Old 12-01-2008, 01:18 AM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Results for a temporary NA build using STI pistons....
So until I get the turbo parts all lined out, intercooler sorted, yada yada yada, I am running my new motor NA.
Its an NA block with Mahle 100mm pistons (STI compression), 99 DOHC Legacy Subaru 3-ply metal head gaskets, earlier than 1997 twin turbo heads, unknown year 2.5 NA intake manifold.
Other than an irritating idle issue (likely a vacumn leak), the motor runs great! More torque and power than a 2.2. But how does it compare to a higher compression build? Not as good. But it still has enough torque to have fun with for the next 500 or so miles till I get the turbo stuff sorted.
Build thread here.
http://forums.nasioc.com/forums/show....php?t=1636451
Old 12-01-2008, 06:58 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
That's encouraging!
Jay
Old 12-01-2008, 09:46 AM   #3
soulhassorrow
Member#: 150732
2011 WRXXXX
LRP
you going to dyno that motor??i guessing you're not cause it'd be a waste to dyno before you put it all together, i just wonder how much difference those pistons make!@##@!
soulhassorrow is offline   Reply With Quote
Old 12-01-2008, 01:16 PM   #4
Back Road Runner
Member#: 60082
2004 Forester STI
Could even road dyno it with romraider and data log lab on the cheap (cost of a cable)
Old 12-01-2008, 01:18 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Can romraider talk to a 1990 Legacy ECU?
Old 12-01-2008, 05:20 PM   #6
VIsubi
Member#: 187834
06 2.5i impreza
Red
why didn't you sub the 4ply head gaskets and didn't those get recalled or changed. don't think it can well maybe it can just not adjust anything on the ECU..I really don't know.
VIsubi is offline   Reply With Quote
Used Sti Pistons Rs Piston Rods neogold Engine/Power/Exhaust 0 01-19-2010 12:18 AM
FS: Used STi Pistons, Timing Belt Tensioner, Various STi Engine Gaskets and seals,... fattie92 MWSOC Private Classifieds 2 05-10-2009 10:18 PM
Building my sti block, and suggestions for pistons and rods? wrxwagon253 North West Impreza Club Forum -- NWIC 5 11-25-2007 02:08 AM
Cobb Tuning 2.5L NA Build - Dyno Results [LONG] Trey Normally Aspirated Powertrain 99 04-03-2007 03:06 PM
For Street Use is 2.5L NA better than STI G.Subramaniam Subaru Conversions 29 11-29-2004 10:12 AM
