Old 12-01-2008, 01:56 PM   #1
Speed Clinic
Vendor
Member#: 192948
2006 wrx gt35r
420awhp@20psi 93oct
Default 06 Sti Speed Clinic Built/Tuned 444awhp 20g
Jeanky's 2006 Sti Mods List:
Greddy20G
Tial 38mm Wastegate
CP Pistons
Eagle Rods
BMPC FMIC
TGV Deletes
Walbro 255 Fuel Pump
Stock Modified Injectors
Modified Invidia Up-Pipe
Greddy Profect-B
HkS Carbon TI 3in Exhaust
Helix Down-Pipe
3mm Grimmspeed Intake Manifold Gasket
Tuned By Columbia
Dyno Video <-----Click Here!!!
We tuned the car on 93 oct and C16. The Results are as follows:
20psi on 93oct 404awhp/387tq
27psi on C16 444awhp/415tq
Speed Clinic is offline   Reply With Quote
Old 12-01-2008, 02:02 PM   #2
Steve.804
Member#: 68647
07 STI
Rotated 35R Jorge Tuned
Wow 404awhp@20psi with a 20G? That's some power!!! Wonder why it only went up 40hp with an additional 7psi of boost? Too bad I cannot see the graphs at work :/
Steve.804 is offline   Reply With Quote
Old 12-01-2008, 02:31 PM   #3
wrxhard
Member#: 108091
how big is the hotside on the greddy 20g? Seems a bit laggier than most 20g's.
Really good numbers for a 20g though. Great job guys.
wrxhard is offline   Reply With Quote
Old 12-01-2008, 04:05 PM   #4
roninsoldier83
Member#: 61966
2011 Mazda 3 &
2009 Kawasaki Ninja 650R
Is the hotside a TD05 or TD06? Like posted above, with peak torque not coming until almost 5000rpm, I would assume TD06?
Either way, very nice numbers man!
roninsoldier83 is offline   Reply With Quote
Old 12-01-2008, 04:22 PM   #5
Speed Clinic
Vendor
Member#: 192948
2006 wrx gt35r
420awhp@20psi 93oct
It has a TD06 hotside on it.
Old 12-02-2008, 01:07 AM   #6
JeankySti
Member#: 170370
2006 STi
Precision 6265 Powered...
Yes it is a td06 20g. thanks for everything guys.
JeankySti is offline   Reply With Quote
Old 12-02-2008, 02:09 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
its a dynojet
because the 20g is a smallerish turbo to be running boost that high.....its getting very close to the edge of the comp map at those PR's
http://www.stealth316.com/images/td06-20g-raw.gif
read this from FP's site
"This 20g turbo offers similar pump gas performance to our FPGreen model, while reducing the boost threshold by a couple hundred RPM due to its slightly smaller compressor wheel. These slightly smaller lower intertia rotating components benefit applications where pump gas is the primary fuel used and boost pressures do not exceed 22psi. Applications requiring higher power output above 22psi would select the FPGreen model over this 20G.
This unit operates very effectively in the 18-25psi range on the 2.5 STi engine, but is slightly lower in maximum power output on race gas (boost above 22psi) compared to our FPGreen model."
Old 12-02-2008, 09:55 PM   #8
JeankySti
Member#: 170370
2006 STi
Originally Posted by Phatron View Post
its a dynojet
Well it is a dynojet but this one happens to be the lowest reading dynojet in all central florida including the mustang dynos around.
Also this numbers were accomplished on a stock exhaust manifold and a conservative tune, we are sure the car has more still left in it.
Old 12-02-2008, 10:26 PM   #9
explor4u
Member#: 138705
2007 WRX STI OBP
XPT Stage 2 - 12.7@107
WOW! Awesome numbers...Now let see it tomorrow at Orlando Speedworld I'll be there tomorrow with my 07 STI!!!! Enjoy your new power man!
explor4u is offline   Reply With Quote
Old 12-02-2008, 11:04 PM   #10
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
this will be legit as hell if it actually goes fast instead of goin 12.6 @ 110
mxpunk is offline   Reply With Quote
Old 12-02-2008, 11:36 PM   #11
JeankySti
Member#: 170370
2006 STi
I won't be out there yet, since i need to buy new tires that actually hook mine are gone. Trust me when i get them you will see me at bithlo.
Do some research i went 12.5@106.92 on the stock vf39 no meth or race gas that was with about 290awhp a week after i took it back on 110 oct and ran a 12.9@110 with a 2.3 60ft so im pretty sure 400+ will not be a 12 sec run .
Old 12-03-2008, 12:07 AM   #12
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
Originally Posted by JeankySti View Post
I won't be out there yet, since i need to buy new tires that actually hook mine are gone. Trust me when i get them you will see at bithlo.
Can't critisize here, people think i'm nuts when i tell them i make 391whp on these dynos. Just go get a trap speed to display your true power. If its a typical high reading dynojet, you won't trap better than 118.5. If its low like you claim, you'll be in the 121-122 range with solid 11.3-11.5's. Seems awfully fast for a 20G, but hey, good luck and hopefully you can bring back a slip that makes people
STi Mikey is offline   Reply With Quote
Old 12-03-2008, 01:31 AM   #13
Audiosavvy
Trust me, I'm a scientist
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Those are awesome numbers, but the torqueband seems WAY to the right... I wonder if you're getting a little clutch slippage around 3600. How does it FEEL though?
Audiosavvy is offline   Reply With Quote
Old 12-03-2008, 09:03 AM   #14
wrxhard
Member#: 108091
Does this have headwork and/or cams? The more i look at these numbers (440 whp out of a 44lb/min turbo) the harder i find them to swallow. Unless it's got cams and/or head work. Then i've got no problems, and that would totally explain the right-shifted power band too.
Old 12-03-2008, 09:32 AM   #15
downsti
Member#: 63179
2006 Stock Turbo STi
11.7@113mph-115.6mph VF39
very nice dyno numbers my friend,
now go hit the strip, make us all proud
+1
downsti is offline   Reply With Quote
Old 12-03-2008, 10:15 AM   #16
SubyWill
Member#: 166830
2003 WRX
it will definately be in the 122 range runnin low 11s, the car is STRONG and he can drive the hell out of it too
SubyWill is offline   Reply With Quote
Old 12-03-2008, 11:05 AM   #17
dmross
Member#: 2818
2000 2.5RS
+1
Nice power but something is off. Peak TQ should be 1000rpm sooner with that turbo. You sure you don't have a boost or header/uppipe/wg leak? Is your boost control setup correctly?
dmross is offline   Reply With Quote
Old 12-03-2008, 11:38 AM   #18
sutter2k
Member#: 92467
08 STI
It does seem very late.
sutter2k is offline   Reply With Quote
Old 12-03-2008, 11:41 AM   #19
wrxwhat
Member#: 87653
07 STI / 97 Supra
1700whp of fun
I've never seen a stock head subaru hold power that well till 7400rpm..
wrxwhat is offline   Reply With Quote
Old 12-03-2008, 11:42 AM   #20
RumblingDice138
Member#: 182853
2011 WRX
that my friend is a nice sube. i wish i had that kinda power in mine.
RumblingDice138 is offline   Reply With Quote
Old 12-03-2008, 11:53 AM   #21
Speed Clinic
Vendor
Member#: 192948
2006 wrx gt35r
420awhp@20psi 93oct
This car is still on the stock heads.
Old 12-03-2008, 12:02 PM   #22
STi Mikey
Member#: 114631
2007 11.5 @ 118
I can see he is a good driver, 12.5 @ 106.9 is very, very repectable.
I have seen both a 20g and a green that had similar graphs on different dynos, held power to 7500 no problem. But they both had ported heads and cosworth cams.
Not sure anyone has put it out there yet directly...
Does this car have head work??
Old 12-03-2008, 12:03 PM   #23
STi Mikey
Member#: 114631
2007 11.5 @ 118
nevermind, looks like someone beat me too it while I was typing ^^^^^
Old 12-03-2008, 12:04 PM   #24
wrxhard
Member#: 108091
It has been asked, and answered, but answered JUST before you posted
Old 12-03-2008, 12:12 PM   #25
STi Mikey
Member#: 114631
2007 11.5 @ 118
Well then thats just a hell of a setup, hell of a job, and a great tune I guess.
Anyone know if this car is gonna be around the orlando area the week before christmas?? I'm drivin down from CT for a few days to play golf before the holiday. I made plans for this about a moth ago and when Speed Clinic posted about there 35r wrx I figured I would visit their shop as well. Ive never been to a shop outside the tristate area.
06 Sti Stg2 Before/After Tuned@Akuma seekndestroy19 Proven Power Bragging 9 09-27-2009 09:24 PM
Speed Clinic GT35R 06 WRX Speed Clinic Proven Power Bragging 104 12-04-2008 01:25 PM
Tuned @ Speed Clinic 319whp/315wtq 04 WRX 272 Cams toutanje Proven Power Bragging 28 10-01-2008 07:00 PM
06 STI - Built by ICS Tuned by XX at THE SHOP. sodo Proven Power Bragging 38 09-10-2007 02:44 PM
508 HP 06 STI Built & Tuned By F1DYNO F1DYNO Proven Power Bragging 34 10-10-2006 11:51 AM
Message Board Statistics All times are GMT -4. The time now is 07:18 PM.
