Old 12-01-2008, 03:35 PM   #1
ajs84
Member#: 185310
2008 Impreza WRX STi
WRB/Gold BBS
Default Different Tire Diameters Affecting AWD?
I'm shopping around for winter tires, and I had one salesperson swear to me that putting tires/wheels with a different total diameter than what comes stock on the vehicle is bad for the AWD system. He claims that a tire 0.4 inches smaller than OEM is much worse for it than using a tire 0.1 inches larger than OEM. To me, this sounds like a bunch of crap, and I can't think of any legitimate and logical reason that this should be true. Can anyone confirm my doubts or give a valid/logical argument for why he is right?
For those who are mathematically inclined, my car (2008 STi) came with 245/40-18's, which yield:
(width_in_mm * height_width_ratio * 2 sides_of_tire_in_total_diameter) / 25.4 mm_per_inch + inner_dimension_of_tire_in_inches = total diameter of tire in inches
(245mm * 0.4 * 2) / 25.4 + 18in = 25.72in
The 235/45-17's I'm looking at:
(235mm * 0.45 * 2) / 25.4 + 17in = 25.33in
The 225/50-17's this salesperson is trying to sell me:
(225mm * 0.5 * 2) / 25.4 + 17in = 25.86in
ajs84 is offline   Reply With Quote
Old 12-01-2008, 03:57 PM   #2
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
This is garbage - as long as all of the tires are the same, the AWD system should be fine. Only with different tires or tread wear can you put stress on the AWD diffs and axles, which could lead to failure over time.
Ernest is offline   Reply With Quote
Old 12-01-2008, 04:29 PM   #3
Web Foot STi
Member#: 39086
2004 STi
Your right. As long as all 4 corners are spinning at the same rpm, going straight down the road, the diffs are happy. Sounds like the salesperson has some tyres to push out the door...
Web Foot STi is offline   Reply With Quote
tire pressure affect on diameter, speedo saabpilot Tire & Wheel 4 10-02-2007 12:46 PM
Changing tire diameter = different gearing BUT..... reddevil Proven Power Bragging 14 07-30-2006 03:57 AM
Does uneven tire wear affect AWD? Stroke Transmission (AT/MT) & Driveline 7 01-23-2003 07:03 PM
Acceptable tire diameter difference? DuneHopper Brakes, Steering & Suspension 9 01-26-2002 12:49 PM
difference in tread affects AWD? kcs Newbies & FAQs 2 11-02-2001 09:26 PM
