Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 12-01-2008, 08:13 AM   #1
DeadBolt Enterprises
Vendor
Vendor Sales Rating: (16)
Member#: 34272
2005 STi
Crystal Grey
Default Turbos from the Subaru specialists! Year end pricing specials.
We have been building and working on Subaru specific turbos that really fit longer than anyone else in the market. Our models have all been designed and test fit on actual shop cars so you don't have any unwelcome surprises when it comes time for installation. We continually monitor production tolerances and have the strictest quality control measures in the industry.
We also PRICE all our turbos! That's right! Unlike some of those other folks, we actually put prices on our stuff instead of making you ask for a price (and then who knows if you really got the same price as the previous guy? )
We use only genuine Mitsubishi and Garrett product, we have refused to follow some of our competitors down the road of cheap low-quality chinese copy parts.
Budget Series Turbos:
Water Cooled Models (Wet cartridges)
TD05H-18G - $929.00*
TD05H-20G - $999.00*
TD05H-Super16G - $879.00*
TD06H-18G - $1199.00*
TD06H-20G - $1299.00*
Non-Water Cooled Models (Dry cartridges)
TD05H-16G - $499.00*
TD05H-18G - $699.00*
TD05H-20G - $799.00*
TD06H-18G - $999.00*
TD06H-20G - $1099.00*
STANDARD DEADBOLT TURBOS
TD04 Turbos
REBUILT TD04 $469*
Starting with a good condition core, we will perform a complete teardown, and rebuild including all seals, bushings, retainers, and O-rings.
MONSTER TD04 $569*
This is our original and most popular offering. Get a turbo upgrade without spending a ton of money. Quicker spoolup, much better "roll-on" acceleration, all new internals, we can even ceramic coat them for you!Starting with a good condition core, we will perform a complete teardown, and rebuild including all seals, bushings, retainers, and O-rings. After the rebuild we perform our now-famous Monster Port(TM) procedure.
Monster TD04 with upgraded compressor wheel - $779.00*
Same Monster TD04 as above, but with a larger, higher-volume compressor wheel and clipped turbine wheel for better midrange AND top end power. Nice turbo for folks running in race classes that require a "stock appearing turbocharger."
TD05H-16G Turbos
We were the first vendor in the US to market these on a large level, and still sell a TON of them all over the world! This turbo was originally never offered on the USDM WRX, or the later JDM versions as the compressor housing is not correct fitment for these models. We modify the inlet so that they fit perfectly on the USDM cars.
We include the metal coolant lines, banjo bolts, banjo seals, oil return with gasket, and stainless steel downpipe studs at this price unlike some other vendors! $729.00*
MONSTER TD05H-16G! Special Order - Same unit as above, except that we perform our famous Monster Port(TM) on the turbine housing providing even quicker spoolup, better midrange, and enhanced top end.
$879.00*
ZILLA SERIES TURBOS!
Remember, unlike some other companies our ZILLA series INCLUDES Installed Coolant supply lines, banjo bolts, AND Oil return line AND downpipe studs! (Over $150 for all necessary parts if purchased separately from that other vendor)
The ZILLA(TM) lineup will include our famous Monster Port(TM) Service, Port Matching to downpipe gasket, Wastegate porting, and turbine housing inlet smoothing. TD06 and Fat-boy models also include port matching of turbine inlet to gasket.
Coatings Included are Black Xtreme(TM) on exhaust housing, and Grey ceramic on compressor housing.
This is a LOT of turbo for the money!
WATER COOLED MODELS
Water cooled models include coolant supply lines, coolant supply banjo bolts, banjo seals, oil return line with gasket and bolts, and stainless downpipe studs.
18G Oil and Water Cooled TD06H turbine - $1299.00*
20G Oil and Water Cooled TD06H turbine - $1399.00*
Super16G Oil & Water TD06H turbine $1225.00*
18G Oil and Water Cooled TD05H turbine - $1195.00*
20G Oil and Water Cooled TD05H turbine - $1295.00*
Super16G Oil & Water TD05H turbine $1095.00*
3 inch inlet models of the 20G available at no additional cost, but require the use of Tumble Generator Valve deletes and 3 inch inlet tube.
All prices quoted above are for internal wastegate setups. We can weld the wastegate closed on the turbo for use with the TIAL brand of wastegates we sell below.
As always, email [email protected] or PM us with any questions.
SUPERZILLA!!!
SuperZilla turbos are available with internal or external gate, water cooled, or by special request, non-water cooled (dry)cartridges.
SZ49-55 are available with a 3 inch or standard inlet. 3 inch inlet models require TGV deletes and a 3 inch inlet pipe.
Limited time special pricing!
SuperZilla SZ49 oil and water cooled internally gated* - $1495.00
SZ55 oil and water cooled Fat-boy IWG configuration* - $1695.00
SZ60 oil and water cooled Fat-boy EWG configuration* - $1795.00
SZ65 oil and water cooled Fat-boy EWG configuration* - $1855.00
*-Prices do not include shippnig costs.
Don't forget! We are also a Thermotec warehouse distributor so we sell all the Thermotec goodies at the best prices!
We also carry Tial brand blow-off-valves, wastegates, etc.
DeadBolt Enterprises is offline   Reply With Quote
Old 12-01-2008, 03:46 PM   #2
Vendor
Member#: 34272
2005 STi
Crystal Grey
Thanks for the heads up Scott, got the colors fixed
Old 12-01-2008, 10:42 PM   #3
im2ninja4u
Member Sales Rating: (8)
Member#: 183389
Man, I want the SZ55 so bad right now, but I need to find the FMIC setup you were talking about first.
im2ninja4u is offline   Reply With Quote
Old 12-02-2008, 09:40 AM   #4
Vendor
Member#: 34272
2005 STi
Crystal Grey
Check with Perrin, that's where the TMIC came from that was on our Legacy.
Old 12-02-2008, 06:19 PM   #5
Miercoles Cansado
Member Sales Rating: (11)
Member#: 166820
my ignore list
PM sent.
Miercoles Cansado is offline   Reply With Quote
Old 12-03-2008, 03:53 PM   #6
rexworx
Member Sales Rating: (65)
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Hi Jerry, I called and left a message today with a few questions about the zilla series td06 20G
Ian,
rexworx is online now   Reply With Quote
Old 12-04-2008, 09:22 AM   #7
Vendor
Member#: 34272
2005 STi
Crystal Grey
Originally Posted by brisby555 View Post
PM sent.
Back your way.
Old 12-04-2008, 03:30 PM   #8
Vendor
Member#: 34272
2005 STi
Crystal Grey
Ian,
Sent follow up PM.
Old 12-05-2008, 09:36 AM   #9
Vendor
Member#: 34272
2005 STi
Crystal Grey
Happy Friday!
Old 12-08-2008, 08:43 AM   #10
Vendor
Member#: 34272
2005 STi
Crystal Grey
The boss is still away! Help us make his return a happy one!
Turbos make great Christmas gifts, and unlike hose pesky kittens, they don't start to smell bad if you put them in a box and place them under the tree weeks before!
Old 12-08-2008, 09:15 AM   #11
kwan_1104
Member Sales Rating: (24)
Member#: 127781
Free bump for Deadbolt!
Excellent customer service, never gets tried of my questions, one of the best vendors I have ever encountered!
Rocking there 20G turbo and couldn't be happier!
kwan_1104 is offline   Reply With Quote
Old 12-08-2008, 07:10 PM   #12
Vendor
Member#: 34272
2005 STi
Crystal Grey
Thanks for the kind words!
Old 12-08-2008, 10:21 PM   #13
Mycues1982
Member Sales Rating: (56)
Member#: 86995
2005 Tacoma
Thanks for your hard work Nick!
Mycues1982 is offline   Reply With Quote
Old 12-09-2008, 07:06 PM   #14
Vendor
Member#: 34272
2005 STi
Crystal Grey
Originally Posted by Mycues1982 View Post
Can someone there please upload a pic into my forsale thread of my sz55? The reason I paid extra for the red ceramic coating on the compressor housing is so it would look better and sell quickly. I've had a couple offers and would think it would've sold by now for what I'm asking if I had a picture of it rebuilt and recoated. Please upload something soon.
You've gotta be kidding me.
The thing needed to be recoated because you stripped out the wastegate actuator legs to the point that they couldn't be repaired so we had to cut them off and weld on new ones. This of course destroyed the coating so it needed to be recoated anyhow. You said there was no rush when we told you that we would put it in with a batch of red that we would do and we'd charge you LESS THAN HALF PRICE. Not to mention we fixed the totally screwed up EWG hack weld job for free. Also not to mention that you haven't paid for either service yet.
Posting the pic in your thread as requested.
Old 12-09-2008, 11:41 PM   #15
mr.four
Member Sales Rating: (4)
Member#: 148479
PM sent!
mr.four is offline   Reply With Quote
Old 12-10-2008, 08:51 AM   #16
Vendor
Member#: 34272
2005 STi
Crystal Grey
Originally Posted by mr.four View Post
PM sent!
Back your way!
Old 12-10-2008, 08:02 PM   #17
Vendor
Member#: 34272
2005 STi
Crystal Grey
Sorry for any inconvenience but our website is going to be down for a bit while we move to our new hosting company and server. Should be back up tomorrow morning.
Old 12-11-2008, 01:08 PM   #18
JRSTI
Member#: 70924
2004 STI
Ja Black/RGII's 255 tires
Price to rebuild a VF39.
JRSTI is offline   Reply With Quote
Old 12-11-2008, 01:48 PM   #19
Vendor
Member#: 34272
2005 STi
Crystal Grey
Sorry, those are not rebuildable.
Old 12-12-2008, 12:28 PM   #20
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Hope your holiday is great. I think I've sent more referrals your way in the last month than the last 5 years, so based on that business should be booming. Have a great new year.
Old 12-12-2008, 04:48 PM   #21
Vendor
Member#: 34272
2005 STi
Crystal Grey
OK, our site is still down.
Apparently the DNS update is taking much longer than expected.
Old 12-12-2008, 07:13 PM   #22
dingobite
Member Sales Rating: (28)
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Whats the best way to contact you email or phone regardless ill try back monday i guess ? Im trying to be in a x-mas rush but theres no need to hurry.
dingobite is offline   Reply With Quote
Old 12-13-2008, 09:30 AM   #23
Vendor
Member#: 34272
2005 STi
Crystal Grey
Old 12-27-2008, 03:21 PM   #24
rexworx
Member#: 103232
Hi Jerry, I pmd you folks. I tried calling, phone still messed up?
Ian,
Old 12-29-2008, 12:28 PM   #25
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
The turbo is in Jerry, thanks again for it. I filled it with sand and made sure I was low on synthetic oil, then raced the crap out of it....now it's making funny noises????
Suspension bits from the suspension specialists Turn in Concepts Suspension/Brakes/Handling 7 02-24-2008 10:53 AM
What Song is This?! (used in the nissan national year end event tv commerical) Protege Menace Off-Topic 28 11-17-2005 06:59 AM
What's the best album from the past 10 years? Strider Off-Topic 116 06-24-2004 09:19 PM
Whats the best CHEESE from the past 10 years??? Davenow Off-Topic 36 06-24-2004 01:29 PM
('93-'01) Never realized the '99s were so different from the other model years danc Impreza Forum 5 08-01-2002 06:36 PM
