Old 12-04-2008, 07:52 PM   #1
manxaru
Member#: 123021
Default black OEM oil filters - NLA?
After thoroughly reading all of the threads, and deciding that the OEM (black 15208AA080) filter was the best choice for my newly assembled STi motor, i just found out that 5208AA080 was superseded by part number 15208AA09A.
What's the take on the new oil filters? Doesn't seem like the 15208AA09A is the same as the old 15208AA080?
Has anything better come along?
manxaru is offline   Reply With Quote
Old 12-04-2008, 08:13 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if you can find the old black ones
buy them
if not....
Old 12-04-2008, 08:31 PM   #3
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Found some still available!
Opie is offline   Reply With Quote
Old 12-05-2008, 12:08 AM   #4
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
What happens if you run the new filter?? llol
mxpunk is offline   Reply With Quote
Old 12-05-2008, 12:13 AM   #5
manxaru
Member#: 123021
I think your head explodes...I read it online so it must be true
Old 12-05-2008, 08:51 AM   #6
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
What's the take on the new oil filters? Doesn't seem like the 15208AA09A is the same as the old 5208AA080?
Get some of the 15208AA100 filters while they're still available. I just bought a 6-pack of them here: http://www.subarugenuineparts.com/
The latest filter looks like garbage in comparison to the 'A100.
AndyH is offline   Reply With Quote
Old 12-05-2008, 09:10 AM   #7
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
buy them
if not....
The reason being?
Micky is offline   Reply With Quote
Old 12-05-2008, 09:14 AM   #8
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Looks like? Oil filters are cosmetic parts now are they?
Explain please.....
Old 12-05-2008, 12:13 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
Explain please.....
this is real simple
and basic
if you open one up
and does NOT concern you unless and until you move to the USA and bring your car with you
Old 12-05-2008, 02:21 PM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
An oil filter is an oil filter is an oil filter....there is no mystic voodoo science in them. Mind you I'm no tribologist, but I have better things to worry about than oil filters.
<-----use Purolator Pure Oil gold sandy ones for bling only
Old 12-06-2008, 05:20 AM   #11
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
this is real simple
and basic
if you open one up
Both filters will operate exactly the same, under the conditions specified for the car. If you change oil and filter as deemed necessary by Subaru, you will not see any difference.
Try working in a mass production environment, these sort of changes occur all the time, to save costs. These changes would have been tested to make sure they stand up to the requirements of the car.
Usually customers don't throw their toys out of their cot about it though
Old 12-06-2008, 07:01 AM   #12
mikeythejew
Member#: 141672
Micky, since your from Japan, can you send a 24' container by ship full of the black filters to the U.S.?
mikeythejew is offline   Reply With Quote
Old 12-06-2008, 09:29 AM   #13
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
I think a lot of subaru owners are concerned about this oil filter change
with good reason....
previously subaru hired a "usa" company (purolator) to mass produce oil filters for them
only to have to CANCEL that contract when the filters proved defective
and leaked often and continuously
Makes perfect sense that many would want the black Tokyo Roki filters which have been very reliable.
Old 12-06-2008, 11:03 AM   #14
bluesubie
Member#: 767
04 FXT
You do not know that is the case unless you have examined the filters (and know what you're doing) and have performed a used oil analysis in similar conditions on the new and old filters.
Like Subie Gal's example shows, just because it is a filter that SoA uses does not mean that it is better.
-Dennis
Old 12-06-2008, 12:26 PM   #15
996Cabby
Member#: 17008
'12 AUDI A6
Miss my subey :(
the black STi filter is designed to help with better oil pressure...I am not sure about this new filter, but I haven't heard anything about that around here yet...my friend works at Subaru, I'll find out some more info. ....if this is the case, it's probably a cost savings measure on Subaru USA's behalf....Just like the white 6 star filters we have here in Ontario costs almost a 3rd the price......If this is the case, they are stupid !
996Cabby is offline   Reply With Quote
Old 12-06-2008, 01:36 PM   #16
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
go down the middle of the page to see side by side picture comparison of the old and new oil filter.
http://www.iwsti.com/forums/2-5-lite...rs-blue-2.html
tekfoc is offline   Reply With Quote
Old 12-07-2008, 02:45 AM   #17
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
-Dennis
Exactly what Subaru would/should have done. Think about it, if every car serviced by Subaru was fitted with a new filter that was substandard, that could result in a recall just as if the fault originated from the factory.
Read my post again, nowhere did I say the replacement filter was better, I said that it would be designed to perform to the Subaru specified requirements (filtration/mileage between changes etc), no more no less.
On the other hand if you guys want a container full, no problem... 40 bucks each and I'll send them.
Old 12-07-2008, 07:08 PM   #18
bluesubie
Member#: 767
04 FXT
I did not say that you said the replacement filter was better. You stated that both filters will operate the same. Yes, they will both filter oil but you do not know how well.
The Tokyo Roki has proven to be an excellent filter in construction (as evidenced by the numerous filters that have been cut open) and oil filtration (as evidenced by excellent uoa's).
The new filter has some mighty big shoes to fill and I won't be trying them on. Then again I run my oil for 8k miles so I need a good filter.
-Dennis
Old 12-10-2008, 11:38 PM   #19
only1agam
Member#: 56183
i got some filters racked up but i was wondering about the purolator pureone filters.. what is the part number for a wrx (03 in this case) for a purolator pureone oil filter? is it PL14460? b/c i found an excellent deal on amazon for them for <$6 for 2 of them (after rebate).
heres the link
http://www.amazon.com/gp/product/reb...8969944&sr=1-1
only1agam is offline   Reply With Quote
FS(socal) 2 OEM oil filters+ 2 washer rings and 1 Fram oil filter fusionchicken Engine/Power/Exhaust 0 08-21-2009 05:26 PM
Thank me later.... Do you want the awesome Subaru 0100 Black OEM Oil Filters? volkl23 Service & Maintenance 2 11-28-2005 11:39 PM
Tune Up parts, OEM oil filters, fuel filters air filters, spark plugs LangstonSubaru Accessories & Misc 14 05-05-2004 11:49 AM
OEM Oil Filters, OEM Turbo oil filters, fuel filters, spark plugs, air filters LangstonSubaru Vendor 'For Sale' Classifieds 125 03-29-2004 08:25 AM
Source for "Nippon" black OEM oil filters Orson Service & Maintenance 9 03-19-2004 09:55 AM
