Welcome to the North American Subaru Impreza Owners Club Thursday April 24, 2014
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 12-03-2008, 04:52 PM   #1
The Boombop Shop
Vendor Sales Rating: (11)
Member#: 175296
2010 Impreza STI
Subaru Stars ATP, Carrillo, Cosworth, CP, Fluidyne, Hallman, Koyo, Mishimoto
Bolt-On Turbocharger Kits
Internal Wastegate
P/N:ATP-SUB-001 GT3071R Compressor Map
P/N:ATP-SUB-002 GT3076R Compressor Map
P/N:ATP-SUB-005 GT35R Compressor Map
External Wastegate
P/N:ATP-SUB-007 GT3071R Compressor Map
P/N:ATP-SUB-006 GT3076R Compressor Map
P/N:ATP-SUB-008 GT35R Compressor Map
P/N:HBC-PRO Hallman Pro
P/N:HBC-PRX Hallman Pro RX
P/N:HBC-EVO Hallman Evolution
P/N:HBC-ERX Hallman Evolution RX
P/N:SB-2LTR>-65137S Pro-H with 3/8 CARR Bolts 524g H-Beam Unlimited HP/Rod
P/N:SB-2LTR>-65137H Pro-H with 3/8 WMC Bolts 519g H-Beam 250 HP/Rod
P/N:SB-2LTR<SA-65137H Pro-SA with 3/8 WMC Bolts 517g A-Beam 200 HP/Rod
P/N:SB-2LTR-1<A-65137H Pro-A with 3/8 WMC Bolts 509g A-Beam 100 HP/Rod
CALL
Long Blocks
CS600/CS600X
2004-2006 Subaru Impreza WRX STI EJ25 USDM (Includes Cosworth KK3766 Camshafts)
P/N:20000161 Includes: Factory STI Forged Crank; 8.2:1 CR
P/N:20007705 Includes: Factory STI Forged Crank, 9.2:1 CR
P/N:20000162 Includes: Cosworth 79mm Billet Crank, 8.2:1 CR
P/N:20007709 Includes: Cosworth 79mm Billet Crank, 9.2:1 CR
P/N:20003488 Includes: Cosworth 81mm Billet Crank, 8.2:1 CR
P/N:20007711 Includes: Cosworth 81mm Billet Crank, 9.2:1 CR
2004-2006 Subaru Impreza WRX STI EJ25 JDM/EUDM (Includes Cosworth KK3920 Camshafts)
P/N:SB8008 Includes: Factory STI Forged Crank, 8.2:1 CR
P/N:20007707 Includes: Factory STI Forged Crank, 9.2:1 CR
P/N:20000160 Includes: Cosworth 79mm Billet Crank, 8.2:1 CR
P/N:20007708 Includes: Cosworth 79mm Billet Crank, 9.2:1 CR
P/N:20003490 Includes: Cosworth 81mm Billet Crank, 8.2:1 CR
P/N:20007713 Includes: Cosworth 81mm Billet Crank, 9.2:1 CR
2007 Subaru Impreza WRX STI EJ25 (Includes Cosworth KK3766 Camshafts)
P/N:20002504 Includes: Factory STI Forged Crank, 8.2:1 CR
P/N:20007706 Includes: Factory STI Forged Crank, 9.2:1 CR
P/N:20002503 Includes: Cosworth 79mm Billet Crank, 8.2:1 CR
P/N:20007710 Includes: Cosworth 79mm Billet Crank, 9.2:1 CR
P/N:20003489 Includes: Cosworth 81mm Billet Crank, 8.2:1 CR
P/N:20007712 Includes: Cosworth 81mm Billet Crank, 9.2:1 CR
CS600 MAX
Includes Cosworth 81mm Billet Crankshaft, 260,000 PSI Head Studs, 12mm Blueprinted Oil Pump
P/N:20007212 8.2:1 CR
P/N:20007215 9.2:1 CR
P/N:20007211 8.2:1 CR
P/N:20007214 9.2:1 CR
P/N:20007213 8.2:1 CR
P/N:20007216 9.2:1 CR
Bearings, Gaskets, Head Studs
Main Bearings
P/N:20002720 Size 0
P/N:PR7940 Size 1
P/N:SB0006 Size 2
Rod Bearings
P/N:20002721 Size 0
P/N:PR7889 Size 1
P/N:SB0007 Size 2
Head Gaskets
EJ20
P/N:20000919 0.78mm thickness
P/N:20000922 1.10mm thickness
EJ25
P/N:20000913 0.78mm thickness
P/N:20000913 1.10mm thickness
P/N:20002145 1.50mm thickness
Head Studs
P/N:20002440 EJ20/EJ25 260,000 psi tensile strength (30% stronger than ARP)
Engine Components
Short Blocks
2004-2008 Subaru Impreza WRX STI EJ25
P/N:SB8005 Includes: Factory STI Forged Crank, 8.2:1 CR
P/N:SB8007 Includes: Cosworth 79mm Billet Crank, 8.2:1 CR
P/N:20007703 Includes: Cosworth 79mm Billet Crank, 9.2:1 CR
P/N:20003486 Includes: Cosworth 81mm Billet Crank, 8.2:1 CR
P/N:20007703 Includes: Cosworth 81mm Billet Crank, 9.2:1 CR
Cylinder Heads
P/N:KK3670 2004-2006 EJ25 WRX STI
P/N:20001699 2007 EJ25 WRX STI
P/N:20004544 2008+ STI
With Camshafts
USDM (with KK3766 Camshafts)
P/N:SB8010 2004-2006 EJ25 WRX STI
P/N:20002024 2007 EJ25 WRX STI
JDM/EUDM (with KK3920 Camshafts)
P/N:SB8012 2004-2006 EJ25 WRX STI
P/N:20002026 2007 EJ25 WRX STI
Camshafts
EJ20
P/N:KK3765 IN: 272/10.0mm; EX: 272/10.0mm
P/N:KK3920 IN: 278/10.7mm; EX: 274/10.0mm JDM/EUDM
EJ25
P/N:KK3814 IN: 260/9.6mm; EX: 260/9.6mm
P/N:KK3766 IN: 278/10.7mm; EX: 274/10.0mm
Billet Crankshafts
EJ25
P/N:20002315 79mm
P/N:20002316 81mm
Stroker Kits
P/N:20002501 EJ20 (2.2L)
P/N:20002500 EJ25 (2.6L)
Intake Manifold
P/N:20006438 EJ25 (Shipping 01/21/08)
Intercooler Kit
P/N:20005378 2008+ STI
Valvetrain
Valve Springs, Titanium Retainers
P/N:20000166 High RPM, Single
P/N:KK3839 Ultra-High RPM, Dual with Titanium Retainers
Valves
P/N:SB0034 Stainless, Intake +1.0mm
P/N:SB0033 Inconel, Exhaust +1.0mm
Pistons
EJ20
P/N:20003677 92.00mm / 8.0:1 CR
P/N:20003678 92.50mm / 8.0:1 CR
EJ20 2.2L Stroker
P/N:20003685 92.00mm / 8.5:1 CR
P/N:20003687 92.50mm / 8.5:1 CR
EJ257
P/N:20003674 99.50mm / 8.2:1 CR
P/N:20003675 99.75mm / 8.2:1 CR
P/N:20003676 100.0mm / 8.2:1 CR
P/N:20004531 99.50mm / 9.2:1 CR
P/N:20004532 99.75mm / 9.2:1 CR
P/N:20004533 100.0mm / 9.2:1 CR
EJ257 (2.6L) Stroker
P/N:20003682 99.50mm / 8.2:1 CR
P/N:20003683 99.75mm / 8.2:1 CR
P/N:20003684 100.0mm / 8.2:1 CR
P/N:20004534 99.50mm / 9.2:1 CR
P/N:20004535 99.75mm / 9.2:1 CR
P/N:20004536 100.0mm / 9.2:1 CR
Rods
P/N:20002587 EJ20/EJ25
Oil Control EJ20/EJ25
P/N:KK3928 High Volume Oil Pump
P/N:20001185 Blueprinted High Volume Oil Pump
P/N:20001238 High Volume Oil Pan
P/N:20002499 Oil Control Baffle
Miscellaneous EJ20/EJ25 Parts
P/N:20002270 1993-2007 Impreza WRX STI Air Filter
P/N:20002270 2008 STI Air Filter
P/N:20004539 Air Pump Delete Plates
P/N:SB0001 Timing Belt Guide
P/N:20004953 Kevlar Timing Belt
P/N:SB0002 Cam Angle Sensor
EJ20
P/N:SC7399 92.00mm / 8.5:1 CR
P/N:SC7400 92.50mm / 8.5:1 CR
P/N:SC7401 93.00mm / 8.5:1 CR
EJ25
P/N:SC7410 100.0mm / 8.5:1 CR
EJ257
P/N:SC7420 99.50mm / 8.2:1 CR
P/N:SC7421 100.0mm / 8.2:1 CR
P/N:SC7422 99.75mm / 8.2:1 CR
Fluidyne Aluminum Radiators
P/N:FHP11-02WRX 2002 WRX
P/N:FHP11-04WRX-STI 2003-2007 WRX/STi
Koyorad Aluminum Radiators
P/N:R1819 1990-1994 Legacy Turbo
P/N:R2218 1993-1998 Impreza
P/N:R2450 2002 WRX
P/N:R2704 2003-2007 WRX/STi
Mishimoto Aluminum Fan Shrouds
P/N:MMFS-WRX-01 2002-2007 WRX/STI
Mishimoto Aluminum Radiators
P/N:MMRAD-WRX-01 2002-2007 WRX/STi
P/N:MMRAD-WRX-08 2008+ STi
Authorized Warehouse Distributor of ATP Turbo, Carrillo, Cometic, CP Pistons, Hallman, Fluidyne, Koyorad, Mishimoto Products.
We can also be reached by:
PM / EMAIL / CALL
MSN: sales@theboombopshop.com
AIM: The Boombop Shop
We will pricematch any authorized dealer.
We ship worldwide
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]TEL[/B]: (909) 390-7088
[B]FAX[/B]: (909) 390-0788
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
The Boombop Shop is offline
Old 12-05-2008, 02:32 PM   #2
The Boombop Shop
Member#: 175296
2010 Impreza STI
Subaru Stars Carrillo, Cometic, Cosworth, CP Pistons, Fluidyne, Hallman, Koyorad, Mishimoto
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-06-2008, 11:32 PM   #3
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-08-2008, 03:27 PM   #4
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-09-2008, 08:53 AM   #5
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-09-2008, 04:21 PM   #6
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-10-2008, 12:46 PM   #7
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-10-2008, 08:31 PM   #8
The Boombop Shop
Member#: 175296
2010 Impreza STI
Default Carrillo, Cometic, Cosworth, CP Pistons, Fluidyne, Hallman, Koyorad, Mishimoto
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-11-2008, 04:53 PM   #9
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-12-2008, 10:23 AM   #10
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-13-2008, 04:01 PM   #11
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-14-2008, 05:09 PM   #12
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-15-2008, 02:51 PM   #13
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-16-2008, 08:16 AM   #14
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-17-2008, 01:48 AM   #15
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-18-2008, 04:27 PM   #16
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-19-2008, 04:04 PM   #17
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-22-2008, 03:54 PM   #18
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-23-2008, 07:42 AM   #19
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-23-2008, 07:52 PM   #20
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-27-2008, 05:24 AM   #21
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-30-2008, 06:07 PM   #22
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 12-31-2008, 07:15 AM   #23
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 01-02-2009, 05:03 PM   #24
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Old 01-05-2009, 04:00 PM   #25
The Boombop Shop
Member#: 175296
2010 Impreza STI
__________________
[B]BOOMBOP INC[/B]
3969 E GUASTI RD
SUITE B
ONTARIO, CA 91761
UNITED STATES
[B]EMAIL[/B]:
[B]WEB[/B]:
[/EMAIL]
Closed Thread
ATP, Carrillo, Cosworth, CP, Fluidyne, Hallman, Koyo, Mishimoto The Boombop Shop Engine/Power/Exhaust 176 12-22-2010 06:41 PM
Carrillo, CP Pistons, Fluidyne Sale The Boombop Shop Vendor 'General Sale' Forum 76 07-30-2009 08:13 PM
STI cp pistons, carrillo rods, 2.5 short block cbrdragbike Engine/Power/Exhaust 8 07-02-2008 05:37 PM
Bare Block (EJ257), CP Pistons, Carrillo/Cosworth Rods modify Engine/Power/Exhaust 6 04-21-2008 01:28 AM
FS Carrillo rods and custom cp pistons 100mm bore jrexguy Private 'For Sale' Classifieds 16 08-24-2005 07:30 PM
