Old 12-02-2008, 01:07 PM   #1
omeskcus
Member#: 134657
Default noise from rear end
Ok so my tires on my 93 AWD Impreza were pretty worn. I got new Kumho solace KR21 tires all the way around. Since I got my car back I notice this loud harmonic hum sound. Its more noiticable at lower speeds, then when i get to about 50 + mph it seems to quiet down. I thought it was maybe a bearing at first but i lifted the car up turned the wheel and check or play. And it does not seem like tire noise, my front tires are super quiet and nothing shakes.
Any suggestions or thoughts.
omeskcus is offline   Reply With Quote
Old 12-02-2008, 03:35 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
When was the last time you had any brake work done?
Mike
GrimmSpeed is offline   Reply With Quote
Old 12-02-2008, 06:15 PM   #3
omeskcus
Member#: 134657
never did the rear brakes.
Old 12-02-2008, 06:20 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
try out the drivetrain forum... you will get better results there.
Old 12-02-2008, 11:07 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Check to make sure the calipers aren't stuck or see if the pads need to be replaced. My brakes made a similar noise a few years ago and a simple pad replacement and brake cleaning fixed the problem.
Mike
Old 12-02-2008, 11:48 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Wheel bearings don't have to be loose to be noisy. Does the noise change when you turn the wheel? If it goes away when you turn the wheel it could be a bearing.
Old 12-03-2008, 03:29 PM   #7
omeskcus
Member#: 134657
yeah the noise changes im almost positive now its a dang wheel bearing! I had a mechanic drive it and a few people they all said wheel bearing. Anyone ever change on on a older AWD Impreza. I wanna do it my self.
Old 12-03-2008, 03:29 PM   #8
omeskcus
Member#: 134657
Old 12-03-2008, 03:45 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
Easiest way to do the wheel bearing is to buy a used hub/spindle assembly and just swap it out.
Old 12-03-2008, 04:18 PM   #10
omeskcus
Member#: 134657
what if the bearing in used hub assembly is bad tho?
Old 12-03-2008, 04:39 PM   #11
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
that's a chance you'll have to take.
Old 12-03-2008, 05:23 PM   #12
69subaru360
Member#: 159682
1995 WRX
2015 F150
When they go bad, they have a notchy feel to them if you spin them by hand off the car. Or if they are really bad they are loose. So if it spins free and quietly it is probably a good one. There is still a slight chance you could get a bad one, but at least you won't have a lot of money in it. I actually did one today on an outback, I got the whole spindle/bearing/hub for $25 at a U-Pull it junkyard.
Old 12-03-2008, 06:50 PM   #13
omeskcus
Member#: 134657
I have checked junk yards in my area before for other parts and no one around me has subarus. Anyone ever change a rear wheel bearing before?
Old 12-03-2008, 09:59 PM   #14
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
its not that difficult if you have a solid chunk of time. you will do best if you go into battle with a shop manual . you can get the bearing new cheap. buy good quality greese like amsoil or lucus red and sticky or something, if you want it to last.
you will need a good sized puller and some other tools . try www.scoobymods.com and do a search there. this place has the best prices around, http://hondasubaruparts.com/partloca...?siteid=215050
watchunglava is offline   Reply With Quote
Old 12-04-2008, 09:54 AM   #15
omeskcus
Member#: 134657
cool thank you I will look on those sites you provided for me!
Old 12-04-2008, 10:05 AM   #16
69subaru360
Member#: 159682
1995 WRX
2015 F150
Or go on www.car-part.com and find a junkyard that will ship to you.
Old 12-10-2008, 06:44 PM   #17
omeskcus
Member#: 134657
ok so I cant tell for sure which side the wheel bearing noise is coming from. When i turn the car left it sounds like the noise is coming from the right. When i jack the rear end up i cant tell the difference. This is driving me nuts.
Loud metal on metal 'clacking' or smacking noise from rear end 04 sti RR02wrx Brakes, Steering & Suspension 3 01-10-2010 12:38 AM
Help! buzzing noise from rear end 02 wrx car_cursed General Community 6 01-17-2006 06:49 PM
Horrible Noise From Rear End on STI Hayaboosted Transmission (AT/MT) & Driveline 3 07-27-2005 09:19 PM
odd noise from rear end in reverse tmeh Transmission (AT/MT) & Driveline 13 01-05-2005 11:25 PM
Whirring noise from rear end. Which dealer should I choose? Dan00Hawk Mid West Subaru Owners Club Forum -- MWSOC 6 11-14-2002 01:11 PM
