Old 12-02-2008, 10:01 PM   #1
acemyles2.5i
Member#: 151012
2007 impreza 2.5i
urban
Default just got an intake trumpet
off an 04 sti, do i need to trim the rubber piece off the edge of the hood?
acemyles2.5i is offline   Reply With Quote
Old 12-02-2008, 10:22 PM   #2
06OutbackSport
Member#: 160318
2006 Outback Sport
I've found that it's easier to build up the bit of your snorkus (the white bit the trumpet sticks onto) rather than trimming the trumpet. If you get some decent window seal foam you can wrap that around your snorkus and then, with good quality duct tape, tape the trumpet in. I've had mine for 10,000 miles with no issues at all.
... well, actually, I take that back. The only issue was that my first bit of foam i put on, I eventually found stuck to the bottom side of my air filter. MAKE SURE YOU ALWAYS HAVE A FILTER IN THERE! After my first try, I reapplied the foam much more securely and have not had an issue since.
Another option, which some may not recommend, is taking the WRX intake elbow ($80?) which removes the snorkus, and attaching that to your airbox. Then your trumpet would work with as few restrictions as possible. Then, however, you may come across some of the issues found when removing your snorkus.
Edit: My bad. You've got an '04 and no reason to worry about MAF errors. Carry on.
06OutbackSport is offline   Reply With Quote
Old 12-02-2008, 11:50 PM   #3
bulletproof4130
Member#: 173704
07 No Show and No
Go 2.5 N/A
I believe he is talking about the rubber surround around the lip of the hood itself. i trimmed mine so more air could get there. So yes, trim the part where the trumpet is away.
bulletproof4130 is offline   Reply With Quote
Old 12-03-2008, 11:27 AM   #4
apexanimal
Member#: 170186
08 Fit
i did the same thing...
apexanimal is offline   Reply With Quote
Old 12-03-2008, 12:16 PM   #5
acemyles2.5i
Member#: 151012
2007 impreza 2.5i
urban
alright i figured so just wanted to be 100% before i cut it, thanks all
Old 12-03-2008, 04:58 PM   #6
06OutbackSport
Member#: 160318
2006 Outback Sport
ha... i missed that one. Oh well. Yeah, with that rubber piece there, things don't seem to breathe too well.
Old 12-03-2008, 05:40 PM   #7
acemyles2.5i
Member#: 151012
2007 impreza 2.5i
urban
thanks anyways outback, atleast you were trying to help haha
Just got SPT intake, now time for a tune? ATK North West Impreza Club Forum -- NWIC 28 01-06-2007 08:18 PM
Just got my intake... mlovro32 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-29-2006 05:53 PM
I just got an interview for an internship!! JewPac42 Off-Topic 30 02-20-2004 07:25 PM
just got an alarm installed, now there's engine noise kaminari Car Audio, Video & Security 3 04-30-2001 11:07 AM
I just got an e-mail from SOA... JC Legacy Forum 6 04-26-2000 04:12 PM
