![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 148597
Vehicle:00 GDA Jet Black 04 GGA PSM 10 SH5 XT |
Looking into stuffing 255s up front and either 235s or 225s in the rear, has anybody run this setup for a while and have some issues to report? i know there is a bit of size difference between them but im looking more for traction in cornering on circuit/time attack. comparing front and rear tire temps on 225s all around fronts heat up much more and cause more understeer. any feedback would be appreciated. before anybody says it i know about differential problems could arise but not high on my priority list. thanks
Jarrett
#2 |
Member#: 55252
SCIC
Vehicle:* pullup bar * |
tires should all be the same size
#3 |
Member#: 137398
E. Canada
Vehicle:2004 Impreza 2.5RS Platinum Silver Metallic |
If you were FWD or RWD then go staggered but AWD...all wheels, should be the same size with the same size tires.
#4 |
Member#: 88005
Vehicle:2002 WRX PSM GS500 |
Your center diff would not like that...if anything run slightly wider rims in the front with the same size tires.
#5 |
Member#: 148597
i understand running the same size tires, i plan on running the same tires all around for normal day to day driving but on the track stagered might be better for me for hard cornering and faster speeds through corners. this is not for drag or autocross use.
#6 |
Member#: 88005
I would think that there are much better ways to counter understeer. I have never seen or heard of a AWD car using bigger tires up front for a track. Tens of thousands of AWD cars are raced and I'm guessing that there is a reason why people don't do that. 235/45/17 would probably be tall enough to cause the center diff to overheat and lockup.
#7 |
Member#: 148597
yes, i could install a front diff, but the cost of the diff, plus install probably around 1500-2000 dollars.
#8 |
Member#: 39086
Vehicle:2004 STi White |
An inexpensive way to kill a little understeer is to use some small front wheel spacers to pooch out the track. Don't put them on the rear. That way you don't have to deal with two sizes and you can rotate your tyres for wear.
When I say small spacers I mean 3-5 mm with longer wheel studs all the time. For track use only you could get away with much thicker spacers. Big spacers are hell on wheel bearings running straight down the road, but when you vector in the cornering component, the forces are more balanced. Let your conscience be your guide. (I'm not being hypocritical. It is a matter of applications. Parts for the track are not just for "looks".) |
#9 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, '11 A4 Crystal Gray, Silver |
Run the same size tires all around. Use driver technique, suspension tuning, and alignment to reduce understeer.
I run 255/40-17 R888's, 500/400 RCE T2's, Whiteline swaybars 27-29 Front (set on softer setting) & 24-26 rear (set on stiffest setting), Kartboy F&R endlinks, and an alignment at -3 front camber with 1/16 toe out & -1.5 rear camber with 0 toe. Car handles phenomally on the track. It's a little tail happy if anything. |
#10 |
Member#: 148597
finally a little decent feedback, I am already running spacers, 7mm front and 3 mm rear it helped a little but not exactly what im looking for. when i say im getting understeer im not just saying it because it feels like it pushes a little, the reason im looking into this is to get that last bit out of the car before she pushes through or breaks loose. i would love to go 255 all around but im just worried for fittament in the rear. and when it comes to tires im cheap, i use re070s because i can get them cheap and im working on getting some 255 070s but they usually only come up in pairs. here is my current setup.
Camber -2.5 (3-3.5 for track)front and -2.5 rear Caster 4 Toe front 0 rear 0 DMS 40mm Gold DMS adjustable camber plates helix 21mm FSB Hotchkis 25mm RSB Hotchkis rear endlinks Cusco Trailing arms Cusco Latteral Links Aluminum control arms Urethane control arm bushings Cusco Front and rear strut bars 225 45 17 RE070 17x7.5 BBS RG-R and im waiting on the WL roll center kit to arrive. |
#11 |
Hoodbridge!
First thing I'd try is to take out some of the rear camber. Like I said, I run -1.5 in the rear.
Running different size tires really isn't an option. |
#12 |
Member#: 148597
but think about it
255 40 17 overall diameter 635.76mm 225 45 17 overall diameter 634.23mm with the difference in overall diameter being 1.53mm its like having having 2 brand new tires and 2 used tires with 5000 miles on them. i would think that is still the the tolerance for the center diff. even taking into account drag from the wider front tire i think that it would be less of an impact as say a front lsd compared to wider tires and front open diff. |
#13 | |
Member#: 102027
SCIC
Vehicle:BugI Tsx retro lamps for sale not listed pm me |
Also, when people talk about running wider wheels in front, you can use the same size tires all around, but the wider front wheels will cause the tires to have a wider contact patch. You can also run lower offset wheels in front... |
#14 |
Member#: 89493
Vehicle:2001 Impreza 2.5RS Red |
I noticed you said you are running a 21mm front and 25 mm rear swaybar. From everything I have read here it seems you want a bigger front swaybar to increase front end grip. McPherson strut suspension gains camber as the suspension compresses reducing grip in corners, bigger swaybar would reduce roll which would reduce suspension compression therefore reducing the amount of camber you gain. I am not sure if this still holds true with stiff coilovers as opposed to something more stock but this is what I get from what other people have said. You should go to the suspension forum and read the stickies.
#15 | |
Member#: 39086
http://www.tirerack.com/tires/Spec.j...e1=yes&place=1 This has the true tyre sizes. Not calculated. http://www.tirerack.com/tires/tirete...currentpage=52 The wear allowance: "Subaru Within 1/4-inch of tire circumference or about 2/32-inch of each other in remaining tread depth. " |
#16 | |
Member#: 148597
i have actually seen this done before twice one on BOZZ Speeds 02 STI spec c and another 05 spec c but i dont speak japanese so it would have been difficult for me to ask questions about it. |
#17 | |
Member#: 148597
within 1/4inch is 6.35mm so it is well within the wear allowance. but there is nothing about different section widths. so say i bought 4 brand new tires, 255 40 17 re070s and 225 40 17 re070s and had them shaved to match exactly the same circumference. theoretically that would be well with in the 1/4 in tire circumference. |
#18 | |
Member#: 39086
The chart shows the two tyres within 0.1" OD. 4/32nds is the wear allowance on the OD. This says it's OK by 0.025", or less than 1/32nd". ![]() Pi*OD=C 3.14*24.9"=78.2" 3.14*25.0=78.5" Delta=0.3">1/4" Not quite within spec. ![]() I feel that your front tyre wear would get rid of that 0.050" difference pritty fast at the track. But it is just an opinion. You should see what my Victoracers look like. ![]() |
#19 |
Member#: 141040
Vehicle:07 2.5i wagon UGM |
Keep in mind that the tire sizes probably have a bit of a fudge factor, especially when considering that you may not be mounting them on the factory-spec wheel.
However, if the tires are shaved to match, i would think it'd work OK. I don't think it's a very good solution to your problem though. Not saying i know a better way, but it is a curious way to go about it. |
#20 |
Member#: 39086
Actually it's an elegant solution given the Subarus weight distribution. The down side, if the tyre OD's work out, is that us church mice can't rotate our tyres to equalize wear. Porsche did it with the 959, 235/45 fore and 255/40 aft, but that was a $225,000 homologation special 20 years ago.
For fun: http://auto.howstuffworks.com/porsche-959-history.htm |
#21 | |
Member#: 148597
#22 |
Member#: 194302
International
Vehicle:2007 wrx red |
HKS konsai run 255/40 on front and 225/45 on rear wheels GRB 2008
i dont understand it |
#23 | |
Member#: 148597
http://www.hkskansai.co.jp/democar/s...b_a/grb_a.html only real difference from my car i think is the DCCD transmission and front diff. there is a huge difference between the 265 35 18 and 245 40 18 that they are running. |
#24 |
Member#: 31345
Vehicle:05 LGT, GC8, NA blue, white, blue |
I know of some autoX subarus that run a wider front than rear.
you can run a wider tire as long as over alll dim. is the same as you guys know |
| Thread Tools | |
| Display Modes | |
| WTB: 225/45/17 or 235/45/17 or 245/40/17 | TestaRossa | SCIC Private Classifieds | 8 | 03-19-2010 12:11 AM |
| WTB: 714/626 area: 235/40/17 or 235/45/17 tires | crashtest sonny | SCIC Private Classifieds | 0 | 12-29-2009 02:37 PM |
| WTB: 235/40/17 or 235/45/17 tires | xblackdeathx | RMIC Private Classifieds | 9 | 05-07-2009 09:44 AM |
| 235-40-17 or 235-45-17 | pmatty | Tire & Wheel | 9 | 05-05-2008 10:47 PM |
| 235/40/17 or 235/45/17 | jblaine | Tire & Wheel | 6 | 05-24-2006 08:42 AM |
