Old 12-04-2008, 12:46 AM   #1
ebrake_n
Member#: 112036
09 FXT
04 WRX Wagon S2
Default SOS.. Serpentine Belt help!
It came time to change out my belts. As I try and do all the work on my car i can i figured changing the belts can't be that hard.. i have done it on my truck. Well it is easy as pie with the exception of 2 things.
1) The tensioning plate for the tension pulley (below the AC comp) snapped in half So now i have a dead car and have to ride my bike to the dealership in the morning. What are my chances that they stock this part? I want to be there when they open so i can get home, fix my suby, and get my butt to work. And seeing as i have to ride my bike there I am going to leave the house well before they open.. so i can't call. Should I wait for them to open in the morning to see if they even stock this part.. or take a chance?
2) The belts i got (Goodyear Poly-V Gatorback) are very tight.. as in i will have to try like heck to get them on even when the tension pulley it off and the alt is all the way down. Is this right? Should they be this hard to get on? I checked the Shicks Auto site to make sure i picked up the right ones and according to the site i did (although on the back of the package it says 3.3L?)
The #'s are:
4050345
4040350
Any help you could provide would be greatly appreciated!
-Mr. Shadetree
ebrake_n is offline   Reply With Quote
Old 12-04-2008, 09:50 AM   #2
rick-l
Member#: 33868
2003 wrx
srp
Those are the part numbers I found on the Goodyear website also. I went with the dealer parts cause they were cheaper.
Item 1) sounds like you forgot to loosen the bolt in the center of the pulley. A quick call to your dealer would answer the question.
rick-l is offline   Reply With Quote
Old 12-04-2008, 10:13 AM   #3
rkramer
Member#: 118209
2015 WRX Limitec
I'm betting the post above mine is exactly right on. The center pulley doesn't slide like it appears to, you need to loosen the nut on the pulley BEFORE touching the tensioner. Failure to do so will snap either the entire bracket or will break the far end of the tensioner off. (ask me how i know that!) LOTS of threads on here about people that have broken it doing similar stupid things.
btw, it is safe to drive without the acc belts if you need to. just not too long of a distance if you have no alternator turning.
Old 12-04-2008, 10:36 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If the AC belt tensioner broke that's just for the AC belt and nothing else, so it's perfectly safe to drive without it for as long as you need to. The PS/alternator belt is another story, driving without that is not a good idea as you will have no power steering and the alternator won't charge so you'll be running on the battery.
If the belts you got are tight even with the tension adjustments all the way down, they are probably the wrong ones. I'd suggest getting the right ones from a dealer if you have one nearby, and returning the ones you ordered. The dealer belts are not expensive and the quality is better than most of the aftermarket ones.
Old 12-05-2008, 02:12 AM   #5
ebrake_n
Member#: 112036
09 FXT
04 WRX Wagon S2
Thanks for the tips.. and support that i am not a total nub and my mistake is in a flawed visual design of mechanical operation. The car is fixed and runs like the champ she is
The local shop had all the parts i needed in stock. The replacement tension plate for the pulley was only $8.. small price to pay for a learning curve :P
Old 12-07-2008, 02:40 PM   #6
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
ive broken my tensioner before . sucks its like $75 . dealer will rip you off. if you need a new one there are better sites on the net
watchunglava is offline   Reply With Quote
04 H-6 Outback serpentine belt? White Knight Legacy Forum 3 07-06-2007 07:27 AM
serpentine belt squeal question Oas1s Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-07-2007 09:28 AM
Serpentine belts replacement ms3p Service & Maintenance 10 04-10-2007 02:16 PM
Way OT: Anyone changed a serpentine belt on a '91 Escort LX? Siper2 Mid Atlantic Impreza Club -- MAIC 1 11-26-2006 04:08 PM
Serpentine belt Synaestheisa00 Newbies & FAQs 2 12-04-2005 02:01 AM
