Old 11-30-2008, 02:48 PM   #1
xmoshx
Member#: 181952
1998 Outback Sport
Green/Black/Carbon Fiber
Exclamation Timing belt to long!
So doing head gaskets on my 99 legacy 2.5gt (ej25D).
Here is the problem I had the heads rebuild when they did that they also surfaced them did not get the specs on how much they took off.
Also I when with ej257 head gaskets, noticeably thinner than the ones i took off.
Get everything back together and makes this sound.
http://www.youtube.com/watch?v=7NVjR...eature=related
Don't think it is piston slap or rod knock beings how it is consistent and changes with rpms
Compression test was ~180 and about ~110 running.
took it all back apart and the timing belt is loose.
took the hyd ten off a ej205 that was laying around (the bracket too cause it has and extra idler on it) that took up some of the slack.
Noise quieted down as soon as the car warmed up(I would assume confirming that is is the hyd ten)
PROBLEM: The Timing belt is still loose!
i need a fix and fast anyone out here have any suggestions.
xmoshx is offline   Reply With Quote
Old 12-02-2008, 08:04 PM   #2
fornetti14
Member#: 103771
'00 Impreza 2.5RS
So what was it? If the timing belt came loose I'd be worried that the sound is the valves kissing the tops of the pistons. Were the valves adjusted after you picked it up at the machine shop? They may not have adjusted them. I noticed on my '99 Forester that the dealer, manual and hood sticker all had different valve clearances listed.
fornetti14 is offline   Reply With Quote
Parking Uphill Can Cause Timing Belt to Jump Teeth? Jon [in CT] Service & Maintenance 25 04-23-2012 11:55 PM
Do you have to remove the timing belt to change water pump? elsuicida Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-27-2009 03:24 AM
Timing belt too long? horf Service & Maintenance 8 03-07-2008 09:05 PM
How long for timing belt service? tommy2hotty Service & Maintenance 7 03-01-2006 07:36 PM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 06:33 PM
