Old 11-30-2008, 12:09 PM   #1
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
Default Power Steering Belt Tension
Living in New England and the cold weather has finally come for good. I noticed a few weeks ago on cold start ups the car squeaks pretty bad for a while until the car is warmed up. it never did this in the summer or when the weather was nice. It does it also when i turn the wheel left or right but after a while goes away (usually once car is fully warmed up) so im assuming the power steering belt is lose and i am going to check today. but my question is how do i know how much tension to put on the belt and not over tighten it. any input would be helpfull. thanks
BONFIRE074 is offline   Reply With Quote
Old 11-30-2008, 01:49 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The belt should deflect a small amount when you press on it with your thumb midway between the pullies. Too loose and it will slip and squeal, too tight and the pump and alternator bearings can be damaged. If the belt doesn't deflect at all when you press on it it's too tight.
Tightening Power steering belt & AC Belt dans04wrx Brakes, Steering & Suspension 8 01-21-2015 04:01 PM
Tension on power steering belt PHustle Newbies & FAQs 0 05-30-2007 09:12 AM
Timing belt and Power steering belt? Kopid Newbies & FAQs 15 02-06-2007 02:08 AM
need help on power steering belt. masube Legacy Forum 2 01-24-2005 11:43 AM
need help on power steering belt. masube Legacy Forum 3 11-28-2004 12:21 AM
