Old 12-04-2008, 10:37 AM   #1
dlong27
Member#: 191010
2011 Lego Premium
Default IAC issues
My car has intermittently been throwing a P1507 code, which is the idle air control, it'll pop up for a while, then go back off with no noticeable cause. The only symptoms i have experienced are, if I have been driving for a few minutes, then come to a complete stop, clutch depressed mind you, the RPMs will drop to around 3-400 and almost die, then immediately snap back to normal idle. Also, if the car is cold, the RPMs will stay high when I shift, as in if I shift at 3k, it will keep spinning at 3k only dropping slowly between shifts, but this is only when cold. I took the IAC out and cleaned/ greased it throughly yesterday and also cleaned the throttle body out, but Im still experiencing the same symptoms and CEL. Do I need a new IAC or could it be something like a vacuum leak? I can't hear anything that sounds like a vacuum leak around the motor and Im trying everything in my power to avoid having it serviced for a $500+ job, any help would be great
Thanks in advance
-Dan Long
dlong27 is offline   Reply With Quote
Old 12-04-2008, 11:00 AM   #2
Hedbergsuby07
Member#: 160840
2007 impreza
urban gray scoooped
any mods ?
Hedbergsuby07 is offline   Reply With Quote
Old 12-04-2008, 01:46 PM   #3
dlong27
Member#: 191010
2011 Lego Premium
Only custom catback exhaust, 2 1/4" pipe all the way back with a Tanabe Hyper Medallion axelback, stock as a rock other than that, this began before I had the exhaust installed so that has nothing to do with it
Old 12-04-2008, 10:01 PM   #4
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
read these . you can do this yourself . save your money.
http://www.automedia.com/Sensor_Trou...cr20010901ic/1
and then how to do it on a subaru.
http://forums.nasioc.com/forums/showthread.php?t=781242
god google is easy i guess its even easier for you that im here lol!
watchunglava is offline   Reply With Quote
Old 12-04-2008, 10:44 PM   #5
dlong27
Member#: 191010
2011 Lego Premium
Well as my original post stated, I didnt know if there was something else causing the code, i.e. a vacuum leak or something else, Im going to order a new IAC soon, im sick of that GD little light!!
FYI, I searched quite a few times and found exactly what you sent me, it doesn't apply to my car in that mine is different than a WRX's but thanks anyway.
Old 12-04-2008, 11:58 PM   #6
watchunglava
Member#: 168862
fyi suck it. no cels on my ride right now so. your welcome!
Old 12-05-2008, 07:17 AM   #7
dlong27
Member#: 191010
2011 Lego Premium
Bitterness much? who pissed in your cheerios?
Old 12-05-2008, 12:21 PM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
sounds like your iacv is a little slow. the high rpm's is normal on a cold engine. when you depress the clutch and rpms drop to 400, that's your iacv taking longer than normal to open up and let air flow thru. sounds like you may need a new one. you may also try to check in your idle air passages for any obstruction.
Old 12-05-2008, 01:44 PM   #9
dlong27
Member#: 191010
2011 Lego Premium
Yea, I've come to the sad realization that I need to drop $400 on a part thats the size of my thumb Hopefully I can get one in a boneyard/ ebay, gotta check around for some prices. I thoroughly cleaned the air passage when I had the valve off so it must be the valve, thanks for the advice!
Old 12-05-2008, 01:54 PM   #10
watchunglava
Member#: 168862
no way dude you can get that part much cheaper , you sure the wrx iac is different? looks like its the same place to me but whatever . yours isnt on the throttle body?
Old 12-05-2008, 03:04 PM   #11
dlong27
Member#: 191010
2011 Lego Premium
Yea, its different from the WRX, its a little valve on the side of the throttle body thats electrically controlled, I found the damn thing on Ebay from a wholesaler used 2 days ago for 50 bucks and now cant find it again , any idea where i could get one for less than 400? thats what Autobone quoted me at.
Old 12-05-2008, 03:10 PM   #12
watchunglava
Member#: 168862
pm subie gal and get a part # then post it here and ill see what i cant find for you.
Old 12-05-2008, 03:19 PM   #13
dlong27
Member#: 191010
2011 Lego Premium
Hey, i just found it again, I forgot what search string I had used and it was a weird URL, I think it's ended though at least for the time being, part # is A33-661 R02, thanks for the willingness to help!
Old 12-05-2008, 03:22 PM   #14
watchunglava
Member#: 168862
hell yea im all about it !!! im bored as hell right now im sitting around and my 2 year old is napping. ive seen them around for like $300 new so , or you could allways hit up the junk yard or check the classifieds here and see if anyone is doing a part out. i still cant wrap my head around why it would have gone bad? dirty and non functional yes but bad?
Old 12-05-2008, 03:35 PM   #15
dlong27
Member#: 191010
2011 Lego Premium
yea that seems odd to me too but I'm a n00b with newer car stuff, i guess just a matter of odds, some of them have to go bad out of all the ones out there, guess thats just my luck!!
Old 12-05-2008, 03:38 PM   #16
watchunglava
Member#: 168862
try and soak that thing over night in sea foam the clean it up . sea foam is like jesus juice
Old 12-05-2008, 03:40 PM   #17
dlong27
Member#: 191010
2011 Lego Premium
haha, that won't hurt the electronics in it? im just nervous about Effing it up worse and having a non-running car
Old 12-05-2008, 03:46 PM   #18
watchunglava
Member#: 168862
you said it was efed allready? what can it hurt. the problem allready is the electonics are probably shot . just thinking of ways around a $300 part. $6 can of sea foam . to make sure it isnt just too dirty.
Old 12-05-2008, 03:49 PM   #19
dlong27
Member#: 191010
2011 Lego Premium
True, I'm really grateful for the help, I'll give that a shot cuz I've got nothing to loose.
Old 12-05-2008, 04:46 PM   #20
Storm
Member#: 5218
96L Most Over-
Developed Beater
6 pins on the plug, right? I just sold one of these over on RS25.com. I have another one, but it won't be available for a week or so.....if you can wait that long.
It's currently on my car but not hooked up since I'm frankenstein'd to high heaven. I'm waiting on a different harness plug to use another throttle body. As soon as it comes in, I'll be pulling this TB off. Feel free to PM me. If it's dire need, I can make up a blockoff plate and run that way til the stuff shows up.
Jay
Old 12-16-2008, 01:23 PM   #21
96imprezaL
Member#: 145635
2005 LGT Stg4 soon;)
GRP
hey im having the same trouble but can you tell me where the iac is?? mine is a 96 impreza l 2.2l...heres some pics of what i think it is:
is that it?? thnaks
96imprezaL is offline   Reply With Quote
Old 12-16-2008, 02:28 PM   #22
dlong27
Member#: 191010
2011 Lego Premium
is that it?? thnaks
I believe it is, they are attached to the throttle body and either have a wire harness or coolant line which connects to them, depending on the vehicle. Here's a link to one on ebay which fits your car http://cgi.ebay.com/ebaymotors/2-2-2...mZ350133479175
Good luck!
Old 12-16-2008, 02:37 PM   #23
96imprezaL
Member#: 145635
GRP
awesome thanks so much
Old 12-16-2008, 07:27 PM   #24
dlong27
Member#: 191010
2011 Lego Premium
No prob! no need for anybody else to go thru the same PITA that I did
Old 12-16-2008, 07:44 PM   #25
shineysideup
Member#: 197671
1997 Impreza
red/ black
I just replaced my iac and now car won't start.
shineysideup is offline   Reply With Quote
Possible Tranny issue, grinding with no load battlewaggin Transmission (AT/MT) & Driveline 3 06-06-2010 01:02 AM
IAC Issues banana_pony95 Newbies & FAQs 8 11-24-2008 07:48 PM
IAC issues on 02 wrx(again) GREDDYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-17-2005 09:25 PM
98 ECU, open iac and closed iac (need help wiring a link) Keith Subaru Conversions 5 09-02-2005 08:49 PM
tec-3 iac rangere7 Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-15-2002 10:48 PM
