Old 12-03-2008, 02:36 PM   #1
Bryanwrx
Member#: 157349
2010 WRX
Default Idle problem/maf sensor/wth?
Hi guys, and some gals,
So I drive a 99 impreza 2.2ts (ej22 NA, automatic woohoo). Recently I had changed the intake (after much research) to a weapon R secret weapon. I know the name is really dumb, but their price was right, as was their research, and it had a MAF adapter....finally. So i installed it about a month ago. Yesterday i was pushing it a alittle, at about 5500 rpm, and the car just died. Ignition stayed on, but the engine would not remain running for more than a few seconds.
So I ended up switching the MAF sensor for one from a EJ25 ( same part number). It now runs, but after many ECU resets and about 50km of driving, it still runs rich. Can someone please point out something that may have also gone wrong at the same time.
So at idle it runs rich (black smoke) and is a rough idle. while driving it goes cleanly through the power band no problems. thanks
bryan
Bryanwrx is offline   Reply With Quote
Old 12-03-2008, 02:44 PM   #2
FabFlatFour
Member#: 185213
2007 Impreza 2.5i
UGM
Sounds like your problem could be similar to what williaty researched, not sure though...check out his thread at the link for more details.
http://forums.nasioc.com/forums/show....php?t=1471819
FabFlatFour is offline   Reply With Quote
Old 12-03-2008, 03:33 PM   #3
Bryanwrx
Member#: 157349
2010 WRX
read that already (but thanks for going through the trouble of finding it). I popped back on the stock airbox and tried to line it up to the snorkus...not long enough. So basically i will be heading to my performance shop and getting a slight extension. if this works then i will do a little write up on it. As well i called my local subaru dealer asking if there was truly a recall on the maf sensors...they are going tog et back to me. thanks btw!
Old 12-03-2008, 03:59 PM   #4
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
nah dude it has nothing to do with that thread!! you just need to rescale your maf and youll be fine. let me know if you need help doing it
watchunglava is offline   Reply With Quote
Old 12-03-2008, 04:05 PM   #5
Bryanwrx
Member#: 157349
2010 WRX
well i reset my ecu (took the negative terminal off for like 2 hours) will that do it?
Old 12-03-2008, 05:51 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
I dont think he can rescale his MAF like we can with opensource. maybe with some other ECU piggyback/software/etc?
Old 12-03-2008, 05:53 PM   #7
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
I hear that holding down the brake pedal for a min or so will bleed off any residual voltage left in the system via the tail lights. id do that, too. That's with the battery disconnected, of course. But if its a MAFv scaling issue, then no, it wont help. if its something else, it might help.
Old 12-03-2008, 06:17 PM   #8
watchunglava
Member#: 168862
sorry dude didnt realize open source wasn't avalible for the 99. good luck
Old 12-03-2008, 11:08 PM   #9
Bryanwrx
Member#: 157349
2010 WRX
well found the problem. igured id take a guess that the maf sensor i received was also a little buggy, which it was. A trip to my local subbie dealer indicated that after a 77$ bill i needed a new sensor. fixed and runs great! thanks for the help gents
cheers
bryan
Old 12-03-2008, 11:27 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
For future reference, if swapping MAF sensors doesn't cure the problem like it did for the OP, a failed front O2 sensor, or an exhaust leak before the O2 sensor can both cause this problem as well.
So i unplugged my MAF sensor...fixed idle Suby Steve Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-19-2009 03:26 PM
Replaced MAF, cleaned IAC, still idle problems? Aaron'z 2.5RS Service & Maintenance 15 08-21-2007 06:17 PM
low idling problem with new 02 sensor sc00ter Service & Maintenance 3 01-14-2007 05:46 PM
MAF sensor problem??? acorazzin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-22-2006 05:41 PM
Um help.....EJ205 swap/ MAF sensor problems!!!! Homemade WRX Subaru Conversions 7 10-31-2003 04:12 PM
