Old 12-04-2008, 11:57 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Can a Single HFC Totally Eliminate the Stench?
OK, so I switched to the EL headers, which are catless. The car smells HORRIBLE. So bad, in fact, that every time we slow down before a stop, one of us has to reach over and turn off the heater so we don't suck up exhaust fumes. It's a nasty, sickly, burning, caustic, acrid smell. No smell of rotten eggs/sulfur though, which kind of surprises me.
Will a single high-flow cat completely eliminate the smell? The stock cats totally took care of it, BTW.
Old 12-05-2008, 12:13 AM   #2
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
i have the single hfc on my line and i havent gotten a cel , if its that functional then im saying its good . i havent disabled the cel either its enabled and i havent gotten it.
exhaust allways stinks to me , it definatly stinks more at cold start i guess cause the cat isnt hot yet.
watchunglava is offline   Reply With Quote
Old 12-05-2008, 11:03 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
do you have a leak at one of the joints?
I've run catless for years and never get a strong smell of exhaust...
Old 12-05-2008, 11:53 AM   #4
piker28
Member#: 22664
Even when I was running a single hfc i would get the smell once and awhile... but as said above it def sounds like you must have a leak somewhere
piker28 is offline   Reply With Quote
Old 12-05-2008, 02:19 PM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No leak. Checked multiple times.
Old 12-05-2008, 02:49 PM   #6
piker28
Member#: 22664
I have been in multiple catless cars and non act the way you describe that is why i presumed a leak. But to answer your question yes a cat would help cut some of that smell down
Old 12-05-2008, 07:10 PM   #7
GrundleJuice
Member#: 165749
I have never noticed any smell since doing my headers and stromung HFC. Honestly, if i didnt know anything was different i would think it was stock (as far as the smell goes). Little more evidence that a cat, HF or not, may help. You think it may be your header wrap/coating? does it smell as soon as you start the car or does it take a couple mins to start stinking up your ****?
GrundleJuice is online now   Reply With Quote
Old 12-05-2008, 08:34 PM   #8
watchunglava
Member#: 168862
i was also thinking the header wrap but thought that would be obvious , is it smoking? take it on a good 100 miles drive and really heat those babies up.
Old 12-05-2008, 08:41 PM   #9
EdHilario
Member#: 137398
2004 Impreza 2.5RS
One HFC on my car and still smells like gas. You need at least one true cat.
EdHilario is offline   Reply With Quote
Old 12-05-2008, 08:43 PM   #10
watchunglava
Member#: 168862
mine dont smell like gas just smells like exhaust . your running nice and rich if you smell rbob7 in your exhaust
Old 12-05-2008, 11:42 PM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It starts as soon as the car starts, doesn't change as the car gets hotter. It's definitely not the header wrap as I have probably 1k miles on the car already.
Comparing to two other catless cars tonight, it's definitely the smell of an catless exhuast. HFC it is...
In the middle of the niiiiiight.... (woken by the stench of feces) Sideshowbob Off-Topic 40 07-21-2009 02:48 PM
Steering wheel on a bug-eye... can I keep CC nd eliminate the airbag light? N'CTRL Interior & Exterior Modification 2 04-13-2009 10:45 PM
Single HFC vs. The No Cat Smell williaty Newbies & FAQs 9 01-15-2009 12:38 AM
running a hydra, can i eliminate the maf? ScreaminFast Other Engine Management 5 01-09-2006 04:56 PM
What single visual mod totally changed the look of your Subaru? RaceComp Engineering Interior & Exterior Modification 72 03-02-2004 05:06 PM
