Old 12-12-2008, 06:21 PM   #51
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Wink
Originally Posted by z&cobb View Post
The next oil change will be with Penzoil Platinum, and the one after that with Valvoline.
I'll report back if one of those finally ruins my engine or turbo (currently 150,000 miles).:
For people like us, maybe it will upset the engines' delicate balance.
Coati is offline   Reply With Quote
Old 12-12-2008, 07:15 PM   #52
dictoresno
Member#: 139816
2002 WRX, VF34 swap
i was considering going to Rotella-T 5W-40 on my next change. i blew up my first motor on M1 5-30. after a brand new block and two oil changes on RP, about 7000 miles, i was wondering if the 5-40 rotella would be a good choice. ive read over and over on here and the bob is the oil guy site trying to research the oil. so again, how many people have been running Rotella-T 5W-40 and have success with it? i really dont want to risk blowing this car up again. i dont track it or race it its just a daily driver.
dictoresno is offline   Reply With Quote
Old 12-12-2008, 07:21 PM   #53
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
mobile 1 synthetic is like italian olive oil..it sux
mxpunk is offline   Reply With Quote
Old 12-14-2008, 06:17 PM   #54
bluesubie
Member#: 767
04 FXT
Perhaps Valvoline increased the Zinc antiwear additive to the old formulation level of Mobil 1, or increased it over that level.
The levels have not changed to the "old formulation level of "Mobil1", which would be ILSAC GF-3. The levels are the same as current GF-4 specs. Some are speculating that Synpower may already meet some of the GF-5 specs.
Turbocharger Protection
Use of the TEOST 33C deposit bench test is being considered in GF-5 to evaluate Turbocharger Protection.
During this test, problems were observed with oxidative degradation/thermal coking of engine oil in the turbocharger bearing area during hot shut-down. It is necessary to protect the bearing from deposits because deposit build-up in the turbocharger bearing area can lead to loss of engine performance and possibly engine failure.
Turbocharger Protection is important, but there are tradeoffs when it comes to Fuel Economy. The detergent and dispersant components that go the metal surfaces to keep the engine's parts clean and prevent deposit build-up in the turbocharger, compete against the friction modifier components that go to the metal surfaces to reduce friction and improve fuel economy.
Mobil 1 is kinda in the thread title. But I guess oil made in Germany is what all US drivers should use. German technology FTW.
It's probably the best 30 grade that you're going to find "off the shelf" so why not use it? It's not necessarily that it's "German technology" but it's an oil that meets European ACEA A3 requirements for shear stability.
-Dennis
Old 12-14-2008, 07:52 PM   #55
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Italian oilve oil is quite good, in fact....depending on brand and quality used.
JUST LIKE motor oil.
Your analogy if fraught with error.
Old 12-18-2008, 05:27 PM   #56
subarurabbit
Member#: 4083
2011 OB 3.6R
I think there is a reference to the imitation olive oil from NY/NJ being sold in CT in that post.
On 10k miles wish Amsoil ASL 5w30... 5k more to go!
subarurabbit is offline   Reply With Quote
Old 12-18-2008, 08:49 PM   #57
Uncle Scotty
Member#: 16200
OK buy Nates beans
yoar not one of those guys that thinks running oil for 15k miles is a good thing are you????
'cuz it isnt and thats just plain nuts
Old 12-18-2008, 10:13 PM   #58
GullyWagon07
Member#: 164171
08 EvoX <3 Wagon
rear prodrive plate frame
^serious.....
ill go max 4k on my gc 0w-30 on how spirited i drive, including stop and go, car getting turned on and off......and etc. etc.
GullyWagon07 is offline   Reply With Quote
Old 12-18-2008, 10:33 PM   #59
mikeythejew
Member#: 141672
The best oils are usually found in convenience stores. They are usually marked API "SA". We all know an "A" is the best grade.
mikeythejew is offline   Reply With Quote
Old 12-19-2008, 09:55 AM   #60
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Written with sarcasm, I'm sure
AndyH is offline   Reply With Quote
Old 12-19-2008, 10:42 PM   #61
Rom3BreaK
Member#: 186995
1992 3000gt VR4
Java Black Pearl
http://ferrarichat.com/forum/faq.php...tor_oil_basics
Hopefully this will help, although long, it's definitely worth the read.
The conclusions I reached after having read the article are as follows:
Run a 10w (or possibly a 5w) oil as today's 0w oils don't resist shearing well. If it wasn't for the viscosity shearing affect of today’s oil, 0w would be the best. Unfortunately, a good 0W oil is not yet available.
Motul 300V or Redline are best because they are ester based oils and thus resist viscosity shear much better than Mobil 1 does. I'm not positive but I think I recall hearing that Royal Purple is ester based as well.
I would personally not run anything over a 10w35 oil in a suby, although admittedly I'm not sure about information regarding normal operating temperature for your cars, but I believe they don't run too hot (unless racing conditions are present).
Bottom line: I would run full synth. I would not run M1. I would run an ester based oil.
Rom3BreaK is offline   Reply With Quote
Old 12-20-2008, 01:03 AM   #62
Uncle Scotty
Member#: 16200
OK buy Nates beans
some of that is out of date and anything with a turbo is harder on oil that those without and ive never seen any 10w35 and I(and others) could go on and on and on
Old 12-21-2008, 11:50 AM   #63
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
[url]... Unfortunately, a good 0W oil is not yet available.
I beg to differ, Castrol Syntec 0W-30 (a.k.a., "German Castrol" or simply "GC") has proven to be a very stout motor oil that is very resistant to shearing.
Old 12-21-2008, 04:27 PM   #64
bluesubie
Member#: 767
04 FXT
Agreed. And I'm having very good results with Amsoil SSO 0w-30. It stayed in grade after 8,000 miles of a brand new turbo, towing, sprited driving, several days of 100+F temps and off-roading.
Another thing about that article, Dr. Haas is a surgeon and car enthusiast. He is not a tribologist. He does use 20 grades in his exotics , but he does not use girly-man thin oils like Mobil1. Only Red Line or Renewable Lubricants Inc. Red Line 5W-20 would resist shearing better than most (if not all) Energy Conserving xw-30's like Mobil1 because of it's high HTHS.
-Dennis
Old 12-24-2008, 02:14 PM   #65
Astroguy
Member#: 46392
2004 WRX
I commonly read that Rotella 5w40 is recommended, any thoughts on the 15w40 variety for those of us that live in mild climates (say greater than 30 F temps)? I've actually read some threads at BITOG suggesting the 15w40 is more shear stable than the 5w40, for example here... http://www.bobistheoilguy.com/forums...ue#Post1220861
So despite 5w40 being synthetic and 15w40 plain dino, if the 15w40 is more shear stable wouldn't it be a better candidate for mild climate or summer use?...and also extended change intervals?
Astroguy is offline   Reply With Quote
Old 12-24-2008, 08:53 PM   #66
esteve
Member#: 28716
2006 STI
By all accounts, Rotella T 5W-40 is an excellent oil and I'll probably be switching to it for my next oil change due to its value and availability. The only possible concern is if your car burns oil, the extra phosphorous in Rotella might damage your cats.
A cSt viscosity @ 100 degrees C of 15.5 makes me salivate!
esteve is offline   Reply With Quote
Old 12-24-2008, 09:04 PM   #67
Uncle Scotty
Member#: 16200
OK buy Nates beans
well....i would say that if you prefer long change intervals.....4k+ miles....use the 5w40
if you are just gonna dump it every 3k.....use the 15w40
Lots of mobile one synthetic motor oil! ryanjorunner Private 'For Sale' Classifieds 12 03-26-2006 09:51 AM
Mobil One vs. other synthetics AaronBBrown Service & Maintenance 81 12-18-2002 01:03 AM
Mobil One Synthetic SupaSench Tri-State Area Forum 13 06-11-2002 03:16 AM
i just mixed mobil 1 synthetic with valvoline synthetic (both 5w-30)... db97 Service & Maintenance 4 03-08-2002 10:50 PM
Mobil One synthetic Tranny fluid is it worth it Jimmy Normally Aspirated Powertrain 6 06-04-2001 08:14 AM
