Old 11-29-2008, 07:33 PM   #1
97OBWagon
Member#: 43899
2005 Legacy OB Wagon
Atlantic Blue
Default P2009 CEL Tumble Generator Valve
I have a 2005 Outback Wagon 2.5L non-Turbo. A while back, I got a CEL. I read the code and it came back P2009 (Intake Manifold Runner Control (IMRC) Circuit Low (Bank 1)). I also notice that my fuel mileage and power have both diminished. Do you think it's a gummed up tumble generator valve (TGV)? Other people with TGV problems get CEL codes in addition to P2009, but I'm only getting a P2009 error.
I read a lot about the TGV and some posts say that I should clean it. Are there any directions on how to do this quickly or do I need to take the entire intake manifold off like in the TGV deletes procedure?
Dumb questions:
1) Which side is bank 1? Passenger or driver?
2) How do people get factory service manuals?
Any help would be appreciated! Thx!
Alan
97OBWagon is offline   Reply With Quote
Old 11-30-2008, 11:44 AM   #2
Tea cups
Member#: 103136
procedure for P2009 for your car:
STEP:
1 CHECK HARNESS BETWEEN ECM AND
TUMBLE GENERATOR VALVE ACTUATOR
CONNECTOR.
1) Turn the ignition switch to OFF.
2) Disconnect the connector from tumble generator
valve connector.
3) Measure the voltage between tumble generator
valve actuator and chassis ground.
Connector & terminal
(E51) No. 1 (+) Chassis ground (��):
(E51) No. 2 (+) Chassis ground (��):
CHECK
Is the measured value less
than 5 V?
YES
Replace the tumble
generator valve
actuator. <Ref. to
FU(H4SO U5)-31,
Tumble Generator
Valve Actuator.>
NO
Repair the battery
short circuit
between ECM and
tumble generator
valve actuator.
Tea cups is offline   Reply With Quote
Old 12-02-2008, 12:06 PM   #3
97OBWagon
Member#: 43899
Atlantic Blue
Default Thanks
Thanks, Tea Cup! I'll give it a try.
Old 12-22-2008, 04:30 PM   #4
lolsshea
Member#: 198161
Default Fix??
Hey - I ran across this thread today looking for answers to the same exact question. Just bought an 05 Outback and it threw the P2009 code this morning.
What was the result?? Did you get it sorted?? I haven't driven it enough to see any diminished power or mileage, but that could change.
lolsshea is offline   Reply With Quote
Old 12-29-2008, 07:31 PM   #5
97OBWagon
Member#: 43899
Atlantic Blue
Default No problems?
I couldn't find the problem so I took it to the dealer today. I had cleared the P2009 CEL in August 2008 and no new codes have materialized since then. I still have decreased gas mileage (currently getting ~17mpg from non-turbo, 2.5L in city), low power, and intermittent rough idle. The dealer couldn't find anything wrong.
CEL Code: P1090 Tumble generator valve #1 (RH) malfunction (stuck open) 4sworks Newbies & FAQs 7 11-14-2016 09:59 PM
Tumble generator valve CEL TyranosaurusWRX Newbies & FAQs 11 08-09-2010 09:46 PM
Help ... CEL 1086 re: Tumble Generator Valve Actuator lupohki Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 05-20-2005 08:14 AM
Tumble Generation Valve Info Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-21-2002 04:24 AM
Check engine. Tumble generator valve EPD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-12-2001 12:47 PM
