Old 12-04-2008, 06:52 PM   #1
colost.wrx
Member#: 196635
2002 Impreza Wrx
Have a Nice Day? EGT sensor help
I just purchased my car under 3 months ago and recently the EGT sensor worked its way out from the uppipe. I noticed it when my wrx sounded like a diesel truck. I took it to the dealership and they informed me the sensor had "unscrewed" itself somehow. They want to charge me $190 to screw it back in for me because of the inconvinient location. I'm reluctant to pay so much for a "repair" that I feel I could do myself. However I am unfamiliar with the upipe and am not sure if it would be something I could accomplish or not. I am mechanically inclined but am in college dorms without a place to work on it. I could drive it 1.5 hr home where I have tools, but is it safe. What a dilema
colost.wrx is offline   Reply With Quote
Old 12-05-2008, 01:23 AM   #2
RealiTnh
Member#: 191452
2004 ej20 18g 303whp
@ 20psi Synaptic tuned
You should be able to reach the bung from under the hood and you can try rethreading it in or just do what I did and plug it with an M12 x 1.25 pitch bolt. I had to use a large nut and a lock & regular washer to make up for to much length on the bolt. Also grab a 2.2k 1/2 watt resistor from Radio Shack to keep you ECU smiling... Easy fix!
RealiTnh is offline   Reply With Quote
Old 12-05-2008, 01:43 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
search around here for the fix
its easy......and cheap......ive cut the cable off close to the hex with a bolt cutter and cut the probe off at the taper and used jbweld on the threads of the remaining part of the probe and the 2.2k ohm resistor in the plug on the firewall
and been permanantly done in 30 minutes
Old 12-05-2008, 07:10 PM   #4
colost.wrx
Member#: 196635
2002 Impreza Wrx
Thanks For the Imput! My car is currently at the dealership, If I go over there to see if I can rethread it myself, do you know what tools I'll need? Or what parts I might have to remove to get to it (if any).
Old 12-05-2008, 07:21 PM   #5
mikeythejew
Member#: 141672
Unhappy Sad smiley for the fail
I'm tired of people using the sad smiley lately unless they have a real i$$ue like, "why is my my engine knocking"?
mikeythejew is offline   Reply With Quote
Old 12-06-2008, 04:23 PM   #6
colost.wrx
Member#: 196635
2002 Impreza Wrx
Exclamation
Public Service Anouncement: i changed it to a neutral face so i don't upset anyone
Old 12-06-2008, 04:51 PM   #7
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
forget about it and get an upipe while you in there.
sackytar is offline   Reply With Quote
Old 12-08-2008, 07:06 PM   #8
colost.wrx
Member#: 196635
2002 Impreza Wrx
Thanks For all of the help, I successfully put the EGT senor back in and possibly will plug it later as it does have an HKS Aftermarket upipe. The sensor is viewable under the hood without removing any parts. I will post pictures later If I can.
Old 12-08-2008, 07:23 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
hks up is garbage
if it leaks....replace it
Need help finding flare nut for EGT sensor STi2001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-12-2002 10:28 PM
EGT sensor striped on stock uppipe! help wRxbeater11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-27-2002 09:37 PM
HELP!! EGT sensor problem bobgrice Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-11-2002 07:59 AM
Stock EGT Sensor HELP! D_REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-15-2001 10:59 PM
Need help installing EGT sensor IMPBOY Bay Area Impreza Club Forum -- BAIC 4 02-27-2001 11:43 PM
