Old 12-03-2008, 09:51 AM   #1
mpaone
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Unhappy sigh, yep another EJ20G cold start thread
So aside from the "usual" IAC issues, latley the cranking on my EJ20G has been worse and worse.
Today it just clicked once each time I turned the key. Left it alone to start my other car and heard a clicking under the dash every couple of seconds (relay?).
Then after about 5 minutes it started but almost stalled. After work today I'm bringing the alternator and battery to get checked but I doubt it is either of those. Will install a spare starter this weekend as well just in case.
Any ideas from the NASIOC community?
Thanks,
-Mike.
mpaone is offline   Reply With Quote
Old 12-03-2008, 11:36 AM   #2
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
all i can say is gl
and holy crap 3rd member on nasioc 0_0!
JDMFLCL is offline   Reply With Quote
Old 12-03-2008, 12:28 PM   #3
gongeuzler
Member#: 16103
GC's
Sounds like your battery may not have enough cold cranking amps. Ive experianced this before, the relays will fire off and the car doesnt seem to have enough power to crank it over.
gongeuzler is offline   Reply With Quote
Old 12-03-2008, 01:13 PM   #4
mpaone
Member#: 3
2012 Geeteeeye
Thanks for the feedback.
Brought both in at lunch and battery-replace, alternator- only putting out about 3 amps(?)- basically replace. So, um yeaaaa.
Battery is free 3 yr replacement from Sears;Alternator I'm watching a few on e-bay.
-Mike.
Old 12-03-2008, 01:15 PM   #5
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
trust me...do a compression test. latley my car had done the same thing....then it started running more and more like crap. so i did a a compression test......tunerd out cyl 4 had 32psi.......sux. all the other 3 were up at 151 acroos the boards.
check cyl 4 first and see what it turns out to be. it is def worth a shot. my ringlands blew out, and currently i have my motor out of the car and rebuilding it. ej20g going to be freshly rebuilt.
gc8awdsti is offline   Reply With Quote
Old 12-03-2008, 01:55 PM   #6
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
compression has nothing to do w/ the clicks he's hearing , start w/ the battery ,then check starter connections Alternator only comes into play once the car has been started & is running
G/l
sense of nature is offline   Reply With Quote
Old 12-03-2008, 02:04 PM   #7
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
yeah belive it or not i heard the clicks also, sounds like a relay under the dash clicking on and off. i know this. the thing is, it kept getting harder and harder to crank for no reason. new battery, starter, alt...i bought alot of stuff and still had the problem. i rechecked all the wiring that ECS did for me, and it was perfect....so i just was like "hmm i wonder what my compression results are" so i did a test and come to find out it was 150-151-151-32
Old 12-03-2008, 03:53 PM   #8
mpaone
Member#: 3
2012 Geeteeeye
Guys, look a few posts up... both battery and alternator are bad.
After I replace those I can move onto other things.
Thanks,
-Mike.
Old 12-03-2008, 04:12 PM   #9
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
-Mike.
I have a spare alternator for sale. Comes with a free EJ22 motor!
subaruwrx is offline   Reply With Quote
Old 12-03-2008, 05:08 PM   #10
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Am I one of the few who doesn't have 20G issues?
i_c_the_light is offline   Reply With Quote
Old 12-03-2008, 05:21 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
seems liek it. im scurred of jdm turbo ej's :{
mxpunk is offline   Reply With Quote
Old 12-03-2008, 05:31 PM   #12
kingsubi
Member#: 19239
2011 WRX
I have no real issues after replacing the turbo and the shortblock...
kingsubi is offline   Reply With Quote
Old 12-03-2008, 06:12 PM   #13
gongeuzler
Member#: 16103
GC's
If I were in your shoes ide be frightened by them too.
Old 12-03-2008, 07:05 PM   #14
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
naa, i put 7K miles on a ej18/22t hybrid that was boosted with no EMS.. i aint scared of nothing!
i find it funny i had little to no problems with my homemade turbo kit equipped impreza but these factory turbo motors are crapping out and having problems.
if i had the time i would def buy a jdm ej20 motor and use it for a na turbo kit build up. I hear them ej20k heads flow nice
Old 12-04-2008, 09:13 AM   #15
mpaone
Member#: 3
2012 Geeteeeye
Lightbulb
Truthfully this car has given me less problems than my new MY02 WRX when I had it... barely any issues for the 2.5 years I've owned this car.
Now back on topic- borrowed an alternator and used the same battery and the car started right up this morning. It was warmer than usual tho (about 40). Bought another alternator and getting a gel cell batt. this week.
-Mike.
OT Docs: Yep, another please help me thread. UKscooby Off-Topic 18 08-11-2010 09:55 PM
another swap won't start thread SubeSTIle Subaru Conversions 0 02-26-2008 09:18 PM
Yep, another "What car would you get?" thread by CvD Car vs. Driver Mid Atlantic Impreza Club -- MAIC 38 04-05-2007 09:36 AM
Yep, another "Name That Noise" thread thejean Built Motor Discussion 29 02-24-2007 06:02 PM
Yep, another Rammstein thread Pomorski Off-Topic 6 01-21-2006 09:29 PM
