Old 12-01-2008, 07:06 PM   #1
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
Default is it ok to run unevenly worn tires for a week
just bought some wheels locally and 2 of them are at 90%, 1 at 80%, and 1 at about 20%. I would be running them for just 1 week. would i be ok with that?
pumpkyn is offline   Reply With Quote
Old 12-01-2008, 07:11 PM   #2
AbrownSTIo6
Member#: 189911
Chapter/Region: HIIC
**** you
**** brown
What are you running them on? I have not see anything wrong with this before, It is a short time period and you should be fine
AWD - Longer than a week may be harmful
RWD- not as bad wont do anything, i ran 100 and 10 percent for about three months, no big deal.
AbrownSTIo6 is offline   Reply With Quote
Old 12-01-2008, 07:14 PM   #3
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
they are 225/40R18 Kuhmo Ecsta ASX. the turbo is on its way out so its not like ill be wanting to overwork the center diff much.
Old 12-01-2008, 07:20 PM   #4
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Put the 20% and 80% on the front, since it has an open diff. I wouldn't put a lot of miles on that way but short trips should be OK (the spare is not full size after all)
Mike Wevrick is offline   Reply With Quote
Old 12-01-2008, 07:59 PM   #5
fliz
Member#: 30342
I'd keep your speeds low and follow Mike's suggestion.
I saw somebody overheat their rear diff by putting a spare tire on the rear end of their WRX and driving at freeway speeds for 40-50 miles.
fliz is offline   Reply With Quote
Old 12-01-2008, 08:43 PM   #6
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
thanks guys!
now how ok would it be to run 2 90% and 2 100%?
Old 12-01-2008, 11:47 PM   #7
Web Foot STi
Member#: 39086
2004 STi
The wear allowance: "Subaru Within 1/4-inch of tire circumference or about 2/32-inch of each other in remaining tread depth. "
http://www.tirerack.com/tires/tirete...currentpage=52
Your wheels need to spin at the same rpm running straight down the road to keep the diffs happy. Short term it's not a big deal. Long term could be expensive.
Web Foot STi is offline   Reply With Quote
Old 12-02-2008, 08:30 AM   #8
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
^^^ to measure the circumference basically get the tire and roll it on some string?
or around that is if its the same tread, same kind of tire and say 2 are at 8-9/32 and the other 2 are at 10/32 then I should be fine?
Old 12-02-2008, 11:02 AM   #9
Ktempo
Member#: 180226
2005 Impreza WRX
Im curious to know if having two new tires in the front and two old tires in the rear would be a problem long term. Somehow i managed to get 5 nails in one of my tires, and i cant afford to buy a whole new set of http://www.tirerack.com/tires/Sizes....Potenza+RE050A which are my current tires. I was thinking to leave those in the rear, and replace the front with http://www.tirerack.com/tires/Sizes....+Pole+Position . I live in NJ where the roads are terrible and we see snow a few times a year... my train of thought was that i could maybe get some grip in the snow, save some money, and not suffer too much handling. Theres about 10k miles on the old tires btw... if it were less i might consider just buying one of the same tires and being done with it.
Ktempo is offline   Reply With Quote
Old 12-02-2008, 12:46 PM   #10
fliz
Member#: 30342
Bad idea on multiple fronts.
1) Do not run different model tires front/rear...it can screw up the center diff. The two tires you posted have a new tread depth difference of 1/32", and way different treadwear ratings.
2) The circumference rule by Subaru applies to all four tires...not pairs
3) Running a summer tire in the rear is a sure way to end up spinning out of control in the snow.
Old 12-02-2008, 01:16 PM   #11
Web Foot STi
Member#: 39086
2004 STi
You got it.
Personaly I use a 10' 1/4" steel tape measure for circumference.
Since the front tyres tend to wear more I'd start with the better set on the front. Rotating the tyres is important on these cars.
Old 12-02-2008, 02:07 PM   #12
Ktempo
Member#: 180226
2005 Impreza WRX
Thanks for the info! I love my subaru, and im still learning =) Im more than a little paranoid about making decisions about my car, so the well informed response is appreciated.
Old 12-02-2008, 11:37 PM   #13
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
thanks!! thats what happened with this set. I just got lazy and said screw it and didnt rotate them for about 10k then when i took the front tires off the tires were worn fairly more than on the front. so thats why im getting new wheels and tires
Is it ok to run tires that are not stock size? dgsblb2 Tire & Wheel 4 02-27-2009 08:07 PM
Is it ok to run without fender liners at the track? Also, how to remove them? ewright Motorsports 9 10-29-2005 10:36 PM
is it ok to run sedan springs on wagon? (pinks) daphunkie12 Brakes, Steering & Suspension 4 01-22-2005 04:14 PM
Is it ok to run without a muffer? What about all the heat and the gas tank? LqSilver General Community 20 11-14-2003 09:52 AM
is it ok to run without the 2nd o2 sensor on the midpipe [freeman] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-28-2003 06:03 PM
