Welcome to the North American Subaru Impreza Owners Club Monday September 22, 2014
Old 12-04-2008, 10:28 AM   #1
AMR
Member#: 171509
Thumbs up 2005 SAABaru - Full Race 1.5 Header / TD04 Turbo / Rom Raider
Vehicle: 2005 SAABaru 9-2x (2.0L WRX Engine/Drivetrain)
Horsepower: 257whp (140whp stock)
Torque: 280wtq (140wtq stock)
Modifications:
- STOCK TD04 Turbocharger
- STi Top Mount Intercooler ('04-'07 STi)
- Full Race 1.5 Header w/ Up-pipe
- COBB Turbo Back Exhaust System (catless)
- AMR 750cc Injectors
- AMR Electronic Boost Control Solenoid (EBCS)
- NGK 1-Step Colder Plugs
- PERRIN Turbo Inlet Hose (2.4")
- AMR BMI Cold Air System
- TGV Deletes Housings (Race Port & Match)
- Walbro 255 Fuel Pump
Tuning:
- Rom Raider tuned by AMR
Dyno Sheet:
Boost vs AFR:
Thoughts:
Very clean car. I noticed with the TGV Deletes and the Full Race Header the TD04 was a little on the laggy side. But not really noticable on the street. Really rips tires lose in 2nd gear. Customer was extremely satisfied. Timing was at 11.5 degrees at peak torque and 19 degrees at redline. Air Fuel Ratio was around 11.2-11.0. Tune was done on 93 octane.
-Rob
AMR is offline   Reply With Quote
Old 12-04-2008, 10:33 AM   #2
wrxhard
Member#: 108091
This is the second plot i've seen a full-race header with a td04, and both looked quite laggy. My guess is it's just too much header for such a small turbo. Powerband looks good though for sure. 257 whp out of a td04 is nothing to sneeze at either!! Good job guys.
wrxhard is offline   Reply With Quote
Old 12-04-2008, 10:37 AM   #3
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
19* at redline? Don't you think that's a little on the low side?
akira02rex is offline   Reply With Quote
Old 12-04-2008, 10:41 AM   #4
AMR
Member#: 171509
Thank You.
-Rob
Yes and No. We noticed on this vehicle giving it the timing up top did nothing. 1 or 2 hp. Why give it more timing if it is not worth the gain. We would rather keep is safe and happy.
On top of this, it is cold out. Gas stations are "winterizing" there gas. So again, safety and reliability is number one priority. Not the extra 2hp
-Rob
Old 12-04-2008, 10:45 AM   #5
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
That's odd... I ran more timing than that on my 2.0L wrx w/ a 20G, approx 5* more.
Could be that there was an issue with the engine. But..looks like it made great power!
Old 12-04-2008, 11:01 AM   #6
CatfaceType-R
Member#: 81102
awesome stuff rob, i like your tuning philosophy
CatfaceType-R is online now   Reply With Quote
Old 12-04-2008, 01:23 PM   #7
AMR
Member#: 171509
Thank You!
-Rob
Old 12-04-2008, 01:24 PM   #8
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
I agree!
Great job.
SuperSTI is offline   Reply With Quote
Old 12-04-2008, 01:43 PM   #9
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
do you have any other td04's with stock manifolds or an UEL or EL that you can lay over this plot?
td04 and FR headers.....i find that very weird. i was certain that absolutely no one under a 49 lb/min turbo would even think about that manifold....i take it a turbo upgrade is in the works, hence the 750cc injectors?
Old 12-04-2008, 02:12 PM   #10
AMR
Member#: 171509
Phatron,
Yes. He will be upgrading the turbocharger during Christmas. He went ahead and did the TGV deletes and the upgraded injectors. I can print some plot of TD04 with stock manifolds off the dyno for comparison. There will be a big difference regarding spool time.
-Rob
Old 12-04-2008, 02:40 PM   #11
Phatron
Member#: 36033
CEO PhatBottiTuning
so the FR manifold isnt good on smaller turbos? i swear i saw some testing with Perrin EL's that showed that the perrins added power on everything from td04's up to gt35's. and i thought the fr was supposed to be better the the EL's everywhere.
i thought the 1.5 scroll design was supposed to aid spool and lowend power and was the whole purpose of the design to properly utilize the cylinder pulses?
Old 12-04-2008, 02:45 PM   #12
AMR
Member#: 171509
It is a very nice header. Fabricated very well. On this vehicle with the additional TGV deletes and larger TMIC, it caused the TD04 to be a bit on the laggy side but as plus gave some great pull from low-mid-to-high rpm band.
-Rob
Old 12-04-2008, 07:25 PM   #13
tmarcel
Member#: 7555
Because all motors are not the same Some do more BTDC timing than others.
tmarcel is offline   Reply With Quote
Old 12-04-2008, 08:26 PM   #14
fastwrx25
Member#: 126441
03 bugeye
wow thats alot of torque for a td04. nice!
I was expecting to see some race gas or meth in the mod list.
fastwrx25 is offline   Reply With Quote
Old 12-04-2008, 08:51 PM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
what correction factor was used?
Old 12-04-2008, 09:46 PM   #16
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
hey rob, do you have a dyno graph of another td04 2.0 ltr with the boost turned up on a stock pnp'd manifold or a perrin?
All4bSpinnin is offline   Reply With Quote
Old 12-05-2008, 09:17 AM   #17
AMR
Member#: 171509
Extremely fun to drive.
He has an Aquamist Meth Kit that we are going to install. I am not sure if he would want to tune it on this or on his upgraded turbocharger.
-Rob
Phatron,
Just the standard 1.00 setting the dyno comes with. We dont believe in correction factors. The vehicle makes what it makes, the gain is all we are interested in.
-Rob
As soon as I get some time I will have to go through the computer on the dyno and find some to put on as comparisons.
-Rob
Old 12-05-2008, 12:49 PM   #18
iamchris
Member#: 106479
2005 9-2X Aero
Fluorescent Brown
140 whp and wtq? What dyno is this on? You know you're supposed to go full throttle, right?
iamchris is offline   Reply With Quote
Old 12-05-2008, 12:54 PM   #19
SuperSTI
Member#: 67182
2004 Subaru STi
what a tool question to ask
Old 12-05-2008, 12:57 PM   #20
iamchris
Member#: 106479
2005 9-2X Aero
Fluorescent Brown
It's a serious question. What stock WRX nets 140 whp?
Old 12-05-2008, 01:09 PM   #21
SuperSTI
Member#: 67182
2004 Subaru STi
on a dyno dynamics with 1.00 correction and my buddy who has a bone stock 2.0l bugeye dyno'd at mzm on there mustang put down 140whp as well. use the search button before asking questions. on a dyno jet, that read 15-20% higher, it puts down 180whp+ which is probably what you are used to seeing.
Old 12-05-2008, 01:11 PM   #22
MattPersman
Member#: 139385
dynos like AMR's, Buschur's, MZM's break hearts of stock cars
MattPersman is offline   Reply With Quote
Old 12-05-2008, 01:43 PM   #23
OppositeLock
Member#: 54060
Now: v8 207/v6 5mt
Then: JRTune fastest td04
Agreed, adding a TMIC and TGV deletes adds more spool time then people realize. I have always heard that my plots look laggy for a td04 (only a few hundred rpm quicker then this one and I don't have the big header), but I have a Helix TMIC and TGV deletes.
Anyway, nice tune. That midrange looks wild. Also, about the spool, how hot was the header?
Yep, uncorrected DD's are killers for guys looking for numbers. Mine only put down 265whp uncorrected, but trapped 111-112 to put it into perspective.
OppositeLock is offline   Reply With Quote
Old 12-05-2008, 02:27 PM   #24
eqlized_aero
Member#: 88699
2005 92x V8
92x V9 Spec C Type RA
It will be interesting to see what he nets with the bigger turbo on the FR header. Ported stocker works just fine for me. That's a hell of a lot of money to put in to a header on 2.0L car that could have been put in to a built block and netted more power.
eqlized_aero is offline   Reply With Quote
Old 12-05-2008, 02:40 PM   #25
iamchris
Member#: 106479
2005 9-2X Aero
Fluorescent Brown
So you're saying that this car would dyno over 300whp on a dynojet with a stock turbo?
Full-Race 1.5 Scroll header/uppipe tested on Yimi Sport's 08 STi socalLGT Proven Power Bragging 272 10-28-2011 02:19 PM
Full race twin-scroll header question davidm_sh Factory 2.5L Turbo Powertrain 9 12-31-2010 02:54 AM
Full-Race 1.5 scroll manifold/uppipe stidoc Factory 2.5L Turbo Powertrain 4 12-28-2009 10:54 PM
Full Coolingmist 1.5 Gal Meth kit, Top Feed 930cc, Turbo XS- Divored DP UpSideDownDesi Engine/Power/Exhaust 35 12-02-2009 02:28 PM
2005 Saabaru 9-2X Aero 5 speed Scooby do MWSOC Private Classifieds 11 03-25-2007 07:28 PM
