Old 11-30-2008, 03:40 PM   #1
Bonjo2
Member#: 56521
2002 WRX Wagon
Default RallyAmerica Turbo Inlet and other Bits
Spent some time looking at the RallyAmerica and Subaru USA team site.. Wow, the usa thing is taking off--literally.
Can someone explain the mammouth sized turbo plumbing, esp the section prior from the I/C to the TB. Are most of the bits on the open cars now one-offs? The exhaust and intercooler setup something I think norms like us could benefit from--maybe in ST classes? Maybe some beefy susp arms now that everyone is trying to jump their subarus over mountains..
Happy Day. Thanks in advance.
Bonjo2 is offline   Reply With Quote
Old 12-01-2008, 02:26 PM   #2
Bonjo2
Member#: 56521
2002 WRX Wagon
http://rally.subaru.com/event_2008_lspr_gallery1.html
The photo in question is about 1/2 way down. One reply mentioned it being either a water cooler like some supercharged cars run, another theory is it is in some way part of the antilag. Anyone know for sure?
Old 12-01-2008, 02:57 PM   #3
delongedoug
Member#: 124113
and beyond!
Looks like insulation to me.
delongedoug is offline   Reply With Quote
Old 12-01-2008, 03:21 PM   #4
Tbagger
Member#: 122680
2006 STi Rally Car
I''ve seen this on mulitple WRC cars over the past 3 years. I never really asked or looked into it. They all seem to have that sized piping coming off the IC to TB.
Here's a shot of the '07 engine bay with the intake where the stock IC goes.
more of the '06 setup
Tbagger is offline   Reply With Quote
Old 12-01-2008, 05:28 PM   #5
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Not insulation, but a type of expansion chamber. Unsure of the physics/dynamics of it, but it may have to do with holding a large pressurized volume of air....instead of sucking through a straw with a ball inflation needle at the end, you get more "straw" volume, making the best of what is available? I dunno...that is my layman response. I know that they make expansion pipes like that for my wife's Saab turbo
JamesWilson is offline   Reply With Quote
Old 12-01-2008, 10:18 PM   #6
Bonjo2
Member#: 56521
2002 WRX Wagon
that sorta makes sense assuming they keep it pressurized with the ALS, it could keep pressure and allow super quick throttle response when back on the go button. But like you, layman's guess
Thanks for the better photos.
Old 12-01-2008, 10:24 PM   #7
Mechie3
Member#: 120152
What doesn't make sense to me is the sudden change in diameter as there is a loss (quantified by "k" in most fluid dynamics books) that results from sudden changes like that. Not only would the velocity slow because of the V1A1=V2A2 (regainable energy if A2 returns to being small) but the expansion losses.
I like bonjo's explanation of the overall system (or at least his guess of it, as it makes sense to me). If the system is always kept pressurized (or at least at 0 vacuum) then when you get on the throttle, you don't need to build boost from negative pressure or fill up a large volume first. By the time the turbo has fully spooled, you've ben able to pull from the reserve resevoir to get the first response.
The volume might also be tuned a bit to the dynamics of the turbo/engine.
Mechie3 is offline   Reply With Quote
Old 12-01-2008, 11:10 PM   #8
Web Foot STi
Member#: 39086
2004 STi
Remember, those engines have to breath through a 34mm restrictor. I don't know how the "big pipe" quite works, but they may be saving up pressureized air on corner entry, closed throttle (CT), and getting a bit of an extra boost on corner exit, WOT. Just a theory on my part.
Web Foot STi is offline   Reply With Quote
Old 12-02-2008, 10:24 AM   #9
LukeD
Member#: 90243
2002 V8 JDM STi wagn
flat black
send Rodney over at subaruwrcspares.com an email. We were looking at an ALS setup here at my shop that the wrc team uses. We though they were pulling air in through the intercooler...then up through the uppipe to keep the turbo spooling. Totally different system than the bang-bang ALS. Anyway's he sent me a very detailed response on how the subaru wrc ALS works with pictures and pricing. very informative.
LukeD is offline   Reply With Quote
Old 12-02-2008, 10:28 AM   #10
Mechie3
Member#: 120152
Please make a thread about this if you get a chance. The prodrive factory thread had some pics/info about this, but not much. You can definitely see the air bypass for the ALS on the hot side of the IC.
Old 12-02-2008, 01:04 PM   #11
Yotsuya
Member#: 935
Jack Soo Fan Club
Looks like it just increases the plenum, though I only really paid attention to the need for it back with the 98-01 RSs.
Yotsuya is offline   Reply With Quote
Old 12-02-2008, 05:38 PM   #12
speedblind
Member#: 42202
Makes sense. A few manufacturers are putting variable-length intake manifolds on production cars - Porsche comes to mind. The idea is that for high rpm and WOT conditions, you want a short as path as possible to the intake. For lower throttle/rpm conditions, having a longer path provides a greater overall volume of air "in reserve" in case you suddenly go WOT and need the air. Improves throttle response and low-end torque if you believe the marketing folks.
I'm guessing that the larger intake tubing basically provides the extra air necessary when going WOT.
speedblind is offline   Reply With Quote
Old 12-02-2008, 05:57 PM   #13
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
has anyone seen the inside of these pipes? maybe they're hiding something...
Old 12-02-2008, 06:06 PM   #14
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
I like it. Would be a great way to cheat. "Yea, we totally use that giant thing as an expansion chamber. There totally is not NOS in there, no way"
-Tom
trhoppe is offline   Reply With Quote
Old 12-02-2008, 06:26 PM   #15
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
My guess is that the chamber acts like another plenum...so when a driver goes off throttle into a corner and punches the gas...the chambers stores extra air for a faster transition back into the power band.
Similar to a throttle body spacer which adds volume to the intake plenum.
To be honest...at speed the air is moving so fast through those pipes that the change in size probably has little effect, or is out weighed by the extra benefit of the larger chamber
geddesk2 is offline   Reply With Quote
Old 12-02-2008, 06:27 PM   #16
Web Foot STi
Member#: 39086
2004 STi
Old 12-02-2008, 08:17 PM   #17
speedblind
Member#: 42202
Very cool link.
Old 12-05-2008, 05:24 AM   #18
Bonjo2
Member#: 56521
2002 WRX Wagon
Awesome stuff. Thanks.
FS Stock STI turbo inlet and new Samco turbo inlet grichardv8 Engine/Power/Exhaust 5 05-05-2013 11:00 AM
Post swap (exh+int) and other bits for sale greddy18 1993 - 2001 Impreza Specific Parts 17 08-13-2008 12:53 AM
FS: aps turbo inlet and other parts evoklr101 Engine/Power/Exhaust 6 09-27-2007 02:26 PM
Sti pistons, pan, RS short block, wrx turbo and other bits rst4me Engine/Power/Exhaust 48 03-20-2007 09:09 PM
FS: 5 spokes and other bits Panic NESIC Private Classifieds 1 12-12-2006 08:38 AM
