Old 12-02-2008, 05:50 PM   #1
05ASPINREX
Member#: 190454
2005 wrx stage II
white like my bitch
Default Mobil one synthetic Bad?
i just changed over to mobil one sythetic my car is an 05 wrx with 40xxx miles on it. is it bad to run sythetic. many people have told me not to run it.. are they just retards or am i an idiot
05ASPINREX is offline   Reply With Quote
Old 12-02-2008, 06:01 PM   #2
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
11 Taurus SHO daily
There is absolutely no downside to running synthetic other than the added cost. You can run it longer between changes, it doesn't break down with heat as quickly, it cause less sludge, and it has a higher resistance to gasoline contamination.
There are many myths about synthetic that seems to make people worry about it. When it first came out in the aircraft industry, there were some problems with. They had issues of it not mixing with mineral oils and a few other problems but those are all resolved and have been for decades.
Some people have complained about more oil consumption when using Mobil 1 5w30. I used to use it. My car seemed to use a lot when autocrossing on hot summer days. But that probably has more to do with the fact that it is 5w30 not that it is Mobil 1. I started using 5w30 Mobil in the winter and 10w30 Mobil 1 in the summer. It used a lot less. I now use Royal Purple in the same viscosities. It seems to use about the same amount.
FourOnTheFloor65 is offline   Reply With Quote
Old 12-02-2008, 06:07 PM   #3
DC16A2
Member#: 174357
2002 OBS
There's an Oil FAQ: http://forums.nasioc.com/forums/showthread.php?t=499177
Part of this edutainment series by Unabomber: http://forums.nasioc.com/forums/showthread.php?t=533787
Hope this helps =)
DC16A2 is offline   Reply With Quote
Old 12-02-2008, 06:15 PM   #4
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
I personally run mobile 1 turbo deisel truck oil which is synthetic. reccomended by my tuner. i never consume oil and it runs great.
SedonaScooby is offline   Reply With Quote
Old 12-02-2008, 06:42 PM   #5
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
^^^so you run 15w50 which is pretty heavy.
some people have had bad luck with mobile one saying that it shears out to 5w20 from a 5w30 pretty quickly
if you want good oil motul or amsoil is the way to go.
03WRX-WRB is offline   Reply With Quote
Old 12-02-2008, 06:43 PM   #6
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
i would rather piss in my engine than use 5w30 M1
'Mobil 1' is MANY-MANY oils and this kind of 'generic' error in description of things here cause a HUGE amount of stupidity and misinformation being spread
BE SPECIFIC
Old 12-02-2008, 06:49 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
the above os just plain wrong on seveal levels
and Mobil makes a couple 15w50 oils and is NOT what the guy was talking about in any event
Old 12-02-2008, 06:50 PM   #8
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
We have a whole forum for oil and this ain't it. Post appropriately or post in the newbies forum as you've upset like 200,000 people with your n00bness.
Old 12-02-2008, 07:08 PM   #9
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
whats the difference between all the 15w50 oils that mobile one makes then?
not many people run a 15w50 in the subarus that i have heard of. i dont know if its a bad thing or not. being in a cold climate i cant see a 15w being good but in a warm climate its probably not a bad thing.
and i said 15w50 is heavy but it is a bit thicker than 5w30 no?
Old 12-02-2008, 07:54 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
if you do not know anything do not post anything
you do not......
Old 12-02-2008, 08:03 PM   #11
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
well oil is one of the things i know little about. so why dont you give me some more useful information other than "you know nothing" i dont know everything neither do you so help someone learn something new and not be so damn rude about it.
Old 12-02-2008, 08:05 PM   #12
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
11 Taurus SHO daily
Sorry to hyjack the thread.
How is the diesel oil working out for you? How many miles are on your car? Did you have some sludge build up in your motor or something, and figured the added detergents would help clean it? Or do you use it more to keep it clean in the future?
The reason I am asking is that my POS daily driver Honda has a good deal of sludge buildup from the previous owner neglecting to change the oil often. I was thinking about switching to 10W30 diesel oil. I think Mobil makes that in the Delvac series as a mineral oil.
Old 12-02-2008, 08:51 PM   #13
mikeythejew
Member#: 141672
07' wrx
Uncle Scotty 5W30
Anyone with knowledge will agree to use this product. http://www.auto-rx.com/
mikeythejew is offline   Reply With Quote
Old 12-02-2008, 09:39 PM   #14
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
11 Taurus SHO daily
I don't really want to try some company's snake oil as a solution. Oil is designed to work by itself. They spend lots of time putting together additive packages. Mixing something with your oil can interfere with the additives designed into the oil. I'm not a chemist. I am not going to dump something in my motor that the oil was not designed to have mixed with it and assume it will work.
The diesel oil is designed to clean the engine better than regular oil with more detergents in its additive package. That's why I have been considering it. Chemists and chemical engineers have designed it to clean better than regular oils without having to had some magic bottle into it. That's why I thought it would be good for my situation.
Old 12-02-2008, 09:51 PM   #15
bluesubie
Member#: 767
04 FXT
- Mobil1 Turbo Diesel Truck is a 5W40.
- Auto-RX is not a snake oil and has been tested by one of the top oil experts in the country (if not the world). It is a engine cleaner made from esters.
- If you want to use Mobil1 run M1 0W40 (their best 30 weight ) or M1 TDT. Even Blackstone has commented that they see high wear with M1. Check this used oil analysis.
-Dennis
Old 12-02-2008, 10:08 PM   #16
SedonaScooby
Member#: 143522
98 Forester L (RIP)
I've run the turbo diesel oil for a year now, put about 25+ k on the odometer. it burns no oil, ever. I go 5,000 miles on every oil change and its never nasty gunky ass thick.
after using it for 3 months or so i had a engine oil analysis done. i cant remember the terms they put it in from blackstone or w/e it was but my engine was fiving cherry for the 65K that where on it. it had less particle contaminants then what is the "good" scale in their % they gave me. basically they said .02-.10% is ok and mine where at .01 or just none. they also said my engine was running so good and from what they found from the oil i used is that i could go 7800k inbetween changes based on the analysis. thats nuts to me, i do 5k which i still think is pushing it. used to always do 3k with my JDM f20b swapped accord. i ran mobile 1 in that as well, just not this oil.
not sure if its cuz i'm the second owner and the first owner treated this thing better then his wife and kids...or if its cuz i run that certain oil...or what. not sure its the oil since i only had been running it for 3-4 months before the oil analysis.
Old 12-02-2008, 10:09 PM   #17
SedonaScooby
Member#: 143522
98 Forester L (RIP)
-Dennis
odd blackstone sent me back my info saying my oil/engine was great. even recommended changing it out every 7800 miles. that was based on the turbo diesel oil i was running, and the sample was sent in at 5000k on the oil change.
Old 12-02-2008, 10:16 PM   #18
raheezy69
Member#: 163078
MARG BAR DICTATOR
LONG LIVE IRAN!!
search button.
i've stopped using a certain oil filter because of that great button.
let's see if you can see which oil filter is trash.
raheezy69 is offline   Reply With Quote
Old 12-02-2008, 10:28 PM   #19
SedonaScooby
Member#: 143522
98 Forester L (RIP)
Originally Posted by raheezy69 View Post
search button.
thanks for the input on mobile 1 synthetic oil. answered everything the op was looking for.
Old 12-02-2008, 10:58 PM   #20
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
you like WAY-WAY too many here just do NOT read
'MOBIL 1' IS ABOUT 40 DIFERENT OILS AND THEY ARE ALL DIFFERENT AND SOME ARE GARBAGE SOME ARE NOT AND MOST IDIOTS THINK THEY HAVE TO USE THE GARBAGE 5W30 WHICH IS 100% FALSE
Old 12-02-2008, 11:00 PM   #21
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
and when will this end
JHFC
Old 12-04-2008, 04:03 PM   #22
GullyWagon07
Member#: 164171
08 EvoX <3 Wagon
rear prodrive plate frame
i hear mobil 1 is releasing 0w30 and 0w20(not that i will use it) comming 09.
GullyWagon07 is offline   Reply With Quote
Old 12-04-2008, 04:21 PM   #23
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
The 0w30 and 0w20 products are already "available" under the "Advanced Fuel Economy" product line.
http://www.mobiloil.com/USA-English/...l_Economy.aspx
I say "available" because Mobil has a shortage of all their products right now due to hurricane damage to their production facility.
gpshumway is offline   Reply With Quote
Old 12-04-2008, 04:44 PM   #24
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
and neither of which would be at all suitable for a turbo subaru, IMO
Old 12-04-2008, 05:13 PM   #25
jesubi11
Member#: 142780
2004 WRX Wagon
JBP
What do you use Uncle Scotty?
jesubi11 is offline   Reply With Quote
Lots of mobile one synthetic motor oil! ryanjorunner Private 'For Sale' Classifieds 12 03-26-2006 08:51 AM
Mobil One vs. other synthetics AaronBBrown Service & Maintenance 81 12-18-2002 12:03 AM
Mobil One Synthetic SupaSench Tri-State Area Forum 13 06-11-2002 02:16 AM
i just mixed mobil 1 synthetic with valvoline synthetic (both 5w-30)... db97 Service & Maintenance 4 03-08-2002 09:50 PM
Mobil One synthetic Tranny fluid is it worth it Jimmy Normally Aspirated Powertrain 6 06-04-2001 07:14 AM
Message Board Statistics All times are GMT -4. The time now is 12:42 PM.
