Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 12-04-2008, 07:58 PM   #1
XmikeX
Member#: 184768
05 WRX
toasted white
Default change brake fluid
read about it in the sticky and it says oem brake fluid, does it really matter what type of brake fluid you put in there? like will autozone brake fluid work or would you guys suggest a better quality, and how much fluid will i need? my car is 30k miles on it so i doing complete system flush
looking to getting it changed at a local shop called jims tire man anyone know if all shops use about the same brake fluid?
thanks
XmikeX is offline   Reply With Quote
Old 12-04-2008, 08:32 PM   #2
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
I don't think I would get cheap brake fluid, like the in house store brand. Usually the cheaper the fluid the lower the boiling point. There are other options that are locally available and at a decent price.
A lot of people use Motul and other fairly expensive fluids in street cars. I don't see the need. It might be a bit overkill. If you don't track the car or anything you might want to try Valvoline's Synthetic Dot 4+ fluid. You can get it at most autoparts stores. It seems to be nice compromise between something like the Motul and a standard or OE fluid. I have been using it in all my cars for some time now without problems. I autocross a little and I drive pretty hard on mountain roads frequently. With the way I drive, I don't see a need to order a better fluid.
FourOnTheFloor65 is offline   Reply With Quote
Old 12-04-2008, 08:40 PM   #3
XmikeX
Member#: 184768
05 WRX
toasted white
thanks for the info, do yuo know how many bottles i will need to do the flush?
Old 12-04-2008, 08:42 PM   #4
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
As long as you don't end up wasting a whole lot a quart should do the trick.
Old 12-05-2008, 01:59 AM   #5
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
there are seveal good, cheap brake fluids
the Valvoline synthetic DOT4 is likely the best bang for the buck...a quart is under $10
a step up would be Ate 200 and Ate Super blue(same product, one colored blue, one not) is another good, inexpensive choice
http://www.raceshopper.com/brake_fluid.shtml
Old 12-05-2008, 02:04 AM   #6
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
ATB SB Ftw.
Wrx_Fan_0717 is offline   Reply With Quote
changing brake fluid stronzo Brakes, Steering & Suspension 7 02-17-2004 09:22 PM
Changing brake fluid??? Wrx17 Brakes, Steering & Suspension 3 01-08-2004 11:18 PM
how to change brake fluid? yamahito Service & Maintenance 3 02-15-2003 05:10 PM
How to change brake fluid? WRXVII Service & Maintenance 4 02-11-2003 03:35 PM
Changing Brake Fluid. mav1c Brakes, Steering & Suspension 6 11-15-2000 11:21 AM
