Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 12-05-2008, 03:12 AM   #1
2_Liter_EJTurbo
Member#: 145084
1995 Impreza LSTI
Default Redline changes?
I just finished my ej20k swap in my impreza. I went for a drive and after gassing it hard it started to get fuel cut at 4500 rpm just like it would at redline. Does any one know what this is?
2_Liter_EJTurbo is offline   Reply With Quote
Old 12-05-2008, 03:15 AM   #2
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
check your coilpacks. any crack then they are no good.
boost maybe too high?
what ECU are you running?
spark plug gap?
any CEL?
gc8awdsti is offline   Reply With Quote
Old 12-05-2008, 04:54 AM   #3
2_Liter_EJTurbo
Member#: 145084
1995 Impreza LSTI
spark plug gap?
any CEL?
I have a ej20k which has 1 main coil pack and i have not seen any cracks on it at all.
Boost was my first idea i have not installed my gauge yet so i cant say for sure. I hooked everything up as if it was stock so i assumed it was at stock boost. I plan on installing my boost gauge tomorrow and checking what boost lvl im running. I also have my air/fuel gauge (not a wide band though) to install so i can sheck that out
its an 88 ecu
plug gap i did not check but they were pre gaped for a 2002 wrx
CEL?
This thing runs fine some of the time but twice now i has done this fuel cut thing like its hitting the rev limiter at 4500 rpm. When it does happen the car runs normally it still has power right up to 4500 it just wont rev higher then that.
One of my friends thought it might be my knock sensor? Would detination do this?
*Edit* What is stock boost for these things? 1997 TD04 WRX ej20k
Old 12-05-2008, 05:16 AM   #4
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
CEl= check engine light. getting one at all?
Old 12-05-2008, 10:08 AM   #5
korhan
Member#: 103202
09 sti09&00gc8
black&grey
check your speed sensor
korhan is offline   Reply With Quote
Old 12-05-2008, 10:34 AM   #6
suberdave
Member#: 101865
88 GL-10 STi
my moneys on the VSS not working properly... had the same problem with my first EJ20G swap...
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 12-05-2008, 12:42 PM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
will also do that if you hit boost cut ... (this happened to my k)
my bcs was fubar it hit 1.3bar
stock boost on the wagon should be ~9 psi or less
Old 12-05-2008, 05:37 PM   #8
2_Liter_EJTurbo
Member#: 145084
1995 Impreza LSTI
Mmmk installed my boost gauge it is running at 12 psi. Gassed it 2nd 3 or 4 times. It did not do the rev limit thing. Then I pushed it a little harder and shifted under power and I saw my boost spike to about 15 psi. Just to verify I tried it again same thing only this time right on my shift it went to limp mode.
So does this mean that jaxx is correct?
Old 12-05-2008, 06:29 PM   #9
korhan
Member#: 103202
09 sti09&00gc8
black&grey
ej20G ej20K oem ecus boost cuts in 1.2 bar. it can run continuous 1.1 bar. stock boosts are 0.8 bar at both model.
vss(speed sensor) effects the rev limit if it dont work properly and it cuts the rev at 4500
Old 12-05-2008, 06:40 PM   #10
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
Doestn the boost depend on the ECU? I have an EJ20G from an STi Wagon and the stock boost is 12.7psi. Simply upgrading the ECU should up boost.
subaruwrx is offline   Reply With Quote
Old 12-05-2008, 06:49 PM   #11
supasweetr34skyline
Member#: 113060
2000 Built GC8
Aiming for 10's
+1
supasweetr34skyline is offline   Reply With Quote
Old 12-05-2008, 07:54 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
ECU does effect boost. All teh Ej20K's are higher boost than the G's...
Old 12-05-2008, 08:06 PM   #13
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
So, speed sensor would definitely do this? What if the vss is installed to the USDM dash and not calibrated? Would it stil have this issue?
Old 12-05-2008, 09:18 PM   #14
suberdave
Member#: 101865
88 GL-10 STi
should not be an issue. i had a EJ20G ECU connected to an 87 and an 88 USDM GL dash. worked just fine.
-=Suberdave=-
Old 12-05-2008, 10:26 PM   #15
korhan
Member#: 103202
09 sti09&00gc8
black&grey
i guess it is not about the dash, if you just check or replace the vss sensor you can see the error. for all model 5 mt, we have 30 tooth profile speedo gears in the tranny. the only thing is that, you see the speed wrong on your speedometer. if you use a mph gauge cluster with a jdm swap.
Old 12-05-2008, 11:52 PM   #16
2_Liter_EJTurbo
Member#: 145084
1995 Impreza LSTI
Ok so the write up on the swap I used listed a vss pin on my edu but this was not ever connected to the black and white wires for the speed sensor on the jdm trans. Being that I'm still using the usdm 95 guages (which are mechanical) it's not connected. I did how ever connect the vss pin to the wire that was stated in the write up.
Gear Oil Change??? wickkerr82 Newbies & FAQs 6 06-04-2010 02:35 PM
Redline changes? 2_Liter_EJTurbo Pre-2002 Factory Turbo Powertrain 0 12-05-2008 03:24 AM
What to change to increase redline? blaznc Normally Aspirated with bolt-on Forced Induction Powertrain 12 05-06-2005 02:56 PM
Redline Oils need to do fluid change asap willguidry Normally Aspirated Powertrain 6 03-04-2003 11:18 AM
Can auto change the redline? DoctorNick Transmission (AT/MT) & Driveline 12 05-15-2002 12:13 AM
