Old 03-27-2002, 05:35 PM   #1
GimmeScoobySnacks
Member#: 2094
1999 2.5 RS-T
RBP
Default is I/C waterspray kit worth $300?
ok so i'm gonna get my car dyno tuned in the next week or two. when i called the guy asked if i wanted to also add an IC waterspray kit which could be programmed with my Link ECU for an additional $300. is it worth it? will i even notice a difference? should i just try to make my own with a button to use it? Advice from the turbo gurus please
Sid
GimmeScoobySnacks is offline   Reply With Quote
Old 03-28-2002, 09:16 AM   #2
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
Are you running the Link or the Link Plus? The link plus has a built in programable water spray drive.
If you do not have the link plus then using a switch is probably not a great idea. If you use it when the IC is too hot the cold water can crack the IC. It should be hooked up to a TC gauge or some sort of temp sensor in order to avoid damaging the IC.
PunKidd is offline   Reply With Quote
Old 03-29-2002, 01:02 AM   #3
GimmeScoobySnacks
Member#: 2094
1999 2.5 RS-T
RBP
i have the Link Plus
Old 04-05-2002, 02:26 PM   #4
PunKidd
Member#: 8533
2002 2.5 RS-T
Well if you have the link plus then don't spend 300 bucks. All you need are some wind shield squerter parts that you can get from a junk yard for a lot less than that.
Waterspray Kits! Quantum-Racing.com Engine/Power/Exhaust 69 04-30-2005 04:38 PM
FS: CHEAP! Cobb AP, Subzeros w/azenis, IC waterspray kit lucidmatrix New England Impreza Club Forum -- NESIC 32 01-25-2005 05:09 PM
FS local: MRT Intercooler waterspray kit w/free 16 gallons of distilled water! annointed Tri-State Area Forum 6 04-07-2003 10:11 PM
Those with an MRT Auto Waterspray Kit Obscure411 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-10-2002 11:42 AM
Gauging interest in an intercooler waterspray kit... mpaone South East Region Forum 29 02-21-2002 05:53 PM
