Old 03-27-2002, 02:02 PM   #1
BAMA RS
Member#: 877
1998 2.5RS
BDP
Default right channel louder then left?
I hooked up an Alpine 5 1/4 component set in my RS a few weeks ago and when I first listened to it I noticed that the right speakers were noticably louder than the left. I have no adjustability for that on my amp, just gain for front, rear and sub. I have a 5 channel Kenwood amp runnning my entire setup and everything else seems to be ok. There's only a problem with the door speakers. Does anyone know what might cause this? Thanks for any help.
Cameron
BAMA RS is offline   Reply With Quote
Old 03-27-2002, 05:44 PM   #2
Charge
Member#: 3313
Well, mine are the same way(different speakers, though). I put in 6.25's and had to put in spacers to support their depth. I tried to angle the woofers up at me, but only managed the slightest of an angle. Therefore, the left speaker is aiming across my feet. The right is aimed a little more closely to my head.
You have to realize, the tweeter is not normally going to be quite as bright. The Mid-range sound you get from the Mid-Bass woofers will usually be stronger. You're probably hearding that.
Only way to tell, really, is to sit in the back of the car, dead-center.
Just my suggestion. Or, you may have an amplification issue or the wires could be backwards(check crossovers as well).
Neil
Charge is offline   Reply With Quote
need the little black flap right infront of the left wheel CletusTheDwarf Private 'Wanted' Classifieds 5 04-02-2006 10:37 PM
It's the right to LIFE, *then* LIBERTY... rogue Off-Topic 115 12-02-2005 02:01 PM
Right side of car speakers louder than left, normal? affinity1 Car Audio, Video & Security 10 11-01-2005 08:53 AM
drugs to the right, hookers to the left Amazake New England Impreza Club Forum -- NESIC 20 03-07-2005 11:53 PM
Vf-30 louder then stock? RobPA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-06-2002 03:06 AM
