejew is offline   Reply With Quote
Old 11-29-2008, 12:59 PM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I do all the work on my car. I won't pay someone to do something I can do myself.
Old 11-29-2008, 01:22 PM   #4
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
fwiw I had the same issue at a turbo-to-downpipe flange - I put it back together with a stock gasket + bead of Permatex Copper (following the instructions carefully i.e. finger tight / cure overnight / torque down) and it has been fine for 3-4 years - even though it's only rated to 700F intermittent - I'd think it's worth a shot since your temps should be lower at the midpipe
UkNuck is offline   Reply With Quote
Old 11-29-2008, 01:25 PM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That's the high-temp coppper RTV gasket material you're talking about, right? Kind of looks like orange silicone caulking?
Someone left a tube of that here. The instructions are all gunked over though. Do you torque the bolts down before or after you let the stuff cure overnight?
Old 11-29-2008, 01:39 PM   #6
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
http://www.permatex.com/documents/td...tive/81878.pdf
looks like I was wrong about initial 'finger tight' - it says to torque to spec right away
although on the back of the tube I have it says "Do not squeeze out silicone by overtightening bolts. Dries in 1hr, fully cures in 24hrs."
Old 11-29-2008, 04:14 PM   #7
WeldingHank
Member#: 98645
2002 WRX Wagon
use the copper RTV and let it set about 30-40 mins after you torque it. I was using that for a while to seal my donut flange cat-back to my flat-flange DP. it works wonders till i found a donut gasket to stick in there and not restrict my exhaust.
WeldingHank is offline   Reply With Quote
Old 11-29-2008, 05:40 PM   #8
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
clean all the surfaces with some acetone...let dry....use that gasket goop....do it before you need to drive the car for at least 18 hours if possible...longer is good
it should cure your leak
the only way to make that fit better is to take it off and cold work it back flat....if you dont know how to do this, you may make it worse
I Need a shop in the nova area to fix an exhaust leak 15secWRX Mid Atlantic Impreza Club -- MAIC 6 10-17-2008 11:03 AM
How do you clean an exhaust? wrxSIN Newbies & FAQs 39 04-19-2008 04:35 PM
How do you find an exhaust leak? nich0lai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-08-2007 03:39 PM
do I have an exhaust leak? sc00bywagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-24-2005 02:50 AM
How do you know if you have an exhaust leak? dman918 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-06-2002 04:51 PM
