Old 03-27-2002, 09:09 AM   #1
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Question Acceleration noise
This was mentioned slightly in the Newbies forum, but since there were no real answers, I figure I'd try in the appropriate forum.
When I accelerate in 2nd, 3rd, 4th, and 5th gear, between 2000-3500 RPM's, I hear rattling going on. I do hear the turbo spooling; along with the spooling is what seems like a loose screw rattling around/leaf flapping type of noise. If I accelerate quickly, the noise isn't noticeable - it's when I accelerate aat ease when the sound is most prevalent. Is this sound normal for a turbo'd car or should I bring this to attention at my local Subie dealer?
Hank3 is offline   Reply With Quote
Old 03-27-2002, 01:53 PM   #2
fpa1974
Member#: 15371
2002 WRX Sedan(gone)
Pearl Blue
This is identical to what I have. I mean point to point. You probably did a better job describing it than I could have done it myself. Anyway I talked to my dealer about this and they said that probably the heatshields are to blame. So I will have them check this when I have it in service for the clutch replacement (that will fix the deceleration noise).
But this noise is not normal. It should not be there on a brand new car no matter how you look at it.
Florian
fpa1974 is offline   Reply With Quote
Old 03-27-2002, 01:54 PM   #3
fpa1974
Member#: 15371
Pearl Blue
Sorry for the double post. Browser problems...
Old 03-27-2002, 02:29 PM   #4
Hank3
Member#: 16157
'03 Mazda P5 <><
Thanks for the response Florian - good to know that I'm not the only one. When are you having your car serviced? I'm going in at 1000 miles to get me a Subaru Oil filter (currently at 615 miles) and while I'm doing that, I'll have a service tech ride along with me to listen for the "Clutch Deceleration" problem and this rattling problem we have (hopefully you've pinpointed correctly cause that's what I'll mention ). Let me know what you find out and I'll do so also.
Old 03-27-2002, 10:57 PM   #5
push2
Member#: 6531
Is your noise coming from engine bay or under your shifter? I just installed an HKS exhaust and the rattling seems to be coming from the flex joint area on the piping... It happens around 3k-4k while cruzing and goes away at WHOT. Ive checked the all my connections and everything is tight so I guess I'll check out the heat sheild theory...
push2 is offline   Reply With Quote
Old 03-27-2002, 11:57 PM   #6
fpa1974
Member#: 15371
Pearl Blue
In my case is clearly the engine bay (right side, turbo area). At least this is where I think is coming from...
Florian
Old 03-28-2002, 01:13 AM   #7
opusx
Member#: 16807
Hank,
Your heatshield is no longer there. When the dealer installed your turbo back exhaust, they removed it.
opusx is offline   Reply With Quote
Old 03-28-2002, 05:39 PM   #8
Hank3
Member#: 16157
'03 Mazda P5 <><
hmmm...then I wonder what it is then. The noise does not sound normal. We'll see what the tech says when I take him for a ride-a-long.
Old 04-13-2002, 02:17 AM   #9
TML
Member#: 16188
any new updates on this? i have the same noise and the mechanic ordered two new heat shields for me. I hope this fixes it.
TML is offline   Reply With Quote
Old 04-13-2002, 10:24 AM   #10
Drexel
Member#: 16566
2008 G35
Liquid Platinum
Default noise
Unfortunately i dont think it will! Mine has had that noise since i got it and its still there now. I have had it in numerous times to two differnt dealerships. Theyve changed a LOT of stuff under hood. I really think its a clutch/trannie issue. The wierd thing is, that as time goes on, about 6,000 miles now, the rattle is a lot less now!? It will only do it occasionally and it is not nearly as loud as it used to be?? Im still searching though!!
Drexel
Drexel is offline   Reply With Quote
Crude Transmission Deceleration and Acceleration Noise after Clutch/Flywheel Install caterpill Transmission (AT/MT) & Driveline 271 05-20-2015 05:36 AM
Strange noise when slowing down? arrrwhyy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-07-2010 09:26 PM
Acceleration pull to the right?? scrappydoo7 Brakes, Steering & Suspension 3 06-01-2010 10:57 AM
Hard acceleration noises in '04 STi kangaroo128 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 06-21-2007 05:43 PM
Odd Acceleration noise subygirl Normally Aspirated Powertrain 5 09-26-2005 04:49 PM
