Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 11-29-2008, 03:14 PM   #1
operating engineer
Member#: 62893
2008 STi
Default wheel spacer in "A Stock"
I plan on running 3mm spacers on the rim for autoX . Does it have to be hubcentric to be safe?
operating engineer is offline   Reply With Quote
Old 11-29-2008, 03:21 PM   #2
RS drifter
Member#: 7891
2005 wrx STI
Aspen MF white!
as a precaution sure. it takes a lot of the load off the wheel studs,
RS drifter is offline   Reply With Quote
Old 11-29-2008, 03:51 PM   #3
Davidss
Member#: 27446
No, cheap spacers are fine. However, I would recommend longer wheel studs.
Davidss is offline   Reply With Quote
Old 11-29-2008, 05:12 PM   #4
operating engineer
Member#: 62893
2008 STi
where can I purchase some hubcentric spacers? i assume they will be custom. Know the spec I need? i think the Hub Size is 56.15 mm.
Old 11-29-2008, 05:36 PM   #5
dunk
Member#: 15359
You don't need hubcentric spacers. Just tighten your lugs properly and you'll be fine. If you're running a 3mm spacer it's likely that the wheel sits on the hub properly even with the spacer.
Duncan
dunk is offline   Reply With Quote
Old 11-29-2008, 07:08 PM   #6
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Like Duncan said, the wheel will still sit on the hub even with the 3mm spacer (it does for me)
pignoseSTI is offline   Reply With Quote
where to get wheel spacers in chitown? staticfritz Mid West Subaru Owners Club Forum -- MWSOC 14 04-12-2010 07:17 AM
08 Sti "A Stock" strut and sway bar option? operating engineer Motorsports 2 11-02-2008 09:35 PM
Question: Wheel spacers in NC Clark Kent Mid Atlantic Impreza Club -- MAIC 1 03-26-2008 08:57 PM
Tampa area: Wheel spacers, in stock? Today? jblaine South East Region Forum 3 02-04-2008 02:40 PM
Wheel spacers in 5x100mm??? Tony Technical Forum Archive 4 05-11-2000 04:45 AM
