Old 12-02-2008, 02:39 PM   #1
i_drank_what
Member#: 82614
2005 WRB STI
2005 OBP WRX
Default 2004 STi Intake Manifold on 2007 STi
Will a 2004 STi intake manifold bolt up to a 2007 STi? Are there any differences?
i_drank_what is offline   Reply With Quote
Old 12-02-2008, 02:44 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I don't see why not, AFAIK they are the exact same
Old 12-02-2008, 03:01 PM   #3
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
No its not a direct bolt on. You will have to oval out the holes that go from the IM>TGV. Alos some of the vacuum lines are in different places.'
Justin
GrimmSpeed is offline   Reply With Quote
Old 12-02-2008, 03:13 PM   #4
Member#: 51961
2005 STi
2012 WRX
Good to know
Old 12-02-2008, 04:13 PM   #5
MasterKwan
Member#: 98961
2003 WRX
The injectors are different too if you switch the TGV parts as well.
Old 12-02-2008, 06:26 PM   #6
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
I don't think that's a direct bolt on. "I THINK"
tux121 is offline   Reply With Quote
Old 12-03-2008, 03:03 AM   #7
i_drank_what
Member#: 82614
2005 WRB STI
2005 OBP WRX
Is it safe to say that any of the side feed TGV equipped STi models (pre-07) intake manifolds can be swapped without modifications? And that all of the top feed TGV equipped STi models (07+) intake manifolds can be swapped without modifications?
Old 12-03-2008, 12:08 PM   #8
Mycues1982
Member#: 86995
2005 Tacoma
Is there any modification needed to the '07 and up regular wrx intake manifold to fit the earlier model wrx tgv's?
Mycues1982 is offline   Reply With Quote
05 STi intake manifold on 07 WRX: I know it fits, need help w/WRX harness onto STi IM adjasont Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-01-2010 03:25 PM
STi Intake Manifold on 03 WRX CatchMyDrift Subaru Conversions 4 02-09-2005 07:39 PM
STi Intake Manifold on NA 2.5? BrysImpreza Normally Aspirated Powertrain 15 10-13-2004 02:27 PM
sti intake manifold on 03 wrx Smoke Show Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-14-2004 05:50 PM
STI Intake Manifold on 98. Fitting? Befits? awd4ever Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-20-2003 04:06 PM
