Old 12-02-2008, 08:58 PM   #1
Andrew06WRX
Member#: 185098
06 WRX SGM
beachcruiser w/ basket
Default 2006 WRX will NOT START!!!!
Please help, push the clutch in and will not even try to start. All other electronics work fine, tryed to jump start already. I swapped my interior with an STi last weekend but it started fine every time since the swap. Tonight I get nothing. Please help.
Andrew06WRX is offline   Reply With Quote
Old 12-02-2008, 09:53 PM   #2
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Try jumping the clutch start switch wires together and see if it will start? The switch is on the pedal assembly. If it starts, there is a problem with your clutch start switch.
There is also a starter relay. I think it is located in the relay panel under the hood, if its not there it will be under the drivers side dash. Find another relay that is the same part number and switch the two. If it starts the relay that's bad.
Finally the solenoid on the starter can go bad. There are two terminal on the starter. There is a large one that runs to the battery, and a small one that runs into the relay. Unplug the small terminal. Then have someone get in the car, hold the clutch down, put the key in the on position, and use something to jump the small terminal. You can use a piece of wire from the positive side of the battery to it or something from one terminal to the other. If it doesn't start the solenoid or the starter are bad.
FourOnTheFloor65 is offline   Reply With Quote
Old 12-02-2008, 09:57 PM   #3
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
+1 I just had the same prob on my 06, bad clutch switch. I used to just wiggle the harness that plugs into the switch and it would start.
06AZREX is offline   Reply With Quote
Old 12-03-2008, 12:49 AM   #4
Horkus
Member#: 112667
2002 WRX wagon
What kind of no start? No crank? Crank but no run? After market anti theft sys?
Horkus is offline   Reply With Quote
02 WRX Will Not Start Giddyb Newbies & FAQs 7 01-26-2009 08:35 PM
07 WRX will not start lilorsini Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-21-2008 05:06 PM
WRX swap in RS will not start Turb0loverRS Subaru Conversions 5 05-28-2007 10:04 AM
engine change WRX just will not start HELP cyberpest1 Subaru Conversions 3 09-17-2003 10:04 PM
Car will not start, at Evanston for Repair Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 14 01-23-2001 11:34 AM
