Old 12-03-2008, 12:16 AM   #1
cubuff
Member#: 38345
2004 WRB WRX
Default JDM avcs cams vs. USDM avcs cams are they interchangable?
I am trying to find out if the USDM sti avcs cams from any of the current aftermarket cam makers will fit in ver8 big port heads. I cannot find any answers to this.
Then the ultimate question is... will Brian Crower 280's with avcs fit in the version 8 heads?
Thanks.
cubuff is offline   Reply With Quote
Old 12-03-2008, 07:36 AM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Cams fit fine but the signal for AVCS is different on JDM cams. The US cams have slots in the cams for the sensor signal, the JDM ones have ribs. This would probably give an inverted signal, I doubt this will make the engine management system happy.
Marnix is offline   Reply With Quote
Old 12-03-2008, 10:48 AM   #3
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
I know for a fact that the Tomei cams (same USDM as JDM as far as I know), will fit in the Version 8 heads with fully functional AVCS without issue.
No ECU problems either.
zeropsi is offline   Reply With Quote
Old 12-03-2008, 11:41 AM   #4
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Really? I thought it was a 3 part pickup v. 4 part pickup. But if it works, thats fricken awesome (maybe I should keep my JDM spec C heads!)
DoctorNick is offline   Reply With Quote
Old 12-04-2008, 12:05 AM   #5
cubuff
Member#: 38345
2004 WRB WRX
Soooo... Any sound 100% proof of USDM sti spec AVCS cams being interchangeable between US heads and JDM heads and still being fully functional?
There seems to be that discrepancy that I am unwilling to take a chance on.
Old 12-16-2008, 01:38 AM   #6
cubuff
Member#: 38345
2004 WRB WRX
Anyone in the future wanting to know the answer to this read the post quoted above. This is correct different avcs cams for usdm and jdm. Confirmed from Cosworth and Kelford.
Old 12-16-2008, 05:35 PM   #7
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
^^^^absolutely correct
john 1badSTI is offline   Reply With Quote
Old 12-16-2008, 08:22 PM   #8
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
besides the cam sensor for jdm are located toward the rear of the head.
usdm sti cam sensors are not in the rear..
got both sets of heads..jdm v7 spec C & usdm sti..
do some more homework..
Old 12-16-2008, 08:46 PM   #9
cubuff
Member#: 38345
2004 WRB WRX
From what I understand this isnt what makes the AVCS not work in either casing. The cams themselves can work in different heads. Its the actual avcs signals as descibed above that is non-compatable.
Old 12-16-2008, 11:20 PM   #10
john 1badSTI
Member#: 77470
usdm cam sensors for the avcs are located at the rear of the heads,whereas the wrx single cam sensor is located on the drivers side front of the head behind the intake cam sprocket.
Old 12-17-2008, 12:28 AM   #11
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
true that!!
back on topic....
If you run your USDM stuff on the JDM heads, you shouldn't have a problem.
Big Ports heads, on USDM ECU/harness. Only thing different are the combustion chambers, intake ports, valve springs, etc.
Run the USDM AVCS cam cap assembly, put USDM AVCS cam sensor on and voila?
FuJi K is offline   Reply With Quote
Old 12-17-2008, 05:56 AM   #12
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
OMGHi2U cam signal
so which em are you going to use?
how are you going to invert the signal?
Old 12-17-2008, 09:36 AM   #13
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
If you use US cams with US sensors and a US ECU, the signal doesn't need to be inverted, correct?
bluescoobywagon is offline   Reply With Quote
Old 12-17-2008, 11:41 AM   #14
john 1badSTI
Member#: 77470
as long as the wiring harnesses are the same
JDM AVCS solenoid vs. USDM AVCS solenoid coolcougar Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 39 11-08-2012 08:02 AM
Analysis of Cosworth AVCS cams vs USDM STI cams bboy Built Motor Discussion 89 06-18-2008 03:48 PM
JDM WRX vs USDM WRX Cams cegpcola Built Motor Discussion 7 12-22-2006 12:08 PM
JDM Ver 7 Vs. USDM STi cams Surb00 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-27-2004 03:46 PM
Trade JDM Spec C cams for USDM Sti Cams Julio Private 'For Sale' Classifieds 0 11-16-2003 09:09 PM
