Old 12-02-2008, 01:46 PM   #1
LukeD
Member#: 90243
2002 V8 JDM STi wagn
flat black
Default Subaru WRC ALS
So I've noticed a few posts come up as of late talking about the ALS system used in the Subaru WRC. There was a picture posted from a prodrive tour with a turbo, headers and exhaust. On the up-pipe/headers side of the turbo, there was an extra flex pipe with a black box attached to it. After reading through many of the discussions here and having discussions around the shop I work at (HMS Motorsport). We came to the conclusion that that pipe actually pulled air in from the hot side of the intercooler and then pulsated it through the black box and then finally through the turbo, thus keeping the turbo spinning. This would prove to be a more effective way at canceling out the lag and not going with the "bang-bang" ALS that a lot of cars use. So, not fully happy with the conclusion we came up with, I decided to shoot an email over to subaruwrcspares.com The email I received back is here...Rodney explains how the whole system works and also touches on how the big "charge pipe" works which comes from the intercooler to the throttle body. I hope this clears some things up..
picture of the turbo side of the ALS system.
email
Hi
The item you refer to is known as a "rocket". This device is fitted to the header just in front of the turbo and works as a sophisticated anti-lag system.
Air and fuel are fed into a combustion chamber and ignited by a spark on over-run, it can be used in three stages (depending on how long you want the engine to last) and is the cause of the load banging noise that can be heard as these cars pass by and the flames coming out of the tail pipe. This system is used in conjunction with the boost pack which stores excess pressure in it's own reservoir to be fed back into the engine inlet side of the inter cooler when the throttle is depressed after shut off.
All this is coupled to the "flat change" gear shift and launch control system which is of course controlled the the ECU.
Just to give you some idea of prices:
WRC Header 2,200
WRC Turbo 10,000
Boost Pack 3,000
ECU 5,000
Engine Wiring Harness 3,000
The "rocket" system was removed from customer cars by Prodrive, and only cars still under contract (S11 onwards) left the factor with this spec.
Hope this was of help
Rodney
few pics circled is the rocket system/charge canister
LukeD is offline   Reply With Quote
Old 12-02-2008, 03:23 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
very cool. I was always curious what that canister was there for
Old 12-02-2008, 03:26 PM   #3
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
very interesting.
jnorth85 is offline   Reply With Quote
Old 12-03-2008, 12:27 AM   #4
snoe19
Member#: 146045
2005 STi
Crystal Grey Metallic
thanks for the info... I always wondered the details on how that actually worked.
at subaruwrcspares.com
holy crap I wish I could get some stuff shipped over here from them.
snoe19 is offline   Reply With Quote
Old 12-03-2008, 04:28 AM   #5
optional
Member#: 193090
'06 Scion tC
Flint Mica
so this is what that black evo in initial d uses lol.
optional is offline   Reply With Quote
Old 12-03-2008, 05:29 AM   #6
thad
Member#: 176616
1994 impreza
white
wow, thanks for taking the time to post this, ALS have become a recent fascination of mine.
any insight on how the "boost pack" works. throttle switched or vacuum? fed straight from the turbo or through the bypass valve?
thad is offline   Reply With Quote
Old 12-03-2008, 11:17 AM   #7
Ralliart4
Member#: 135927
2002 Impreza WRX RA
Well the simple explenation was that this becomes a circa 5th cylinder dedicated to keeping the turgocharger in efficiency boostready and takes quite a bit to keep the system managed. The advantage is that it is more of a mechanical system than other teams so reliability and electronic connectivity will not disable the engine.
I saw one and got one of the engineers to try and explain it to me but i still did not get the whole picture but in a nutshell there you have it.. it was Sir Harrold Morely's Prodrive S12 WRC car from Barbados that he sold last year.
Ralliart4 is offline   Reply With Quote
Old 12-03-2008, 12:14 PM   #8
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
Supposedly its some sort of gas turbine in the rocket chamber. There was a good article on this in one of the race engine technology from 2006. 3.5 bar absolute at 1800 rpm. If you sit on the start line next to an S9 or newer wrc, you can hear it
dentsport is offline   Reply With Quote
Old 12-03-2008, 12:56 PM   #9
LukeD
Member#: 90243
flat black
just found that issue online and bought it. kinda curious as to what it says.
Old 12-03-2008, 02:23 PM   #10
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
cool info
chimchimm5 is offline   Reply With Quote
Old 12-04-2008, 10:10 AM   #11
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Please scan and post when you get the magazine
I'm still a little confused about the entire system's interaction and plumbing. Maybe there's a diagram/schematic.
<-- Bought his harnesses from you guys
jblaine is offline   Reply With Quote
Old 12-04-2008, 10:49 AM   #12
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
Jblaine,
The fresh, compressed air is taken from right after the compressor outlet and sent to the valve shown in that first photo. It enters the manifold collector right before the turbine. The air mixes with unburnt fuel. Something happens in that "rocket" area and creates a high velocity of exhaust (the only thing that could create that level of velocity at such low engine load would be a gas turbine). Prodrive weren't the first to do this (just make it extremely simple). The first I know of is Nick Mann with his Ford BD Turbo powered hillclimb car. He used a small emergency start turbine from a bell helicopter to keep the turbo at 30+ psi.
If you wait until the first S12 that appears in this video, you can hear the engine idle change. They leave the start line at 1800 rpm. The ford/skoda and Grp N cars leave at 5-6000rpm. Pretty cool.
http://www.youtube.com/watch?v=LpBiZYVfTp8
Old 12-04-2008, 10:57 AM   #13
Carisma
Member#: 89017
1995 Subaru Impreza
Red
If you wait until the first S12 that appears, you can hear the engine idle change. They leave the start line at 1800 rpm. The ford/skoda and Grp N cars leave at 5-6000rpm. Pretty cool.
That's interesting. Thanks for the video.
Carisma is offline   Reply With Quote
Old 12-04-2008, 05:38 PM   #14
orbit03
Member#: 2300
2002 Impreza WRX
Banana Pudding
That must be a hell of a ride on launch.
orbit03 is offline   Reply With Quote
Old 12-04-2008, 08:12 PM   #15
cazwrx187
Member#: 176592
2002 WRX-Sold
1998/04 Unicorn RSTi
Yeah I saw the "boost pack" on subaruwrcspares.com a few months ago. I never knew what it was.
cazwrx187 is offline   Reply With Quote
Old 12-05-2008, 11:10 AM   #16
Big C
Member#: 3586
2000 RSTI Rally Car
2012 STI SWP Hatch
Great post and interesting read! Thanks
Big C is offline   Reply With Quote
Old 12-05-2008, 11:47 AM   #17
O4STInger
Member#: 77934
00 2.5RS w06' swap
BLUE
awesome post!!!
O4STInger is offline   Reply With Quote
Old 12-05-2008, 09:36 PM   #18
MGAMAN
Member#: 24671
2010 Audi S4 PP
2006 R1 - 06/08 hybrid
wow awesome info! video was great to hear the difference in launch.
MGAMAN is offline   Reply With Quote
Old 01-31-2009, 02:38 PM   #19
subaruwrcspares
Member#: 201669
2009 Porsche 911
subaruwrcspares is offline   Reply With Quote
Old 01-31-2009, 02:54 PM   #20
subaruwrcspares
Member#: 201669
2009 Porsche 911
Can someone please explain how I add pictures to my post - I am losing the will to live at the moment
Old 01-31-2009, 03:10 PM   #21
jeisen
Member#: 27258
who dat be dat was?
You can link them from another site by surrounding the link with img tags. Simply press the button above where you type the text that has a mountain/moon on it (insert image) and paste the link of the picture in there.
jeisen is offline   Reply With Quote
Old 01-31-2009, 03:57 PM   #22
Subaruski
Member#: 39905
i dont see any pictures
Subaruski is offline   Reply With Quote
Old 09-22-2009, 04:57 AM   #23
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
bump for more info!
u2_m4r1n3 is offline   Reply With Quote
Old 09-26-2009, 03:00 PM   #24
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
BUMP again for more info
Old 09-27-2009, 02:26 AM   #25
LukeD
Member#: 90243
flat black
lol i have no more info.
Hpi Micro Rs4 Rc Car, Jdm Mini Subaru Wrc Rc Car, Subaru Wrx Sti Tamiya Model anthonyrb98 Accessories & Misc 12 01-06-2008 12:31 AM
WTT: 1999/2000 Subaru WRC Challenge mag & Subaru WRC stickers for MY05 Leg. Brochure Penphoe Vancouver Impreza Club Forum -- VIC 4 09-05-2007 03:29 AM
Subaru busy to prepare for 2005 [Merged 2005 Subaru WRC thread] 2002pete Motorsports 26 03-01-2005 06:59 PM
Subaru WRC Car at Subaru of Riverside! clam Southern California Impreza Club Forum -- SCIC 13 03-31-2003 07:50 PM
Anyone else get the Subaru "Drive" mag and the "Subaru WRC great challenge"? BlueScooby New England Impreza Club Forum -- NESIC 5 04-13-2001 05:32 AM
