Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 12-04-2008, 10:11 PM   #1
hotsauce61488
Member#: 175119
white
Default Installing Up And Down Pipe, Few Questions
im ordering my megan up/down pipe tomroow and plan to install the day they come. my friend who is going to help me, let me just say idk if i can trust the kid .. hes crazy but he seems to do his own work on his fp green wrx
My question is, for a simple up/down installation like this , what possible things can go wrong in the process so i have a heads up .. he is telling me hes done the installation more than 5 times, he said in order to get the stock uppipe offu have to loosen 1 motor mount and lift the motor bout 2 inches
Is he right ? i know people have their own methods but tell me what u guys think .. id rather not pay someone a couple hundred if my friend can help me
hotsauce61488 is offline   Reply With Quote
Old 12-04-2008, 10:13 PM   #2
novacivic
Member#: 117980
2005 sti
wr blue
first off this is in the wrong forum
and yes your friend sounds like he knows what he is talking about
novacivic is offline   Reply With Quote
Old 12-04-2008, 10:16 PM   #3
hotsauce61488
Member#: 175119
white
sorry ill move it
Old 12-04-2008, 10:42 PM   #4
Psyk
Member#: 92203
2012 SWP WRX Hatch
RIP 05 WRX
Yes, taking the one motor mount off to lift the engine is needed to get the uppipe out (there's other methods, but this is really the easiest way about it). Aside from that, the rest is just a matter of taking everything apart. The worst thing That I can think of happening is breaking a bolt or doing the opposite and stripping it.
Also, I'm sure this is already known, but soak the hell out of all the bolts with PB Blaster, or the like.
Psyk is offline   Reply With Quote
Old 12-04-2008, 10:46 PM   #5
hotsauce61488
Member#: 175119
white
thanks
Old 12-04-2008, 10:48 PM   #6
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
he doesnt really sound like a friend at all if you cant trust him lol
BONFIRE074 is offline   Reply With Quote
Old 12-04-2008, 10:51 PM   #7
hotsauce61488
Member#: 175119
white
well i mean hes my friend he jus is crazy in general haha
Old 12-04-2008, 11:19 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
there is NO NEED to......oh bloody hell
forget it
Old 12-04-2008, 11:25 PM   #9
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
forget it
No, tell us.
i_c_the_light is offline   Reply With Quote
Old 12-05-2008, 01:52 AM   #10
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
forget it
I'll do it...
Since you're taking the DP off AND the UP, you might as well pop off the turbo and then yank the up pipe from above. It comes out just fine with the turbo out of the way (or even just the DP removed and someone holding the turbo up, really).
Lightly fasten the uppipe, then the turbo (remember those brackets from the passenger's side head!!!), then the DP, line up everything, and torque everything in this order:
1. Header to UP
2. UP to turbo
3. turbo brackets
4. turbo to DP
5. DP to CBE
USE FRESH GASKETS, and please retorque everything after a couple of heat cycles.
Most importantly - good luck, and if you run into trouble use the search here, there a a boat load of install threads with similar headaches, trust me
Abnormal is offline   Reply With Quote
Old 12-05-2008, 01:53 AM   #11
cwr5035
Member#: 176324
02 WRX
Yes your friend is right. That is one way to do it. I personally find it easier to pull up the turbo to get to the uppipe.
cwr5035 is offline   Reply With Quote
Old 12-05-2008, 03:08 AM   #12
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
I always did it the way your friend did. Getting to the O2 Sensor in the header is a pita. Not sure if a13's method requires the removal of that.
Jubert69 is offline   Reply With Quote
Old 12-05-2008, 04:15 AM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by a13n0rma1 View Post
I'll do it...
1. Header to UP
2. UP to turbo
3. turbo brackets
4. turbo to DP
5. DP to CBE
you do NOT need to remove the turbo or the brackets to get the up out
you do NOT need to take the o2 sensor out of the manifold, either
you do NOT need to jack up the engine, either
you do NOT need to......
bloody hell....just forget it
Old 12-05-2008, 10:54 AM   #14
steverx05
Member#: 128269
'13 VW Golf R
I didn't jack up my engine or remove my turbo to install my new uppipe. I don't understand how the uppipe install for our cars got so mixed up with misinformation and controversy. People make such a huge deal about it, and it's really not that bad.
steverx05 is offline   Reply With Quote
Old 12-05-2008, 12:23 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
ding-ding-****ing ding
and im so damned tired of trying to stem the tide of idiots doing stupid UNNECESSARY things---and causing all sorts of OTHER UNNECESSARY PROBLEMS along the way
im sick of it.....and this and bovs and the stupid slammed koo-koo-kiddie crap
god help us all....the end is near
Old 12-05-2008, 12:27 PM   #16
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Amen brother.
Audiosavvy is offline   Reply With Quote
Old 12-05-2008, 12:27 PM   #17
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Meh, I think the extra step helps the noobs out At least in terms of having room to visually see what's what and where.
Old 12-05-2008, 12:52 PM   #18
smurfwrx
Member#: 151928
09 Triumph S3
LMAO @ U.S. Man, you've just had it up to *here* haven't you?
smurfwrx is offline   Reply With Quote
Old 12-05-2008, 02:53 PM   #19
efjellanger
Member#: 64152
Midnight Blue
I had heard it was possible to remove the UP without removing the turbo or jacking up the engine.
I tried to do so. I moved the UP around in every direction I could think of. I couldn't figure it out.
I unbolted the motor mount and jacked up the engine a couple of inches and it came right out. It was easy.
Removing the turbo sounds like a big hassle to me.
As in all things, YMMV.
efjellanger is offline   Reply With Quote
Installing Up And Down Pipe, Few Questions hotsauce61488 Service & Maintenance 7 12-05-2008 11:44 AM
Up pipe and Down Pipe CEL questions njskatchmo Tri-State Area Forum 4 04-21-2006 12:17 PM
up and down pipe install jeffsnyder Forester Forum 1 06-28-2004 04:36 AM
Starting UP and Down Pipe Install MidRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 09-17-2003 12:31 PM
up and down pipe post install overheating! michael skalyo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-02-2003 01:40 PM
