Old 12-04-2008, 10:18 PM   #1
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
Default are the specs for ej engines the same??
I was just wondering if the specs for all ej type engines were the same for stuff like piston #ing, TDC, BDC, is it the mark you have to line up with the crank sensor . I know that the bores and strokes have to change for displacement!! how much doe's the comp ratio change between like G's k's 22t's and 205's 257's etc. I am having a bigggg prob setting the timing on a early 20G. keep pulling the left cam's out when trying different method's ofpulling the belt over the last idler (over the oil filter) can some one tell me of some kinda cam holding tool or some kinda trick!!!
thanx Jesse
94 GT is offline   Reply With Quote
Old 12-04-2008, 10:27 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
put the smooth idler on the bottom on last
Old 12-05-2008, 01:27 AM   #3
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
and use large office clips to hold the belt onto the cam sprockets... The alligator type, that are black with the wire handles.
Arctic Assassian is offline   Reply With Quote
Old 12-05-2008, 09:20 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Ding ding ding. Me too. :D
94GT,
Post pictures. Based on your PM to me, I think you may have a problem with your parts.
Old 12-05-2008, 08:53 PM   #5
94 GT
Member#: 193676
94 legacy GT
yeah I did!! the tensioner pulley was the one off the EJ22 I thought it was the one off the 20g but it wase'nt!! I looked in the trunk o parts and realized that the one back ther was the 20's so I put that one on then loosened all the Idlers (so they were floppy) and left the bottom (smooth) one on but all loose put the origanal tensioner pulley . took two tries but now it is as close as it gets the left bank cams are .5 teeth off the two hash marks are lined up within the double hash allowence!! hope thats good enough? now just hooken all the stuff and wating foe a intercooler and a coolant resivour!!!
Old 12-08-2008, 03:59 PM   #6
thad
Member#: 176616
1994 impreza
white
If its being difficult, I use a pair of vice grips wrapped in a shop towel to hold the belt to the left bank intake gear. I just lock it on gently far enough to the side so I can just see the timing mark.
I've also noticed some slight inaccuracies in the marks on the gears for the 20G.
I put a ver. 2 sti 20g together awhile back and was having allot of trouble getting the two double hash marks to line up on the left side, then the other day, i took a look at another EJ20G (non sti) with the original timing belt on it, and it had a similar issue, all marks line up but the two double lines on the left side. go figure.
as far as the tensioner and pulley, they appear to be identical to the early ej sohc parts.
thad is offline   Reply With Quote
Old 12-08-2008, 10:05 PM   #7
94 GT
Member#: 193676
94 legacy GT
yeah I got it good I think as I am driving it now!!! I loosened all the pulleys including the grippy one!! used the 20g's tensioner pulley tried twice and the left cams are not perfectly straight with one another like the right ones but are sooo close that the left mark on the top one(INTAKE) matches with the right mark on the bottom one(EXH) it runs pretty good considering the gettod intake to replace the TMIC that I have'nt got yet!! thank you for your help!! I think that most OHC (with two cams or more) engines have those double marks for that little play that is allowed to keep in most proper time, both toyota engines and a honda had simalar marks the toyotas were the same exactily. gotta rember this bout belts that they have give and flex when changing RPM,s and temp all that stuff right!! thanx again Jesse.
Are the 03 and 04 engine the same ? jaytone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-19-2009 06:58 PM
Are the 03 and 04 engine the same ? jaytone Subaru Conversions 6 04-17-2009 02:25 PM
How important are torque specs for a rear sway bar and endlinks? Kwyjibo Brakes, Steering & Suspension 7 05-14-2003 01:02 PM
What are the specs for the gold 17" split/flair 5 spoke STi wheels? Cosworth Brakes, Steering & Suspension 3 08-03-2001 05:01 PM
Are all SOHC 2.5L engines the same? Ken Levin Normally Aspirated Powertrain 5 04-02-2001 04:14 PM
