Welcome to the North American Subaru Impreza Owners Club Thursday September 18, 2014
Old 03-27-2002, 10:03 PM   #1
moebiusone
Member#: 6773
wrx impreza
Default Uppipe power gain ?
Hy, I wanted to know what power gains can you get with installing an uppipe ?
Thanks
moebiusone is offline   Reply With Quote
Old 03-27-2002, 10:10 PM   #2
samowrx
Member#: 8403
not much power but less lag with means power comes on sooner.
samowrx is offline   Reply With Quote
Old 03-27-2002, 10:19 PM   #3
mitch808
Member#: 10228
2002 Subaru WRX
Lets see....
5-7HP
close to 100 degree cooler EGT's
500RPM faster spoolup on your turbo
mitch808 is offline   Reply With Quote
Old 03-27-2002, 10:37 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
This is a dyno chart that Vishnu posted:
That line in the middle is with the plugs, up-pipe, and underdrive pulley. The lines at the bottom are stock.
Obviously that would put an up-pipe somewhere in between (basically that line minus the pulley, probably in the +7-10 HP range)
The other benefits are, as was mentioned, the better throttle response/spool up which is easily seen in the graphs, the lower EGTs, and the added security in knowing you're cat can't crumble into your turbo.
Concillian is offline   Reply With Quote
Old 03-27-2002, 10:41 PM   #5
WRXVII
Member#: 15854
VF34'd...
think turbo mag did dyno w/ uppipe and their gain was about 5 hp. Downpipe gain was the most at ~10 hp w/ 15 lb-ft of torque.
WRXVII is offline   Reply With Quote
Old 03-27-2002, 11:46 PM   #6
slin02
Member#: 11588
best thing about the uppipe is that you don't have to worry about the melt down. safe for the engine and safe for the turbo
slin02 is offline   Reply With Quote
Old 03-28-2002, 03:23 AM   #7
Blugin
Member#: 5270
2008 EvoX MR
Red
I gained 15 at the wheels after install and unichip dyno tune.
Blugin is offline   Reply With Quote
Old 03-28-2002, 03:31 AM   #8
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
From our testing on the Dynojet:
Up-pipe on otherwise stock WRX: 7-9 wheel hp
Downpipe with cat on top of Stage Zero : 13-15 wheel hp with Unichip remapping
Downpipe with cat plus Cat-back (turbo-back) on top of Stage Zero: 30-35 wheel hp with Unichip remapping
Cheers,
shiv
Vishnu Performance is offline   Reply With Quote
Prosport Header+Uppipe 20hp Gain... ryan_west06 Car Part Reviews 0 08-13-2009 08:59 PM
uppipe, downpipe, cat back....how much power gain? jimtweet Factory 2.0L Turbo Powertrain 10 01-23-2004 01:27 AM
Initial data on MRT exhaust power gains Patrick Olsen Normally Aspirated Powertrain 10 08-18-2001 10:30 AM
Best power gains?? OsakaGangsta Normally Aspirated Powertrain 4 06-18-2001 08:01 PM
power gain from cams RidinLow Technical Forum Archive 11 09-17-2000 09:05 AM
