Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 11-29-2008, 07:20 PM   #1
Blase
Member#: 54702
2000 impreza 2.5rs
brp
Default PnP question?
I just a general question about porting and polishing things like throttle bodies. What happens to the plate that's inside? If the diameter inside the cylinder is getting bigger, is the plate inside replaced to fit the bigger hole or is it used as is and just lets air through? Just wondering yano?
Blase is offline   Reply With Quote
Old 11-29-2008, 10:11 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Most times, when people refer to "porting" the TB, they just taper the inlet area up to the plate and polish it real nice. To actually take the ID out further, you have to make a new throttle plate to fit it.
Hope this helps,
Jay
Old 11-30-2008, 12:07 AM   #3
Forester_007
Member#: 87139
2003 Forester XS
JBP
Yeah just replace the plate for a bigger one or get one custom made.
Forester_007 is offline   Reply With Quote
Old 11-30-2008, 05:39 PM   #4
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
GrimmSpeed does TB PnP. They'll do a thermal coating too.
Counterfit is offline   Reply With Quote
Old 11-30-2008, 08:01 PM   #5
decke48
Member#: 178804
1998 lgt
TWE does boring for TB and Optimizing. optimizing flow 40cfm better, boring 70cfm better over stock 435cfm
TWE services
decke48 is offline   Reply With Quote
Old 12-01-2008, 01:41 PM   #6
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
The throttle body is a very important part of the intake system and can easily be damaged if not ported correctly. We do offer a porting service at our shop as well as ceramic barrier coating and thermal dispersent coating.
Here is a link to our port work for a WRX DBW throttle body. http://www.grimmspeed.com/catalog/pr...products_id=47
If this is something you would be interested in feel free to shoot us a PM or email us at sales@grimmspeed.com
Mike
GrimmSpeed is offline   Reply With Quote
Old 12-02-2008, 01:22 PM   #7
Blase
Member#: 54702
2000 impreza 2.5rs
brp
Well, this is something I wont be doing for a while. I've been unemployed since september. The reason i started this thread, though, was because I'd eventually like to send it over to grimmspeed and get it done. The only question is when. thanks for chimming in guys.
Old 12-02-2008, 03:33 PM   #8
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Not a problem were ready when ever you are
To kind of go back and answer your second question we dont port the area where the valve reaches the cyliner wall. We port everything diretctly up until that point to insure that the valve is sealing as well as stock.
Mike
Old 12-02-2008, 03:57 PM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
here's when I did mine when I was N/A:
http://sl-i.net/FORUM/viewtopic.php?f=11&t=8093
The last pic didnt' show when I polished up the walls and knife-edged the tb plate though.
Pnp is pretty simple, start with carbide bits to start cutting away material, then sanding drums (60-80g) then flapwheel (120g), then cross buffs to smooth it out, finish off with polishing compound. The TB is made of aluminum so it doesn't take a lot of force to cut away at the metal. Just go slow, take your time, and always take time to feel the surface youre working on to make sure its even. The TB was my first try at Pnp, I say if you have the time, it's a good learning experience (and cheap mod).
My goal was to smooth out the intake tract and to create a velocity-stack effect as air enters the TB lip and into the manifold, not necessarily to just make the whole opening bigger (even with the right sized plate you may be doing more harm than good as the EM is calibrated to a certain diameter in the intake piping most of the time...it's like changing the diameter of your MAF tube).
rougeben83 is offline   Reply With Quote
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 02:32 PM
pnp question alwu Newbies & FAQs 8 06-13-2009 12:15 PM
TD04 PnP Question Tut4u2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-24-2009 06:39 PM
Question on PnP stock turbo Nettalp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-05-2006 03:31 PM
Got XEDE PnP harness, now a couple questions about it. djoye Engine Management & Tuning 1 07-24-2004 10:00 AM
