Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 11-29-2008, 09:22 PM   #1
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Default Opinions Wanted: Bilstein PSS9 Coilovers for Street Touring Autox and Some Track
Hey Guys,
What are your opinions on the Bilstein PSS9 coilovers? The car is a street car but I plan on running many autox's next year (regional and national) in STU class.
I have never really heard anyone run these in ST* class (except at the El Toro ProSolo where an EVO won the super challenge but didn't really pax so well in regular competition) and didn't find anything in the motorsports topics when I searched.
Do you suspension gurus believe in Bilstein?
The set I found for sale comes with 300/250 spring rates. These seem too soft for autox. Do you think the adjustability will be suitable for higher rates without a revalve? Where do you think I should go with the sping rates on these?
These are single adjustable with adjustments changing both compression and rebound. Is that a serious compromise?
Thanks!
S1MPSONS is offline   Reply With Quote
Old 11-29-2008, 09:41 PM   #2
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Please call the Bilstein office in San Diego / Poway and ask to talk with Bret Norgaard. He has developed the PSS9 and newer (and much better) PSS10 applications for autocross Subarus, from the GC chassis and earlier WRX sedan and beyond. This is from a product engineer and top-level National caliber autocrosser, so I would listen to what he tells you to do
The spring rates change, as does the valving as I recall, neither the 9 or 10 were particularly great about anything other than the Bilstein build quality and quick turn-around time for service work. He's got everything logged and worked out already, so just call him with your setup and he can lay a great baseline for you.
IIRC, revalves are only $65/each and includes shock dyno time, and they are VERY fast, in some cases just days, if they are not busy. I think Dyno alone is only $25, still a fantastic value.
JamesWilson is offline   Reply With Quote
Old 11-29-2008, 09:44 PM   #3
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Thanks for the contact. I will surely reach our to Bret.
FWIW Their website says $125 per adjustable shock for a revalve.
Old 11-29-2008, 09:46 PM   #4
JamesWilson
Member#: 124833
2000 Legacy Wagon
Oops, then the $65 may have been for the non-adjustable Monotube....to be honest I have never used their adjustables, only raced on them in other people's cars I don't like turning knobs, only steering wheels, when things need to be "adjusted" (read: revalve and forget).
Old 11-29-2008, 09:53 PM   #5
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Do I read this as, "Bilsteins valving is not particularly great." ?
From what I've heard, they are one of the few firms whose tolerances are actually respectable by motorsports standards.
I guess I need to dyno the shocks and judge for myself though. I am just basing that statement on something someone posted once online.
Old 11-29-2008, 10:01 PM   #6
JamesWilson
Member#: 124833
2000 Legacy Wagon
The off-the-shelf valving on the PSS9 and PSS10 is in no way to be misconstrued to be an autocross or race-specific valving. It is for "street use" and is definitely a compromise valving, what I have been told. That being said, for national-level autocrossing, it is highly recommended that it be revalved for such. That doesn't mean it won't be okay for 90% of people as it comes out of the box however, but YMMV.
As far a product quality etc etc etc I am hard-pressed to find an affordable European-based shock as good as the Bilsteins, I would put them in everything I own or have owned if they made them for them. I really would.
Old 11-30-2008, 12:40 AM   #7
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Originally Posted by S1MPSONS View Post
Hey Guys,
Stock, they sell with 300/250 spring rates. These seem too soft for autox. Do you think the adjustability will be suitable for higher rates without a revalve?
Thanks!
Are you thinking of these because of ride quality or budget or something else?
Old 11-30-2008, 01:03 AM   #8
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Because they are not Taiwanese garbage like a lot of the other stuff on the market. Ride quality and quality valving go hand and hand. You can have superior levels of grip from a coilover without sacrificing ride quality. I hope this coilover will provide both better ride quality and better grip than my current set up. Lastly, these are fairly reasonably priced when compared to other "euro" quality coilovers.
Look, I don't want to convince myself these are good. I would really like to hear from people who have experienced them personally.
JamesWilson, you said you have driven on a set of these. Later you endorsed them. What specifically about the ride/handling did you notice when driving on them?
Old 11-30-2008, 01:14 AM   #9
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
I have them they're great
They're very, very comfortable on the street. Definitely the best track prepared c/o if you're going to drive it on the street also (I live in downtown Washington DC)
Are you sure they're 300/250?
My PSS9's are 440/380 iirc, but I know the newer ones are softer. But still I remember they were like around 400 in the front now.
edit: can't find it but look into the spring rate... that really doesn't sound right
edit edit: here ya go via Z1automotive (where I bought mine heavily discounted. Adam = the man.)... "Spring rates are 400 lbs/inch front, 285 lbs/inch rear."
silverF4turbo is offline   Reply With Quote
Old 11-30-2008, 12:31 PM   #10
douthinkicare
Member#: 169054
2002 WRX vf22
white
I also have them on the street they keep the wife from complain too much, quality is top notch i just need to grow a set and start playing with the nobs or find a a guru to school me up some day. I am only 15 min from poway hmm... lol
douthinkicare is offline   Reply With Quote
Old 11-30-2008, 12:48 PM   #11
Daishi00
Member#: 78952
2005 WRX
CGM
Although they are a capable street coilover if you're planning on doing track/auto-x and are set on coilover options I'd look at either RCE T2's or the TIC AST units. More spring options with a great range of adjustability to compensate.
Daishi00 is offline   Reply With Quote
Old 11-30-2008, 12:54 PM   #12
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Why???? Objectively what makes them more autox track capable.
Fwiw I have looked at them.
Old 11-30-2008, 01:08 PM   #13
Daishi00
Member#: 78952
2005 WRX
CGM
TIC AST's have serious stroke, custom valved and matched to Swift Springs (I believe linear rates as well), and are a nice single adjustable (12 adjustment points) unit. Lot's of R&D went into them that's for sure.
RCE T2's are independent rebound/compression adjustable (near infinite adjustments as no set adjustment points within the range), SS body for corrosion resistance, linear spring rates, multiple spring rate options, custom valved which results in excellent street riding and track/auto-x settings etc... Myles and his crew did a great job on designing these units, which is nice with the limited lifetime warranty.
The PSS9's are progressive spring rates, single adjustable (9 settings) units that are MSRP more expensive than both the T2's and the TIC units. They're good units, very good for street and decent for tracking/auto-x, but I'd go with one of the other units due to the extra features based on price points as well.
Old 11-30-2008, 01:13 PM   #14
Daishi00
Member#: 78952
2005 WRX
CGM
Also, because I know ButtDyno is going to ask, have you considered a good strut/spring combination as well?
Old 11-30-2008, 01:18 PM   #15
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
I have considered just about everything over the past year of so.
Old 11-30-2008, 01:41 PM   #16
Daishi00
Member#: 78952
2005 WRX
CGM
So, why don't you tell us why you've singled out the Bilsteins? Easier to agree/disagree with your reasoning when we know what it is
Old 11-30-2008, 02:03 PM   #17
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
I found a set used for sale. Much more affordable then new TIC or RCE or Ohlins or KW.
Old 11-30-2008, 02:13 PM   #18
Daishi00
Member#: 78952
2005 WRX
CGM
So it sounds like you've made your decision.
Old 11-30-2008, 02:19 PM   #19
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
I'm still on the fence.
Old 11-30-2008, 02:42 PM   #20
Butt Dyno
Member#: 17301
is the "dark side"
I would definitely get in touch with them first and tell them your intentions as far as revalving goes. You're going to run stiffer springs, right? By the time you factor the cost of upgrading the PSS9's in, you might be near the cost of the TiC/AST/KW/RCE stuff.
Oh yeah, and I still love my Koni/GC setup
Old 11-30-2008, 03:06 PM   #21
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
I see this situation all the time. Its normal for the OP to have a "favorite" choice. Many things can contribute to his or her wanting his favorite. But.I say to the Op: get the Bilsteins, run them and work on driving. All the choices are good, so you cant loose. I personally have had Bilsteins on all of about 15 cars in the last 20 years, except my old 280Z from the mid eighties. Anyway..get the Bilsteins and focus on all the other things you have on your plate like driving, tires, pressure, courses, rules etc. Biggest factor will always be ...YOU.
Lets not obsess over the details. Good drivers are fast no matter what the shock.
So here again....GET THE BILLIES and call it a day. You wont be dissapointed.
Myles
RaceComp Engineering is offline   Reply With Quote
Old 11-30-2008, 03:23 PM   #22
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
This is really what I don't want to happen with a used set. In addition to the money, there will be much more time and effort into piecing these together and shipping them out and waiting for revalving.
Old 11-30-2008, 03:42 PM   #23
Chiketkd
Member#: 71634
In hibernation...
+12345 Myles is on the money. You can have the best set-up in the world, but at the end of the day you gotta drive.
Chiketkd is offline   Reply With Quote
Old 11-30-2008, 03:46 PM   #24
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Unfortunately, that statement isn't entirely true. I've hit a brick wall with the capabilities of my stock STi shocks. I was fast all year, even trophied in STU at a ProSolo and a National Tour event on the stock shocks, but they are just not fast enough.
Old 11-30-2008, 03:50 PM   #25
Daishi00
Member#: 78952
2005 WRX
CGM
Ok, so what's the price on the Bilstein deal you're looking at? Does it include tophats/camber plates? Total rebuild costs (shipping etc)? Easy to see how much money you're truly saving.
NYC / NJ : Bilstein PSS9 Coilovers for WRX or '04 STi sleepyS14 Suspension/Brakes/Handling 23 04-29-2009 11:30 PM
WTB: Bilstein PSS9 Coilovers for 05-07 STi WRXPCT04 Private 'Wanted' Classifieds 2 01-16-2008 08:17 PM
FS: OR-Portland: Bilstein PSS9 Coilovers for 05-07 STI Rootus Suspension/Brakes/Handling 7 11-18-2007 11:26 PM
FS: OR-Portland: Bilstein PSS9 Coilovers for 05-07 STI Rootus NWIC Private Classifieds 9 11-18-2007 11:25 PM
Bilstein PSS9 Coilovers for 05-07 STi Rootus NWIC Private Classifieds 24 10-08-2007 05:11 PM
