Old 12-05-2008, 02:52 AM   #1
STi-Nismo Dood
Member#: 4149
MY93 ImprezaRA Sedan
GC8.6 Aspen White
Default Car stumbles/bog woes during start-up
I first experienced this problem after my mechanic cleaned out the engine bay with a power wash. The problem seemed to go away or lessen after the throttle body was cleaned. Last weekend, I power steam washed my underbody and the problem came back again, big time. I try to step on the gas and gives me a feeling like it's building up pressure and going to blow up.
I have replaced the MAF sensor, and it still seems to bog once warming up to about 5-15 minutes of running depending on how it's driven.
My next intention is to replace the o2 sensor. Although I could not see how washing the car could ground the sensor... what do I know...
So far, I notice that this situation only happens during a change in engine temperature.
STi-Nismo Dood is offline   Reply With Quote
Old 12-05-2008, 03:02 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
sounds like a wiring problem more than a sensor problem. extra water may add resistance in a circuit, causing your ecu to think somethings wrong and react to it. check all your wiring.
Squeal during start-up Schell Factory 2.5L Turbo Powertrain 7 08-17-2007 12:35 AM
Car Idles rough during start up ?? RichWRX Factory 2.5L Turbo Powertrain 9 07-18-2005 09:06 PM
DCCD flashing and ABS light on during start up. Digitalfiend Factory 2.5L Turbo Powertrain 5 07-18-2005 07:52 PM
hesitation during start up and in 2nd gear x12oyx316x Factory 2.0L Turbo Powertrain 2 05-17-2004 08:21 PM
Rattling sound during start-up a10thunder Newbies & FAQs 5 09-25-2003 02:54 PM
Message Board Statistics All times are GMT -4. The time now is 03:30 PM.
